08-27-2014, 05:13 PM
2012 30' International
Pleasant Hill
, The Golden State
LP Gas BBQ
I am considering a Weber Q-1000 LP grill. Friends rave about them. I've always been a charcoal cooker using a Cobb for the past 10 years.
Our 2012 has an LP outlet under the frame that is designed to hook a grill to and eliminate the need for the small canisters....you just run it off of your 2-tank LP supply. Neat.
Anyone using this to fire a Q-1000? Reason I ask is that Weber Customer Service said it wouldn't work right. I don't like to hear "no" and am hoping someone is using this with great results.
Thanks.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
08-27-2014, 05:40 PM
Dallas
Would imagine it has to do with the pressure from the trailer regulator not being correct for the grill but I could be wrong. Im sure others will chime in.
08-27-2014, 05:43 PM
1973 Argosy 24
Kitchener
, Ontario
The only reason it might not work right is that your regulator reduces the line pressure to less that what is optimum for the BBQ. The 1 lb cans deliver gas at full pressure and the Q has a regulator to set the working pressure. When I plumbed my 69 Chevy van for gas I had to install a separate regulator to further reduce the working pressure for the fridge. The regulator for the Coleman stove was too high pressure.
08-27-2014, 06:08 PM
2015 30' Classic
Calgary
, Alberta
LP Gas BBQ
See this video for explanation ....Coles notes:you need to remove the included regulator (on Weber) and install a coupler.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
08-27-2014, 06:11 PM
2007 30' Classic S/O
Somewhere
, South Carolina
I've got a Q200 and Q120. My real choice is real wood but either of those Weber's does a darn fine job for a go to grill. They run off of full tank pressure but your tapline is after it goes thru the regulator, don't think it works that way, been reported here several times. I use an inline T from between the tank and hose to regulator connection that I run my remote hose to the grill with.
Looks like the video above my comments might offer a solution.
08-27-2014, 06:57 PM
1998 31' Excella 1000
South Berwick
, Maine
Many years ago I installed a "T" into the gas line under the belly with an isolation valve and female quick connect. Did just as the video shows and removed regulator from my Weber Baby Q, adding female QD to grill and male to regulator. Local propane dealer made me a hose with male ends (long enough to run under trailer so you can grill with your neighbor) to connect from trailer to grill. Now still have option to use regulator with 1# bottle or if you carry along a 20# bottle - lots of flexibility. On another note, when I did this I thought you couldn't double regulate, but someone had a similar setup with the trailer supply downstream of the regulator while using the grill regulator and guess what; he had the same flame hight.
WBCCI 24291
New England Unit
Metropolitan NY Unit
08-27-2014, 08:02 PM
2015 23' International
Charleston
, South Carolina
Here is the source for the connection. Thanks to an earlier poster who directed me to this website. Works perfectly. Remove the portable tank regulator on the grill and replace with the quick connect kit.
http://caloreequipment.com/products/...-trailers.html
The Weber is an awesome grill for the convenience. I am a long time charcoal guy and big green egg user. But the weber is unbeatable for a quick easy grill. Best for a quick hot grill like a steak. Falls short for low temperature slow cooking (or indirect cooking) but then again I have never seen a gas grill that is good for that. The secret of the little weber is the cast iron grates. The grill will preheat the grate to smoking hot and sears a steak or burgers beautifully. Another plus is the grate are two piece which makes it small enough to easily wash in the sink. Also works great as outdoor camp stove for fry pans, etc.
HTH
Steve
08-27-2014, 08:15 PM
2015 23' Flying Cloud
Charleston
, South Carolina
Here is source for quick connect kit.
Weber Q Conversion Kit
Thanks to previous poster for the website.
Awesome grill for convenient quick cooking (steaks, burgers, hotdogs, etc). Not so good for slow or indirect cooking but In my opinion no gas grill is (that big green egg territory). Secret is the cast iron grates. Preheats to smoking hot and gives great seat. Another plus is grates are two piece so small enough to clean in sink. Also great as a camp stove. I substituted 10' hose so it is perfect for quick connect to front of Airstream and setting grill on tailgate of pickup.
HTH
Steve
CrackerBox
08-29-2014, 05:42 PM
Pleasant Hill
, The Golden State
Thanks for the information. Looks like the accessory LP Gas connection can be adapted to the Weber. AS put it there to use and I look forward to cooking with gas. And thanks for the link Cory_can. Directions even I can follow.
10-25-2016, 08:03 AM
2016 16' Sport
Miami
Hi
I know this is an older thread but maybe someone would have an answer for me. I've seen a conversion kit for the Weber q with a 12 foot hose. I have a 16 and the LP port is in the front. 12 foot would still be a bit close for cooking. Can the 12 foot be coupled with the 6 foot hose that came with the airstream?
10-26-2016, 05:36 AM
2023 Interstate 19
Scottsdale
PM sent!
10-26-2016, 01:47 PM
2012 27' Flying Cloud
W
, New England
I tried like crazy to find the right parts to make the conversion of my Weber Q grill - nothing matched. These guys not only have the exact kit I needed, they built me a custom hose to connect to my quick disconnect setup. I'm able to plug in to the port (which AS said HAD to go on the road side) and the hose is long enough to make it over to curb side where we "live" when camping.
Give them a call - they can help with all the details. And I'm not affiliated with them, I get no compensation from them, I just purchase, use, and love their product - and was equally wowed by their custom (and customer) service.
http://propanegear.com/weber-q-rv-quick-connect-kit/
Good luck!
10-26-2016, 04:18 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Q1000 plus Volcano Grill
I am on my second Q-grill from Webber. I love the ease of use and convenience. I have the table and carrying case also. Both are not needed, but once you have them, they become invaluable,. I bought the table used on Amazon...great investment and folds nicely for storage in back of TV. I also have evaluated several gas and charcoal grills the past 2 years. Currently, I use the Volcano several on Forum recommend. It does excellent job of cooking when you want that charcoal flavor like on nice steaks or chicken. It also has a nice carry case and sets up and folds shut very nice, to go back into the case. I switch off depending time and food we are cooking, The Q is always there for easy, fast use. I have not modified the quick disconnect regulator, and so my Q does not get hot as quickly connected to the AS propane bottles, as it does with a Coleman bottle...I will look into that modification shortly, however, after reading these threads.
10-26-2016, 07:51 PM
2016 27' International
Frisco
I purchased a Camco low pressure grill, the 5500 Olympian, I believe hooks up perfectly to Airstream low pressure point.
Arnold and Amy Terkel
2016 27FB
2021 Chevy Silverado 2500;6.6 gas
10-27-2016, 06:30 AM
2015 25' FB Flying Cloud
Manassas
, Virginia
Good luck!
Thanks for the link. I will be copying you
