Old 08-06-2019, 06:46 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Looking for a quality Weather Radio
I had a post here not to far back about a cross country trip where I encountered bad weather multiple times. I have since downloaded apps that connect with NOAA weather stations, well great, if you have cell service.
So now I am looking at weather radios, but radios are not my thing. I know I want a good one, I found C.Crane, but I canít understand all the jargon, I could not pick one.
Anybody know these things?
Ted S. is offline   Reply With Quote
Old 08-06-2019, 07:49 PM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The gentleman with which I discussed this issue maintained that his Ham Radio was the key to getting the weather warnings that he needed. That would seem to suggest, you need to be a radio guy.
Not ready to make that move as yet. So I'll continue to use the little portable that came from - https://russellsformen.com/search?query=weather+radio. It's the yellow one. Convinced your thread will wring out some other options, so I'll keep a watch to see if I can learn a bit more. Pat
PKI is online now   Reply With Quote
Old 08-06-2019, 10:56 PM   #3
2007 22' International CCD
Any weather radio will work reasonably well. You donít really need to be a ham radio operator to utilize the NOAA weather warning system.
Admittedly, as a ham in Huntsville, Alabama, I found using ham radio does give you a somewhat earlier warning assuming you are listening to a local weather net during bad weather. Typically we heard of approaching dangerous weather 2-3 minutes before the tornado sirens went off. We had a radio operator at the NWS radar site looking over the operators shoulder. He would ask for ground spotters in the area of a suspicious radar return and let all of us know what was going on.
rmkrum is online now   Reply With Quote
Old 08-07-2019, 04:55 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I have had a Sangean DT-400W in my trailer for almost ten years. It works great, it's small, and I recommend it. Runs on AA batteries, which I've been removing every fall to prevent leakage.
The DT-400W is still in production, and they cost just under $50.
Old 08-07-2019, 05:59 AM   #5
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
Not this one! Bought this off Amazon, and it is worthless. Not sure where all the great reviews came from. Maybe I just got a bad one. But I will be following this thread, as Iím in the market also.
[Upgraded Version] RunningSnail Emergency Hand Crank Self Powered AM/FM NOAA Solar Weather Radio with LED Flashlight, 1000mAh Power Bank for iPhone/Smart Phone
malinois38 is offline   Reply With Quote
Old 08-07-2019, 06:09 AM   #6
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I have a marine radio from my sailboat days. You can drop them in the water and they float. We use it sometimes when on the coasts to listen to the ships.
They are not cheap but you can throw them across the room with no damage at all.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 08-07-2019, 06:21 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I bought a C.Crane CC Skywave before my long trip through tornado country this summer. The only things I've found I dislike about it are that a) you have to turn on the "Alert" feature every 16 hours, and b) when the alert feature is on, the display backlight blinks on and off which is a bit annoying.
I place the radio face-down on the nightstand when it's in alert mode so the blinking light doesn't interfere with my sleep. It's not the cheapest option, but has a ton of nice nerd-features.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 08-07-2019, 07:20 AM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
When the radio in my trailer went out I replaced it with an AM/FM/CD with NOAA radio reception. I can always find a NOAA station to pick up. The only negative is that this is not an ALERT radio.
There are many good tabletop portable radios with NOAA reception and alerts available. I would look for one that is easy to operate and can fine tune the alerts to your immediate area.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 08-07-2019, 09:12 AM   #9
Miami Beach , Florida
Try using the app called Dark Sky. It uses your actual gps location to give you by the minute forecasts, plus the normal 7 day, and a time machine for weather from years past on any day that there were records kept. Even warns you when it’s about to rain.
rsementi is offline   Reply With Quote
Old 08-07-2019, 10:30 AM   #10
Mollysdad's Avatar
I had the C. Crane CC-Radio for years and absolutely loved it. Until the display faded out and C. Crane wasn't interested in helping me. It was a common problem.
I don't know if they solved it in the CC-Radio 2, but the biggest problem for me is inside the Airstream, radio reception is terrible. I have a nice Sangean, and almost never use it. I miss late night talk radio while I sleep.
Old 08-07-2019, 02:55 PM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you run a weather radio in tornado country "in the season" you do indeed get some of the information you need. In addition to that you get a bazillion pieces of information you have absolutely no use at all for.
There is no "real time" information on the NOAA system. It is all alerts. That means that while you get a hint that something *might* happen, you do not get information about what *is* happening. There are other more modern ways to get real time info *if* you can get a cell connection.
The alert process covers a wide area. The number of alerts can be huge. They are phrased in a fashion that assumes you have a detailed knowledge of the landmarks for a couple hundred miles in any direction. "A point 2.3 miles south west of the junction of Uncle Bob Road and County route 3357" ..... right back to needing a cell connection to look things up.
Any radio that will get any NOAA station gives you the full set of data. There is no advantage to or need for multiple stations. They are spaced out around the landscape. Being able to get at least one of them is not super tough.
Old 08-07-2019, 04:03 PM   #12
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
Oregon Scientific on Amazon. Portable and easy to use.
mike28 is offline   Reply With Quote
Old 08-07-2019, 04:18 PM   #13
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Tagging along to see what I can learn from the experience of others!
Thanks!
Old 08-07-2019, 04:40 PM   #14
2017 27' International
Galt , California
Quality WX radio
C. Crane is one of the best. Located in Fortuna CA, he designs most of the radios he sells. I have several of his radios, and they all play well with very good reception.
Andrew, K6STN
2017 27' Signature FB
2017 F-250 4x4 Diesel Lariat crew cab
One each Cavalier King Charles Spaniel
absteen is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
PKI, tommydSL64
Weather Radio? LilBigfoot On The Road... 11 01-22-2016 02:30 PM
Replacing radio antenna weather stripping on 1970 Overlander aboudre1 Exterior Restoration Forum 2 05-24-2015 11:00 PM
deal: Midland Weather Alert Radio Wayward Electronics & Connectivity 3 11-05-2014 06:29 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Weather Radio on eBay RoadKingMoe Our Community 17 05-07-2004 06:59 PM
