Old 02-22-2014, 10:58 AM   #1
stellar1dan's Avatar
2013 27' FB International
Yelm , Washington
Long term storage
So I'm in the military and am about to deploy and need to store my airstream
Long term for the first time. Besides basic winterization I've got a garage to store it in any other tips or suggestions ?
stellar1dan is offline   Reply With Quote
Old 02-22-2014, 01:39 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
1 - Block it up to take the load off the tires. The tires will slowly deflate over time.
2 - Ventilate!
3 - Disconnect batteries.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-22-2014, 02:15 PM   #3
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Be sure to leave the refrigerator and freezer door open to prevent mold and mustiness.
urnmor is offline   Reply With Quote
Old 02-22-2014, 02:17 PM   #4
urnmor's Avatar
Berlin , Maryland
And most importantly be safe
Old 02-24-2014, 10:12 AM   #5
RJ Dominic, 1975 Soverign
Flat Creek's Avatar
1985 34' Sovereign
LaGrangeville , New York
Send a message via AIM to Flat Creek
One thing to also do is to put poly film, ( a heavy one) under the trailer. The moisture wicking out of the ground goes into the bottom of the trailer and can be trapped. thus rotting out the floor, and other structural members.
Along with blocking the trailer... block under the axels. These trailers are not made to sit on their frames. they are strongest at the axel points.
Turn off your propane tanks..
And yes be safe... please
RJ Dominic
Flat Creek International, Inc.
Vintage Transport Solutions
vintagetransportsolutions.com
(914) 204-6190
Flat Creek is offline   Reply With Quote
Old 02-24-2014, 10:39 AM   #6
NEVER, EVER, block under the axles.
That can and will destroy the alignment.
You can block the trailer up using 6 jack stands, 2 on the A-frame, 2 on the axle mounting plate between the two axles, and 2 on the frame at the rear end.
Old 02-24-2014, 10:49 AM   #7
Only applies if you park on grass or gravel, I think. An asphalt driveway or concrete garage floor will not be subject to wicking action.
WBCCI #1105
TAC LA-4
Sanitize solution - long term wayneskid Fresh Water Systems 20 02-17-2014 04:13 PM
Any suggestions for RV parks in NoCal for long term stays? norma Solo Streamers 5 01-06-2012 02:42 PM
Storage in Airstream / Argosy Rick F Argosy Motorhomes 6 10-19-2011 06:30 PM
Equal-i-zer Hitch storage at home idmtman Hitches, Couplers & Balls 5 08-20-2011 04:49 PM
