Old 08-01-2016, 10:58 AM   #29
1990 32' Excella
jonesboro , Arkansas
We have a dead bolt separate from the knob lock . I put a screw in the assy to prevent the lock assy from working. We only use the dead bolt. This came about from the door self locking on our 86 32 we used to have. Had a twist knob inside and key outside.
joel is offline   Reply With Quote
Old 08-01-2016, 11:37 AM   #30
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by StreaminGeo View Post
They have the blanks and when they cut the keys they look right on - but when I put them in the lock they just won't turn.
I believe you have the Trimark lock on your door. The Trimark key blanks are unusual, and many less knowledgeable locksmiths will use one that is "close" resulting in the problem you describe.
Better locksmiths will have the correct blank, or you can get blanks from an Airstream dealer. Out-of-doors mart has them and will ship them to you. They are not expensive.
Old 08-01-2016, 11:53 AM   #31
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
It's been a few years, but I was able to order cut keys on Ebay. i.e. not key blanks, but keys cut from the code on my original set. Might be worth contacting this fella with your key codes to see if he's still in that business:
http://www.ebay.com/usr/swanyriver1
teagues is offline   Reply With Quote
Old 08-01-2016, 08:49 PM   #32
2017 25' International
Joliet , Illinois
Wow! Giving some random guy on the internet your key code AND your address. Please find a local locksmith.
bel73 is offline   Reply With Quote
Old 08-01-2016, 09:22 PM   #33
CRH
1995 25' Excella
xxxxx , xxxxxx
I have ordered eBay keys and never lost a minutes sleep about the locksmith coming to rip me off.
CRH is offline   Reply With Quote
Old 08-01-2016, 10:08 PM   #34
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
So when the door locks accidentally, is it the deadbolt or the upper door lock?
Mike
Caffeinated is offline   Reply With Quote
Old 08-01-2016, 10:23 PM   #35
2004 22' Safari
All of this advice sounds good, but I have only one key for the door of our 2004 Safari and although I've gone to hardware stores, locksmiths, online, etc. nobody can make a duplicate that works. Any ideas?
I was able to pick up blanks for everything for my 04 Safari from the Airstream dealer in Seattle and hand them cut at a local locksmith....... right after I managed to lock myself out
Northerngirl is offline   Reply With Quote
Old 08-02-2016, 04:56 AM   #36
teagues's Avatar
2008 20' Safari SE
Are you suggesting that he spent 17 years on ebay just waiting to lure in a sucker like me, so now he can drive down from Minnesota any time to steal my towels and dishes?!
Old 08-03-2016, 09:38 PM   #37
CruizinDux's Avatar
Tracktown USA , Oregon
Mike
I've read back thru this and other locked out themed threads, and haven't seen one lock or the other ID'd. Can anyone answer this?
I presume it isn't possible for both to accidentally lock?
CruizinDux is offline   Reply With Quote
Old 08-03-2016, 09:48 PM   #38
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
In my case, it was not the deadbolt.
Old 08-03-2016, 11:06 PM   #39
2004 22' Safari
The time I did it, it was not the dead bolt either.
Suspect I either accidentally slide the locking slide when exiting.... or my service dog who was in the trailer at the time decided to try and open it to see what I was doing outside by pawing the door lever (Which is how he has been trained to open doors with levers) and in doing so slid his paw over the sliding lock. The later is possible but not likely as he has never attempted to open a door without being asked to do so before or since.
Old 08-04-2016, 10:39 AM   #40
CruizinDux's Avatar
Great thanks SteveSueMac & NorthernGirl. It was hard to visualize how a DB could slide over on it's own but easy to see how the latch slide could.
Seems I read in the forums (somewhere) that someone when in camp, had cut a small section of foam (such as from some pipe insulation or maybe ensolite pad) and inserted it into the "slide opening" of the latch on the inside, then used the DB as security when they left. He would then remove it for the road and double lock with keys as usual.
I got the kit from AS dealer on So Cal but haven't installed it as looking in thru the slot and reading the instruction schematic, it appears our '14 already has the additional felt.
Meantime, I think I'll make arrangements with Trimark for a few more sets.
Old 08-04-2016, 10:57 AM   #41
richw46's Avatar
Lexington , Kentucky
For me it was the upper lock by the handle. It's very easy to hit that little slide with a finger when you use the handle to open the door. It's happened a couple of times but so far I've noticed it before closing the door. I usually have my keys with me but I keep a spare set in the TV.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-04-2016, 11:04 AM   #42
richw46's Avatar
This spring I was in Kissimmee, FL and I ordered the blanks. I went to a locksmith and he refused to use my blanks, had a big sign on the wall, wasn't very nice about it. He used his own blanks and 1 of 2 worked. I took my blanks to White's Ace Hardware in Davenport and they cut both keys, worked perfectly. They looked at the one from the locksmith, put it on their machine to see if it had some burrs on it, no luck.
So if you have your own blanks I suggest Ace or True Value hardware stores. Nice folk, good prices, no bad attitude.
-Rich
Rich & Yvonne
2004 4Runner SE
Locked Out finn2020 Doors & Locks 14 05-15-2012 12:44 PM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 11:20 PM
Locked out / How to get back in? empresley Doors & Locks 4 07-11-2006 11:35 AM
I'm Locked out!!! larry smith Doors & Locks 3 03-01-2005 06:52 AM
Locked out of Campground?!? Stefrobrts On The Road... 5 08-24-2003 01:30 PM
