Old 06-07-2017, 04:05 PM   #1
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Loading the Fiamma Bike Rack
After trying the four possible combinations of loading two dissimilar bikes on the rack, this seems to be the best solution. With the bikes this way, I can get both of the provided block clamps to have a good grip on the bars. There is some frame contact down near the axles, but I think I can cushion that with a piece of an old inner tube.
I still need to secure them with the provided safety strap, or some bungee cords. Has anyone come up with a slick solution for securing them on the rack?
Anyone have a neat solution to lock the bikes to the rack?
I was going to order a cover for the bikes to keep road spray off, but I think that would obscure the tail lights too much. Anyone, addressed that problem?
Randy
ID:	287051   Click image for larger version
Randy and Pat Godfrey
Region 3 1st VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-07-2017, 04:44 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Looks great!
I love and hate these bike racks at the same time, first thing is to pull the small plastic covers where the top tubes attach to the AS, make sure that the bracket is riveted/screwed right on the top of the seam and they are secured into the frame rib. It is important that this connection point is solid and check it often, if this part becomes disconnected, the bikes will fall to the ground and be destroyed.
I have seen people drill a hole in their rear bumper to run a lock cable though, but I just cable through the rack tubes, if in doubt do not leave the bikes on the rack.
vintagemotor is offline   Reply With Quote
Old 06-07-2017, 04:49 PM   #3
ShinyPete
ShinyPete's Avatar
Bushnell , Florida
Silver-
Looks good to me. Ours have ridden everywhere we've had our Pete since we bought him over 3 years ago. And we've never secured nor locked ours outside of the Fiamma straps you show in use.
We're on night 8 and about 1000 miles of a state park loop around NE Alabama and back down NW Georgia to home with no issues from the rack. I like it very much.
ShinyPete is offline   Reply With Quote
Old 06-08-2017, 06:54 AM   #4
Viera , Florida
Originally Posted by vintagemotor View Post
Looks great!
I had mine installed at the Airstream Service Center, and watched the process. I have a friend who had his installed by some amateur and what you described is what happened to him. I will be checking mine though just to be safe.
Old 06-08-2017, 04:19 PM   #5
Coast to Coast
Two Peas's Avatar
2016 26' Flying Cloud
St. Augustine , Florida
Agree the bikes are difficult to load properly and secure - and about the tailights too. I called fiama there is supposedly a tailight bar but could never get it ordered and finally dropped it. Their catalog also had a large safety symbol that supposedly is required in Europe. We had a custom cover made to fit over the bike tops so the tail lights are still visible. I also bought a lighted license plate holder and mounted it on the bottom bar and ran wires from the existing plate lights so it can be seen.
2016 26U Flying Cloud
2016 Tundra 4x4
Two Peas is offline   Reply With Quote
Old 06-08-2017, 06:12 PM   #6
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I elected to pass on the Fiamma on my 2017 AS and have been loading the two bikes into my full size F250 TV. But honestly it's a little bit of a pain. I'd like to hear pros and cons of the Fiamma. Thanks
VaTravelers is offline   Reply With Quote
Old 06-09-2017, 08:50 AM   #7
Las Vegas , Nevada
Pros:
Lightweight, bikes go on/off easy (once you set it up), ratchet tie downs, long adjustable tire rails, did I mention it was lightweight?
Cons:
Installation, attachment location, drilling holes in your AS, blocks emergency exit window, blocks tail lights, blocks rear cargo compartment, very low maximum carry weight (no E-bikes), the top rack tubes are attached with the smallest bolts possible.
This is a great bike rack for most and not for some, if that makes any sense.
When I was in Jackson Center of the Universe, I asked why they don't offer a small class I receiver to put in a Thule or Yakima hitch rack and they almost excommunicated me, "Installing a receiver to the rear bumper immediately voids the warranty".
Old 11-17-2017, 04:44 PM   #8
2003 28' Classic
Rural Hall , North Carolina
I know this may not be practical but if you are in the market for a new tow vehicle, check out the Dodge Ram with Ram Box features. Inside the bed on each side come with racks which adjust (knobs) so you can easily transport two or more bikes inside the bed along the sides. I use bike tubes and giant twist ties to secure and a cable to lock. Also I have installed a tailgate pad to fit bike front tires over the top of the tail gate (pads fasten to down tubes). I can carry 4-6 bikes but towing is dicey because tight turns will catch the wheel on the propane cover. Cheerio! Jim
bikerjames is offline   Reply With Quote
Old 11-17-2017, 05:04 PM   #9
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
This is the 3rd of 4 AS's we have had with the Fiama. We used to carry the bikes in the back of our Tahoe, then on top. What a pain. The Fiama is good and bad, as noted. Your pictures look like what we do. We also just run the cable lock over the Fiama rails. When stopped for more than a night, we typically unload and lock bikes to bumper. No real difficult issues for us. I think Fiama is about as good as you can do without a custom rack of some sort.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 11-17-2017, 05:49 PM   #10
aftermath's Avatar
Spokane , Washington
I like our Fiama carrier. Once you figure out how to get them both loaded on, they tie down nicely. We use the safety strap which gives it some additional stability and we tie it in to the rack itself. If something breaks, the bikes will not go down.
I also lock mine with a cable that goes over the rack.
One of the big cons, at least for some folks, is that the forks will rub together. I probably should have protected them with some foam or rubber but I didn't. We now have scratches that are visible but they don't bother me in the least. These might really kill others, especially if you have a very nice expensive ones.
aftermath is offline   Reply With Quote
Old 11-18-2017, 06:17 AM   #11
Viera , Florida
To keep the forks from contacting each other and scratching, I put a piece of old inner tube over one of the forks on each bike. Pretty easy to install and remove with quick-release hubs.
Old 11-18-2017, 06:18 AM   #12
Viera , Florida
...front forks....
Old 02-02-2018, 09:31 PM   #13
2018 27' International
Somewhere it snows , Ohio
Sorry to hijack this thread but there are some very knowledgeable people on here so maybe someone will answer my question. This is regarding the two mounting blocks (tube grippers) on the Fiamma. The long one on my rack rotates near the end like if the block is your hand, the rotating would be like rotating your wrist.
The problem is that my smaller mounting block will not rotate from the horizontal to vertical position. The dealer says that it will rotate if you really twist it. I am afraid the red plastic will break.
Has anyone seen this extremely tight "wrist" on their mounting arm?
Airdream99 is offline   Reply With Quote
Old 04-18-2018, 10:03 AM   #14
Howell , Michigan
tight mounting block
Mine was that way also. it was very hard to rotate but it does rotate if you work at it. Work it back and forth and it will finally loosen up.
jcrango is offline   Reply With Quote
Fiamma Bike Rack for a 27 Classic DennisL Member Introductions 2 03-09-2014 09:31 AM
Fiamma Bike Rack kscherzi General Repair Forum 4 02-08-2014 08:49 AM
How to attach Fiamma bike rack to 19ft bambi Whitewater99 General Repair Forum 2 07-25-2013 05:49 AM
2010 Airstream International Signature 23D Travel Trailer WIth Fiamma Bike Rack eBay Watch Airstreams on eBay 0 05-27-2013 03:30 PM
EB Fiamma Bike rack StagrLee Eddie Bauer - All Models 2 05-08-2013 06:05 PM
