Old 12-12-2013, 01:04 PM   #43
Lily&Me's Avatar
Normal , Illinois
Originally Posted by Wanderingjee View Post
The picture below is my mobile laundry setup that I now use almost exclusively.
The smaller of the two is the Wonderwash. To operate, I put a few articles of clothing in there (pair of pants and a couple of shirts), 2 gallons of water and a teaspoon of laundry soap. Put that cap on it and crank it for 3 minutes. Then I drain the water and do it again with clean water to rinse. Sometimes twice.
The second device is the 120v laundry spinner. This enables me to spin the excess water out of the clothes so that they dry quickly. On a warm day, clothes will dry after the spinner in about 20 minutes.
I usually stay on top of my laundry and I can have it all hung up in about 30 minutes start to finish.
Huh! Pretty clever!
What I miss most when we are gone from our stick house is the washer/dryer and, in good weather......the outdoor clothesline.
Maggie
Old 12-12-2013, 01:13 PM   #44
Wanderingjee's Avatar
1973 Argosy 26
St David , Arizona
I did this in a pinch the other night. Hanging the clothing near the woodstove had them dry at some point while I was sleeping. It was 28 degrees outside and I needed those for work the next day and forgot during the day.
Wanderingjee is offline   Reply With Quote
Old 12-12-2013, 01:17 PM   #45
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by DKB_SATX View Post
Perhaps something is wrong with your 6-gallon water heater. If you start with a hot tank, and pull 2 gallons of hot water 3 minutes apart (assuming you rinse in hot), by the time you have those close spinning in the spinner gadget and are ready to wash another load in your manual agitator tank, you should have enough hot water to wash the next load.
I'm inclined to agree. A dual-mode propane/electric 6-gallon Atwood XT will make 6 gallons of hot water in about 5 minutes on propane alone, or in 9 minutes on electric alone, or in just 3 minutes if you use both the electric and gas heating elements at the same time. Based on Atwood's product literature, at least.
AND, the Atwood XT water heater produces scalding temperatures, so it includes an integral mixer that adds half a gallon of cold water for every gallon of hot, so a 6-gallon water heater produces 9 gallons of not-scalding-but-plenty-hot water before it runs out of hot water. If you routinely use 9 gallons of hot water in less than 3 minutes, then I can see where you might run out of hot water, but otherwise you should never run out!
The Atwood XT didn't exist in 1973 when your Airstream was built, but installing a new one, which is a drop-in replacement for the older Atwoods, would be easier than a flash heater that has different dimensions.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-12-2013, 01:20 PM   #46
1973 Argosy 26
St David , Arizona
There is also the issue of the pilot light. I hate the idea of burning gas all the time. It is an internal flaw with me that prevents me from allowing it. I am most certainly a prepper and burning that fuel when not in use just kills the prepper in me.
I am completely off the grid so there is no dual mode for me.
Old 12-12-2013, 01:20 PM   #47
Lily&Me's Avatar
Normal , Illinois
Are you a fireman? Those look like fireman britches.
For many years, I handled laundry for myself and 2 children (including the old-fashioned, cloth diapers) with those stacking washer & dryer mini units....the washer that you wheel to the sink and attach, etc.
I had the washer for several years before I had the dryer, too. I hung all our clothing on a wooden rack, and did laundry about every other day.
The little washer spun things remarkably dry, and a good shake out before hanging would remove wrinkles.
Whatever works and gets ya thru the day, I say.
Maggie
Old 12-12-2013, 01:22 PM   #48
1973 Argosy 26
St David , Arizona
Yes Maggie, I am a firefighter/paramedic.
Lieutenant Michael King to be exact.
Old 12-12-2013, 01:27 PM   #49
Lily&Me's Avatar
Normal , Illinois
Awwwww.......nice picture!
Stay safe out there.
Maggie
Old 12-12-2013, 01:27 PM   #50
Newer models have spark ignition, no pilot light.
WBCCI #1105
TAC LA-4
Old 12-12-2013, 01:29 PM   #51
1973 Argosy 26
St David , Arizona
Can I keep them off until I need them so that the water isn't always hot?
Old 12-12-2013, 03:14 PM   #52
Mine has remote switches (one for electric, one for propane) on my control panel, up and to the left of the tank level monitor.
So that would be a "yes." You can leave the water cold until about fifteen minutes before you need the hot water, when you turn on whichever heating element(s) you want to use.
WBCCI #1105
TAC LA-4
Old 12-12-2013, 03:28 PM   #53
1973 Argosy 26
St David , Arizona
Mine has nothing of the sort unfortunately. Sounds like some research is in order here.
Old 12-12-2013, 05:08 PM   #54
nilesrob's Avatar
Marietta , Georgia
Images: 12
Great story, great looking rig, awesome plans it sounds like! Ayn Rand would be proud.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 12-14-2013, 07:28 AM   #55
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I agree on the hot water with Protagonist. I am full-time and get more than "dusty" working in the oilfield. I suffer no loss of comfort with a modern elec/propane water heater (nstall with an accummulator).. I do recommend a better soap, as well, for rinsing takes most of the water after all. Try DR BRONNERS liquid. Also makes shower clean up easier. And, look to in-line water softeners (lady friends comfort; on my future list) to also reduce water demand.
Old 12-14-2013, 07:34 AM   #56
dznf0g's Avatar
Oswego , Illinois
X2 on the softener. It also helps keep those lime and calcuim deposits away from the whole system. I chose this one for its storage ease. I installed an additional sewer hose tube and store it there. Works well.
Water Softener | Amerisoft-Compact PortaGold 200 In-Line Mobile Water Softener: SmallSpacesAppliances.com
-Rich-
