Old 04-06-2015, 12:47 PM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Leveling Tandem Tools
So, we have a tandem axel trailer and have had it now for 1.5 years or so...and now realize that there are situations where we need to raise up the low side of the trailer quite a bit to make things level...luckily over the weekend my AS neighbors had these little ramps:
Ramble RV Levelers, Set of 2 - Four Corners D10-171 - Chocks & Levelers - Camping World
So what I did was use the two ramps, pull up enough onto them, wife carefully inserted the 4 stacked high lynx leveler blocks in between the two tires on ground, then rode onto both stacks of level blocks for both tires...
Then I used ground chocks on the other size and pounded those in tight with a hammer...I did not have the x-chocks, or rotochocks, or whatever brand to use on the other side unfortunately, did not have a problem, but makes me worried to think much about it really.
Anyway, at first I thought for a moment:
"well Ill just level up using one of the tires/axels! I have 2 bags of these level blocks, should be able to do it."
...but my AS buddies said its a bad idea to leave it up like that over the weekend on a single axel...thus the route we took.
That got me to wondering...how many blocks high until I should do the same for both tires? Come to think of it, I suppose it should be for both tires all the time?
If it were a single axle, it would be easy enough, but getting both on the same level seems tricky when leveling in a relatively more extreme situation.
I feel the best option for me is to simply buy these leveling ramps and ride up on the blocks as I did last weekend, then get those tandem wheel chocks...
I searched the forums and found little on this subject surprisingly...which made me wonder if I flubbed the search parameters.
Anyway, wanted some input from the experienced folks on here before I spend more money on more leveling stuff.
PharmGeek is offline   Reply With Quote
Old 04-06-2015, 01:26 PM   #2
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I am not sure if this is answering your question or not, but we use the Anderson Levelers for both tires on the side needing leveled. Merely put them in front or back of each tire and pull/back up on them. Get about 4 inches of adjustment equally on each tire and the put the wedge that comes with them in. The chock tires and you are good to go. If need more that four inches raised, a piece of wood or the logos can be built up and then put the Andersons on it. It's quick and easy. I level quickly by myself all of the time.
silverlabs is offline   Reply With Quote
Old 04-06-2015, 02:36 PM   #3
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Somehow I worry those Anderson's would not hold up...how long have you used them?
Old 04-06-2015, 02:38 PM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
They hold up and they're great. These things are pretty solid. Best investment to date. No lego blocks for me. (Admittedly I haven't had mine that long, but I mean they're solid ABS plastic, going to last a long time)
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-06-2015, 02:39 PM   #5
SteveH's Avatar
Common Sense , Texas
I use the Andersens also with our 10,500lb 34, and have been using them for about a year with good results. They seem to be holding up just fine.
Regards,
Steve
Old 04-06-2015, 02:46 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The Anderson's seem to be the only all in one solution for the tandem axels
Do you all think once they are chocked they are solid?
I guess if boondocking on softer ground you can still use them with something else to sit on like my lynx level blocks
Old 04-06-2015, 02:52 PM   #7
silverlabs's Avatar
Waxahachie , Texas
I have used them for about a year during which we traveled basically three to four months all together. Hold up very well. When you put the chock under Anderson when lifted, very solid. I still use tire chocks between tires too. On softer ground, use the linx blocks as base. Suggestion is to always pull your trailer connection from TV so your trailer brakes won't be engaging when backing, if backing on them so the tire rolls up on them freely.
Old 04-06-2015, 02:54 PM   #8
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Among other jobs I ran a plastics company, ABS was one product we worked with the Mississippi EPA or whatever they were where we had two plants told us "plastics have a half life of 125,000 years; my engineers said "probably right", so the Andersons should work out ok.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-06-2015, 03:07 PM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I try to live by the KISS rule ( where I'm the last "S"). I use a couple of pressure treated 2 x 6's cut 2' long and a couple of shorter ones. I drive up onto them and they solve about 80% of my leveling needs. For the times I need more I made some blocks out of 3/4" plywood and 2x3's. The plywood cut 5" wide and about 2.5' long with the 2x3's vertical and plywood top & bottom. 2 of them interlock and form a platform 5" wide and 5' long approx. ( length is custom made) to drive up on when I need more height. These store easily in the pullout bumper compartment on my AS. I use the short 2x6's to form a ramp to pull up onto. So far I have not run into any situation needing more adjustment than I can make with these.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-06-2015, 03:59 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Another vote here for the Andersen's, Pharmgeek. Yes, you want to lift both tires on the low side and the Andersen's couldn't be simpler or more accurate with up to 4" of lift. There's a special chock that comes with them to slide under the other side of them and they are rock solid.
5 out of 5 stars from my perspective.
Old 04-06-2015, 04:02 PM   #11
Gainesville , Florida
I use either the Legos or wood, whichever I pull out of the truck bed first. Jim
Old 04-06-2015, 04:17 PM   #12
1976 31' Sovereign
Oswego , Illinois
I use 2x8 painted blue [easy to wash dirt off], short pcs. under stabilizer jacks and aluminum stand for power jack, longer to support both wheels, heavy rubber chocks that semi trailers use, you will not be able to pull over them, & they are not exp. I tow with pickup so no hassle stowing them. Bill
Old 04-06-2015, 05:34 PM   #13
W , New England
Here's a pic showing the other part of the chock. If I had needed to, I could have driven further forward to catch more of the curve and get up to 4" of lift - then those other parts on the left side sort of slide under and make a solid chock. Couldn't be easier!
Name:	ImageUploadedByAirstream Forums1428363183.512606.jpg
Old 04-06-2015, 07:06 PM   #14
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Would just need to find 90 bucks (2x 45 each) - ouch
We are broke for like the next year - after that funds free up significantly
I may for now find a way to fashion a couple of DIY wood ramps to get me onto my Lego blocks- ideas ?
Those Anderson's look like what I will want eventually!
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
Tools, Tools, and more Tools FC7039 General Repair Forum 36 03-14-2008 03:39 PM
towing tandem with an airstream wvabeer Towing, Tow Vehicles & Hitches 12 09-27-2005 12:01 PM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-30-2004 11:25 PM
'70s Globetrotter tandem? 85MH325 Airstream Trailer Forums 8 04-16-2004 09:00 AM
