Old 04-10-2015, 08:08 AM   #57
z , North Carolina
I'm with you pacieman. I just ordered a set myself. Hope they work.
I see they use a patch of rubber or something under their tire lift. I wonder if glueing a piece of an old rubber doormat or someting similar to the bottom would help with the sliding on concrete? Anyone try that with the Andersen levelers?
FishinHatteras is offline   Reply With Quote
Old 04-10-2015, 08:21 AM   #58
dznf0g's Avatar
Oswego , Illinois
I cut a couple pieces of rubber flooring for a barrier between concrete and gravel and the Andersens. The rubber also works for sand and soft wet soil, to lay down a couple of legos as a base and them roll up on the Andersens with the rubber between.
Regular, relatively firm grassy (or bare) ground is not an issue at all. Sand and recently hard rained on ground can be an issue.
Having a tandem, I went from having to carry 3+ sets of legos to <1 set and the Andersens. Saved a lot of space in my bumper drawer....and is a lot easier and quicker to set up.
-Rich-
Old 04-10-2015, 08:30 AM   #59
2015 25' FB International
Toano , Virginia
Originally Posted by zigzagguzzi View Post
I use either the Legos or wood, whichever I pull out of the truck bed first. Jim
Same here and it's a fool proof system.
StreamTime is offline   Reply With Quote
Old 04-10-2015, 09:02 AM   #60
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Fishing, I have not seen a reason to do that. The only time I have had one slide was operator error. I do carry 2 2X8s for soft ground support if needed.
MICHAEL
Old 04-24-2015, 02:35 PM   #61
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I just ordered a couple of the andeso levelers...
I will report back in he coming months as have a few trips planned and will see them in action, including I think on sand/gravel.
PharmGeek is offline   Reply With Quote
Old 04-24-2015, 03:23 PM   #62
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I knew if you sold enough of those drugs....
We recently used someone else's advice while at a dump station and drove completely up on them on the opposite side, tilting the Airstream a little. Honestly, these look pretty cool compared to lego blocks, IMO.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-24-2015, 04:03 PM   #63
AWCHIEF's Avatar
Images: 33
His drugs are free to qualified Veterans.
MICHAEL
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
Tools, Tools, and more Tools FC7039 General Repair Forum 36 03-14-2008 03:39 PM
towing tandem with an airstream wvabeer Towing, Tow Vehicles & Hitches 12 09-27-2005 12:01 PM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-30-2004 11:25 PM
'70s Globetrotter tandem? 85MH325 Airstream Trailer Forums 8 04-16-2004 09:00 AM
