Old 04-07-2015, 11:21 AM   #29
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
LOL Where is that like button?
MICHAEL
Old 04-07-2015, 11:23 AM   #30
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by PharmGeek View Post
Stevesuemac...let me clarify:
I have only stacked them straight up without a pyramid last weekend when I used my neighbors ramps they have...which conveniently fit between the two tires as well..pull up a bit, then insert the stacked lego blocks and was able to easily roll onto the stack.
Without the ramps, pulling onto them is I presume near impossible..or at least a bad idea.
I know how to pyramid them, and had done that, but that only lets me do one wheel...and when doing 3-5 high, it is (I think) impossible to make two pyramid stacks...although now that I think about it, I suppose its possible to make like two overlapping pyramids...hmmm....I think I would need like 10 more legos to make that happen, lol?
Yup! You got it!
Old 04-07-2015, 01:00 PM   #31
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Oh kiss it hahahahaha
PharmGeek is offline   Reply With Quote
Old 04-07-2015, 01:09 PM   #32
Goal15's Avatar
Dallas , Texas
I'm sure I may get excoriated for heresy or something to that effect, but the one time that I have needed to use my Lego-like levelers, I just put my x-chocks between the tires on the opposite side, took my Tundra jack and put it on the channel iron behind the two wheels I needed to raise and jacked until I could slip the Lego-like levelers (lll) underneath the tires.
I do realize that this might work fine for my 23 but perhaps not bigger AS
We seldom encounter a state park or COE site that requires this amount of leveling.
You do have a bottle jack don't you Pharm? No additional expense required.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 04-07-2015, 01:59 PM   #33
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You definitely should be leveling both tires the same amount though this could change with the grade of the site. Sometimes it is one side, other times it could a one axle.
I really like the concept of the Anderson levelers. Maybe sometime in the future.
For now I have a single set of lynx levelers that I rarely use.
I have a milk crate full of 2x8's with a 45 degree cut on one end along with a few pieces of 1/2 inch plywood for fine leveling. There are shorter and longer lengths so when the trailer gets high the short lengths will fit between the tires.
Campgrounds can get hilly here in KY, I think I have had one side of the trailer 8 inches or so off the ground. Put the truck down in low range makes this much easier.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-07-2015, 02:16 PM   #34
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I must have just been "lucky" in almost always having to use 2 or 3 layers of lego blocks to get the low side up...probably in the last 1.5 years of my first RV experience, over half of the time I needed a good bit of raising of the low side....I had 3 times the level was too far off to get it level, and I just lived with a bit off camber (may have been in my head, but I think it caused me to sleep terrible).
I do have a bottle jack, but only a small 2T variety....not sure what possessed me to get that smaller one vs. a 4 or 5T model....
I will not attempt to imagine the possible downfalls of using a jack...besides jacking it up on axles and damaging them...or weight of the thing getting up then shifting? which seems unlikely while hooked up?...ill wait to hear the excoriation I guess.
Old 04-07-2015, 02:17 PM   #35
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
btw..I never would have thought about turning off the trailer brakes.....seems like an excellent tip.
Old 04-07-2015, 03:43 PM   #36
AWCHIEF's Avatar
Images: 33
I have been very satisfied with my purchase of the Andersen levelers. Much simpler to use than quessing how many legos to use. Using the supplied small chocks they are rock solid and secure. Worth the 80 bucks in my opinion.
MICHAEL
Old 04-07-2015, 03:44 PM   #37
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
For those interested in the Anderson Camper Leveler, please read the negative customer satisfaction results on the Amazon site. I'm sticking with my wood 2X8s.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 04-07-2015, 06:51 PM   #38
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Carver I read them - some breakage reported....however all in all very few negative reports
I'm sold on the Anderson levelers - is xchock type thingies really necessary with them?
Old 04-07-2015, 06:52 PM   #39
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Although I'll probably wait till birthday or Christmas and ask for them
Old 04-07-2015, 06:55 PM   #40
W , New England
One guy's $0.02 - yes. The levelers only level. I use something different than x-chocks but definitely apply additional "stabilizing" beyond just dropping the stabilizers (those don't fully dampen forward/backward motion where x-chocks and others do exactly that).
Everyone's mileage varies.
Old 04-07-2015, 07:48 PM   #41
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I meant to ask if without that type do you worry the trailer could come unchecked from Anderson's
I do understand the stabilization benefit of those...
Old 04-07-2015, 08:22 PM   #42
W , New England
No I don't worry about that with the Andersens.
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
Tools, Tools, and more Tools FC7039 General Repair Forum 36 03-14-2008 03:39 PM
towing tandem with an airstream wvabeer Towing, Tow Vehicles & Hitches 12 09-27-2005 12:01 PM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-30-2004 11:25 PM
'70s Globetrotter tandem? 85MH325 Airstream Trailer Forums 8 04-16-2004 09:00 AM
