03-24-2014, 11:56 AM
Spokane
Leveling Just One Axle
During the last year I have seen a couple of different cases where people level a double axle trailer by placing blocks under just one of the tires. It looks rather odd and as a matter of fact this is what caught my eye. Other than being easier, is there a good reason to do this? And, perhaps more importantly, can it do any harm?
I just saw a thread on a SOB forum and no one seems to know if it is damaging or not. One person said something about it being OK for regular axles but not so good for the torsion types. Any enlightenment would be appreciated. I am specifically looking for the prospect of damage.
03-24-2014, 12:20 PM
I'm In
, Kentucky
Was the other axle just dangling in the air or was it more like on uneven ground? Seems to me that if you put all of the weight on just one of the axles it would be putting a pretty good strain on it. I've read in these forums that it's not even good to use those blocks to raise up one axle to change the tire, you should use a jack at the proper lifting point to avoid any damage.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
03-24-2014, 12:38 PM
Princeton
, New Jersey
Leveling the axles unequally is not a problem for a short period, the weekend. It is not a good idea for longer periods and the rubber in the axles will take a set over time.
With that in mind you want to store the trailer Parallel to the Ground it is stored on rather than level. If it is parked in your drive on an incline you can run the jack up or down to level it the day or so before you go out to load and start the frig.
2004 Excursion 4x4
03-24-2014, 01:00 PM
Spokane
Rich,
The second tire was still in contact with the ground. The first tire was up 4 or 5 inches and the whole set up looked rather strange.
If doing this stresses the axle, I don't think it would matter if it were 1 day, 2 or 7. And no, this trailer wasn't in storage.
03-24-2014, 01:03 PM
1986 31' Sovereign
Miami
Certainly standing on one leg puts more weight on the blocked axle but I can't imagine it is a big deal in the short term as there are no shock loads when you are parked. As noted above, I wouldn't leave it that way all winter...
As for not pulling the trailer up on blocks to change a tire, most of us do it all the time either to do the brakes/bearings or to change a tire. Heck, I've towed my trailer (as per the owner's manual) on three wheels for a few miles (off a limited access highway to the nearest tire store). Got some funny looks but no problems doing it.
These rigs really are tough and capable.
Mike
03-24-2014, 01:53 PM
1995 30' Excella
Bowie
, Maryland
We've never done it, but I've been tempted on some sites that very off-level front-to-back. Fortunately I've so far always managed to pull off "levelity" (a word my wife coined this weekend) with just the tongue jack, possibly with some extra blocks under the jack.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
03-24-2014, 01:59 PM
2002 22' International CCD
San Luis Obispo
Skater,
Yes, my wife invents words, too. "Levelity" is related to the word "levelization", which is the process of achieving levelity. Makes life interesting, doesn't it?
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
03-24-2014, 03:02 PM
Princeton
, New Jersey
As the load increases on the loaded axle the other wheel will drop. The net difference of 4 or 5 inches is the result. This is not a problem for a short period, a weekend or changing a tire.
The important thing to remember is the relationship when storing or prolonged parking. Even if unused for a period of time this type of axle will take a set. When I bought my trailer, and it was only 3 years old, it had sat in Fl. for that period. The axle were shot with less than 1,000 miles on them. The rubber rods in the axle tubes needs to be flexed.
2004 Excursion 4x4
03-24-2014, 06:12 PM
Spokane
Thanks for the input. I don't think I will be doing this on a regular basis. We will continue to "levelize" using the process we usually do.
03-24-2014, 06:53 PM
2002 25' Safari
Dewey
We use the orange levelers which are 1" each. Sometimes we will use one additional leveler on one axle to get it "just right". There is never more then 1" difference between axles.
Richard
03-24-2014, 07:06 PM
2012 25' Flying Cloud
Battle Lake
A driveway I sometimes use at home is inclined down front to rear, but level sideways. When parking there for some time I put blocks under the rear tires to level the front and rear axles, presumably to equalize the weight on each axle.
This can be tricky with standard chocks because they don't fit snug under the rear tires, so I chock the front tires and use X-chocks as well. Many options but secure chocking is important on inclined parking.
Doug and Cheryl
03-24-2014, 08:50 PM
2002 30' Classic S/O
Fleming Island
Why is this?
If on inclined ground one uses different height blocks under the wheels to level the axles left to right and front to rear and the tongue jack to level the trailer front to rear it would seem that the trailer doesn't know that the ground is not level. Why then would I want to park the trailer parallel to the ground?
I think if one draws a force and moments diagram it will show that when parked parallel to inclined ground there is more weight and also lateral loads placed on the lower points than when parked on level ground.
If I'm mistaken please set me right. I need to understand this because my driveway is not level left to right or front to back and I'm leveling when I park.
Al
03-24-2014, 09:17 PM
Central
, Mississippi
Originally Posted by Al and Missy
?..it would seem that the trailer doesn't know that the ground is not level...
Al
It doesn't matter to the trailer, but the fridge cares...it likes level.
I think the point is, use blocks under the axles in small increments to get the stuff level sidetoside, then use the tongue jack for fronttorear
03-24-2014, 09:18 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
If one wheel is in a pothole, leveling the ground, i.e.: one axle, seems to make sense for a weekend camping trip... Of course it would be easier with a short to mid-length trailer to just move the unit forward or backward a couple of feet. I've never had that situation. I use the orange blocks and frequently I've found that there was two inches OFF from side to side, even on some slabs. I'd bet that the slabs were level when laid, but many seem to be laid cheaply so the slab heaves and often breaks due to tree root growth and freeze and thaw cycles.
I changed from 15 inch t 16 inch rims by lifting one axle at a time until the other one was off the ground.
I feel that it's safer to use the blocks to ramp up a wheel than have the trailer fall off of a jack (saw THAT happen once. Ugly.) In addition to the flat blocks I have the integrated chocks which can lock the wheel in a pretty secure cradle. It also feels safer to change tires with the tow vehicle hooked up.
I'd never leave one tire dangling in the air for longer than it took to change a tire or do other maintenance.
Paula
03-24-2014, 10:34 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
The same for us ...parking inclined both fore/aft and side to side ...
03-25-2014, 05:56 AM
1995 30' Excella
Bowie
, Maryland
The slope may be intentional, to allow water to run off. I asked our concrete guy about making ours level side to side, and he wouldn't warranty the work if I demanded that (and front-to-back slope would have been a bigger problem). I guess water pooling and potentially ice is a major issue with concrete. So our parking pad is off side to side a bit - one orange block under the low side actually takes it a bit too far in the other direction.
03-25-2014, 07:07 AM
2004 30' Classic Slideout
Fenton
, Missouri
I use the orange blocks also for leveling. The important thing when putting something under a tire is to make sure the entire tread or footprint of the tire is supported. It is possible to damage a tire by allowing part of a tire to remain unsupported. I went to a RV tire seminar years ago and this was brought up as an issue that could damage the belts.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-26-2014, 08:12 AM
I'm In
, Kentucky
Tires should be off the ground during storage
Jack
Tires should be off the ground during storage:
Store the vehicle such that all weight is removed from the tires.
Cooper Tire & Rubber Company - Storing Tires
Ideally, a vehicle in storage should be placed on blocks to remove all weight from the tires.
Tire Storage - Goodyear RV
Don't store a vehicle with weight on its tires for extended periods of time. Long-term inactivity is more harmful to tires than weekly drives that flex the tires and help maintain oil dispersion within the rubber compounds.
http://www.tirerack.com/tires/tirete....jsp?techid=37
If tires are on vehicle, store on blocks to remove load from the tires. Maintain placard inflation pressure.
Tire Storage | Michelin Tires
Remove the vehicle's weight from the tires (put vehicle on jack stands)
Bridgestone Commercial Truck Tires
-Rich
Rich & Yvonne
