Old 02-09-2003, 10:12 PM   #1
APB
APB's Avatar
Escondido , California
Leveling a trailer
I'm new at this trailer stuff but did pilot a '36 ft motor home for a number of years. As a result of that experience the thought of using blocks to level dual axels is not thrilling.
Has anyone used a hydraulic jack?
Seems like you could put it under the jack point or the frame near the axle and level up much quicker than messing with blocks and such.
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Old 02-10-2003, 04:18 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
APB
After learning how to level our 28 ft MH that has no hydraulic levelers and having owned 2 dual axle Airstreams I long for the good old days!
The dual axel leveling is easy beacuse you have 2 close points to lift. They usally need to be lifted the same amount. I used Lynx levelers when I had a trailer and just guesstimated the lift I needed to get the trailer level side to side. If your unit has one of the large exterior levels the scale seems to indicate a 1-2 inch lift per mark off of level. The front to back is easy to do with the tongue jack. IMHO compared to a MH, a trailer is a cinch!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-10-2003, 08:04 AM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
the learning curve
once you figure it out, it is much faster than getting the a hydraulic jack out. Just set your blocks in place and drive up on them. Piece of cake.
Smily
smily is offline   Reply With Quote
Old 02-10-2003, 08:10 AM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
It's not rocket science
With modern refrigerators, if it looks level, it is probably level enough for an overnight stay. For longer periods, I take a little more care. I have a big level on the front that I can see from the driver's seat and a small level on the side for fore-aft levelling with the tongue jack.
I also use Lynx levelers and/or the yellow ones that Camping World now sells. If the trailer is near level, I may only put a block under one wheel of the pair.
The big thing is that when you use blocks, chocks are ineffective at the best and often impossible to use. I have one of the expanding between-wheel chocks that goes on whichever side has levelling blocks in use. On the side that is on the ground, I use chocks.
John W. Irwin
WBCCI #9632
Old 02-10-2003, 11:43 AM   #5
1975 31' Sovereign
Drasco , Arkansas
Send a message via AIM to BILLY SPIER Send a message via Yahoo to BILLY SPIER
NICE TO SEE YOU ARE A BLUEGRASS FAN BILLY
bdbluegrass
BILLY SPIER is offline   Reply With Quote
Old 07-10-2003, 05:23 AM   #6
Silvertwinky's Avatar
South Shore , Kentucky
I think leveling a trailer is one of the easiest things to do when camping.
Our previous trailer sat lower on one side and now after reading a lot on this forum I realize that I had bad axles. Anyway, it always bugged me that most of the time whenever we'd pull into a campground that it would be consistently low on the same side.
I try and keep a treated 2X6 or two handy for leveling one of the sides if needed and just drive up on that when I know where I want to position the trailer. Also, as John stated I use the chocks that lock between the wheels. Most of the time, I just try and find a level spot to pull into and rarely even need to make an adjustment for the sides anymore. When it's level from side to side, I adjust the power jack up front until its level from front to back watching the level indicator on the front of the trailer.
Works like a charm!
Crank down the stabilizer jacks and you have it.
Visit our church on the web!
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Old 07-10-2003, 05:31 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You gotta be careful if you use jacks because even the factory mounted stabilizer jacks can torque the frame. At the midwest rally, Jack showed me the proper settings. The way I was doing it was making the door harder to open and close (not that it wasn't already hard to start with--needs adjustment).
I use a few 2x6 boards and roll the trailer on them to get it as good as possible and then use the stabilzer jacks to lighten the bounce when done.
Eric
Old 07-10-2003, 05:36 AM   #8
I agree with you silvertwinkie, the stabilizer jacks shouldn't have very much weight on them!
Bill & Donna
Old 07-10-2003, 05:41 AM   #9
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Bill, I think it's a conspiracy. I have noticed that whatever campground I'm in, and whatever site I have (including my own driveway) the door side and the front of the trailer are ALWAYS low. And no, it's not the trailer; my axles are just fine. They just ALWAYS slope that way. I swear that even in the same campsite, if I turned the trailer around, the slope would change to the front curb side with the trailer, so that when you're done levelling, the doorsill is STILL always three feet off the ground! You have to either be Superman and be able to fly, or use a 6' stepladder to get in!
The Grassy Knoll, UFO coverups, Watergate, and now the Great Campsite Slope. Conspiracies All!!!
Roger
Old 07-10-2003, 05:43 AM   #10
Aluminut
2004 25' Safari
. , Illinois
Man there is a sea of twinky/twinkie on the forum this morning...we both have been busy.
Eric
Old 07-10-2003, 05:50 AM   #11
Twinkie, yep we have!
Roger, I just kept trying to convince myself that it wasn't the trailer and that it was just a coincidence all of the time!
After the trailer was gone and the newer one came along it appears level all of the time now so it must have been the trailer, I guess!
Bill & Donna
Old 07-10-2003, 06:48 AM   #12
Pahaska's Avatar
Hays County , Texas
Another reason for levelling
If I am staying long enough to use the shower, I am a lot more concerned about getting the shower floor level side to side than I am the refrigerator. The shower floor is essentially flat, so if I am curbside-low, I end up having to use my foot to sweep water over to the drain. Much easier when level or a little bit streetside-low and it drains by itself.
If the trailer is nearly level, I may put a block under just one of the tires on the curb side to insure good shower drainage.
John W. Irwin
WBCCI #9632
Old 07-10-2003, 07:07 AM   #13
Aluminut
2004 25' Safari
. , Illinois
I've been talking to many techs about the fridges these past few days. I can tell you this much..... each and every repair shop person I spoke with and the website that was posted on the fridge issues threads all say the same thing. Fridges that are not leveled will fail. It may take years, but they will fail before they should. I'd be concerned about both aspects. The one aspect would be a more costly repair.
Eric
Old 07-10-2003, 07:37 AM   #14
Pahaska's Avatar
Hays County , Texas
Eric
Most of that is a relic of the past when levelling of the older refrigerators was super critical.
We had a talk a few years ago from a Norcold rep who said you could put a tire up on the curb and the refrigerator would not be harmed. Dometic says that if you are comfortable in the trailer, the refrigerator is fine. Those are the folks that write the warrenties and I'll trust their judgement.
Most all refrigerators will fail in time; they are loaded with a corrosive fluid and constantly temperature cycled. The thing is that those repair shop techs really have no idea why a specific refrigerator may have failed. Much easier to just blame it on levelling.
John W. Irwin
WBCCI #9632
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 12:15 PM
