Old 07-11-2003, 09:44 AM   #29
1975 29' Ambassador
Reno , Nevada
re "Am I the only one where EVERY surface in my refrig. is a different level"
This is a good question as there is no pad on a fridge that says "level me" that I know of.
From what I can tell, the floor of the freezer compartment is the best solid referent. It should be firmly affixed to the frame and the frame should be the fundamental reference for the cooling parts.
If the floor of the freezer compartment is level, you should be able to put a level on the edge of the door and swing it back and forth and stay level, too. Any other solid, attached to the frame, parts should also be plumb horizontal or vertical, too.
Old 07-11-2003, 10:02 AM   #30
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I use my circular bubble level in several areas of the refrigerator and freezer. You evenutally will come upon some commenality in spots any of which then are usable as the point to level from.
Jack
Jack Canavera
STL Mo.
AIR #56
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 12:15 PM
