Old 10-16-2006, 01:56 PM   #1
HHP
HHP's Avatar
Yucca Valley , California
Question Level Master Help
Greetings Honorable Airstream Owners:
I have this model level master on my AS, the side to side works well, but the front to back level seems to go out of alignment by the time I get to my destination.
I cannot find the manufactures website to see if there is a way to keep the front to back adjusted.
Anyone have a way to keep the front and back level, level?
Thanks!
HHP is offline   Reply With Quote
Old 10-16-2006, 02:06 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
My dealer refused to install it. I am glad. I did not want any holes in my baby.
I use a standard 2 foot long leve inside the entry door.
Check side to side then front to rear.
Michelle TAC MT-0
Sarah, Snowball
Old 10-16-2006, 02:42 PM   #3
Images: 59
Yes, there is a way; developed by Nick Crowhurst. It works very well. Although developed for side to side, it also works for front to back.
I'll let him describe it in detail: http://www.airforums.com/forum...57-post56.html
Old 10-16-2006, 02:47 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thanks!
There is an adjustment screw above the fore aft bubble. It could be that the screw threads are stripped, if so set it to level and epoxy the set screw in so that it won't turn.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 10-16-2006, 03:24 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you may have to readjust it a couple of times until the rubber grommet takes a set.
i put a new one on last year and it took about 3 trys to get it to stay put!
john
you call them ferrets, i call them weasels.
Old 10-16-2006, 03:50 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Doesn't mean the fridge is level
Originally Posted by thecatsandi
...I use a standard 2 foot long leve inside the entry door...Check side to side then front to rear.
Proper RV refrigerator operation/life is the primary reason for leveling an Airstream. In my case, the fridge is not square with the floor. While settling has probably occurred, I don't think the fridge was square with the floor went my Overlander left the factory in '67. For this reason, leveling with respect to the refrigerator's freezer compartment is the best thing to do.
I use a 2-dimensional level made by Reese which is mounted to the tongue jack. It can be easily calibrated via three adjustment screws. Unfortunately, I do not know if Reese still makes it. If they do, I recommend it as it does not stand out like anything attached to the Airstream.
Tom
Old 10-16-2006, 05:20 PM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Their website
'77 Sovereign Intl 31' CB
Old 10-17-2006, 07:35 AM   #8
Nye Thatcher's Avatar
In some cases the fore and aft adjusting screw will come in contact with the panel it is mounted on. If this is the case. just shim it off the panel.
Good luck.
Nye
Nye Thatcher is offline   Reply With Quote
Old 10-17-2006, 07:54 AM   #9
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Match the fridge
Tom
I wholeheartedly agree. Our old 79 Ambassador had a refrigerator that was
definitely tilted with respect to the floor. The PO had installed multiple
levels that disagreed with each other. When I finally figured out which one
matched the fridge, the adult beverages stayed much colder.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Flow Thru Exhaust and Muffler LKappenman Mechanics Corner - Engines, Transmission & More... 17 09-22-2009 11:29 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
