Old 06-05-2016, 12:03 PM   #15
1977 31' Sovereign
Lynnwood , Washington
Unless you're traveling or dry camping, leave grey water valve open.
Tom
TomKirk is offline   Reply With Quote
Old 06-05-2016, 03:53 PM   #16
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I interpreted the original post as "sailors dump gray water in the ocean... It's a pain to get only 4 showers into my gray tank before it's full... can't Airstreamers just dump gray water onto the ground". I was going to say "no" but OTRA15 dud a great job parsing the situation accurately.
Fcstreamer... Were you asking about a situation with sewer hookup, or just dumping at a campsite? Also, as a sailor you may be familiar with "navy showers". That approach greatly extends the life of the gray tank.
GammaDog is offline   Reply With Quote
Old 06-05-2016, 04:11 PM   #17
Gainesville , Florida
In the east and south there are very few places where you can dump gray water on the ground at campsites. Even some cg have areas where tent campers must dispose of their gray water properly.
Old 06-05-2016, 04:18 PM   #18
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Or you could get yourself a vintage Airstream. No gray water tank means no decision to make.
Lynn
WBCCI 21043
Old 06-05-2016, 04:45 PM   #19
2009 19' Flying Cloud
2016 25' Flying Cloud
Akron , Ohio
Like the others, I usually close it to collect at least half a tank to clean the black line and promote full evacuation of gray water particles. I don't leave it open for long periods of time, as I found in a couple of situations that odor from the sewage line enters the trailer through the open valve. I too have heard of back ups entering through open valves during my stays, way worse than just annoying odor. This has happened to neighbors of mine twice in low lying areas with old systems, like the Fl. Keys.
robi is offline   Reply With Quote
Old 06-05-2016, 05:11 PM   #20
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Up until 1973 Airstream trailers had no grey tanks and the water was just dumped. In anticipation of legislation enacted IIRC in 1975, making that practice illegal in State parks, grey tanks were included since 1974 model years. Many actually most of the camp sites in our Provincial parks are simply a level piece of bare earth with electrical hookups. A dish pan can be carried off into the bushes and deposited but dumping a grey tank or leaving the drain open would turn the camp site into a mud hole. Not a good idea.
Gearheart is offline   Reply With Quote
Old 06-05-2016, 05:15 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
In the summer heat, the gray water dumped out in normal use tends to dry fairly quickly in typical summer conditions.
I am NOT saying that I am draining my gray water out on the ground right now.....
Superat stultitia.
Old 06-05-2016, 05:30 PM   #22
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
One has to remember that sewer gas/smells are just a P-trap away, if that barrier evaporates, or sucked thru, your shower and sinks could smell.
I had a washing machine added in my last trailer, where the drain hose dropped in would give the the smell if I forgot and left the grey open at one park. I was at the far uphill end of a long run.
I don't leave mine open.
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 06-05-2016, 05:46 PM   #23
belen , New Mexico
We leave our open and the morning of departure I close it as the morning dishes and a few showers gives us our rinse water. I have a spray system I use if its the last time I am at a hook up prior to returning home.
alantbird is offline   Reply With Quote
Old 06-06-2016, 06:30 AM   #24
[QUOTE=J. Morgan;1802353]In the summer heat, the gray water dumped out in normal use tends to dry fairly quickly in typical summer conditions.
The liquid dries but the food particles remain and draws flies and even animals.
Old 06-06-2016, 06:37 AM   #25
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
W/O "hook-up's", all valves stay closed, grey flushes black when emptying.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-06-2016, 09:27 AM   #26
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I leave the gray tank valve open when at a campground with full hookups.
Some campgrounds without full hookups don't allow gray water discharge onto the ground, but I have let it go in a pinch- down a hill- on the far side of the trailer- after dark- in the rain. I guess I'm a bad boy.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-06-2016, 10:13 AM   #27
Boxite's Avatar
2008 22' Sport
Do unto others....
I guess you'll figure out what that stuff is where my trailer parked in your yard...
Gray water is also waste water and should be dumped at proper dump stations, or open sea and never in inland waterways or lakes.
Airstreamers should be above dumping where it's not desired by the property owner. It's just wrong.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 06-06-2016, 10:31 AM   #28
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Leaving the gray water discharge open
The soap kills the bugs....
And FWIW, if my gray water is draining on the ground right now, it is on my property, and when my 72 was built. It had no gray tank.....
Superat stultitia.
Leaving Dump Valves Open HankO Winterizing, Storage, Carports & Covers 15 01-01-2016 07:35 PM
Can you urinate in shower with gray water drain open? JoePaCO Full-Timing 65 08-21-2014 12:02 PM
Can separate Gray/Black water at discharge? stgerdonly Waste Systems, Tanks & Totes 1 07-20-2011 05:57 PM
Leaving table open while towing tnsue General Interior Topics 14 08-30-2004 02:35 PM
