Old 05-30-2016, 03:57 PM   #1
1999 25' Safari
Northeast , Arkansas
Kayak truck rack
We have a Ford F-150 and a 25' Safari. We recently purchased 2 14' kayaks and are trying to figure out the best way to transport the kayaks on the truck with the trailer attached. After much research, we are still at a loss. Any suggestions would be greatly appreciated.
Tamale is offline   Reply With Quote
Old 05-30-2016, 04:08 PM   #2
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
I can't speak to kayaks but we often travel with a canoe on the roof rack of our Tundra-- have you got a cap (canopy, topper) on the back of your truck so that the entire roof forms a straight line? We have a Yakima roof rack, sold to us by our canoe dealer. The brackets for the back bar did require some permanent installation on the cap over the truck bed, but now the truck with roof rack basically works the same as for a car. The canoe gets tied down with a lot of rope, then we have a bicycle lock on it to deter theft. The front mount on the car top carrier has its lock, as well.
We store our paddles and life jackets in the truck bed, which is also now nice and secure.
If you don't want the cap over the back of your truck bed, Yakima and some other companies also sell a sturdy square frame. that fits over your truck bed.
Len n Jeanne is offline   Reply With Quote
Old 05-30-2016, 04:29 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Depending on the overall length of your kayaks you might consider the Thule Hulavator. It will allow you to load from the sides. Not sure how much length you have on the roof of the truck to get reasonable separation between the units.
This 19 footer just clears on a right hand turn.
2004 Excursion 4x4
Old 05-30-2016, 04:38 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We have an 4 inch elevated cap on our full box Chevy dually. A kayak or a canoe fit on the Yakima roof rack system which is mounted to the cap on the truck. They do offer an crossbar extension which allows you to extend the bars sideways and load from the back and slide forward. You then slide them over to the top of the cap. The extensions then telescope into the cross bars. The elevated cap allows for 42 inches of rear door clearance, so we can put full size bikes in without taking off the seats or wheels. The elevation also allows for the bow of the canoe to not hit the cab of the truck. It has worked for us for 13 years.
Old 06-02-2016, 11:37 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Maybe this will help. They carry two 14.5' kayaks on their Tundra.
http://www.watsonswander.com/2015/kayak-gear/
Old 06-02-2016, 01:09 PM   #6
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
No Stock solutions out there when we did this:
We had the same challenge with one caveat, we wanted a bed cover to be on to cover up anything stored in the bed itself. We could not find any "Stock" solution after much searching so we knew we would have to improvise. Three items needed for installation on the F150 without concern for a possible bed cover:
Trac Rac:
http://www.autoanything.com/truck-ra...truck-bed-rack
Basic Kayak J-Mounts/ cradles (Example Only, Cheaper on Ebay)
http://www.amazon.com/TMS-Pairs-J-Ba...ayak+holders+j
Extra "T" Bolts from Trac Rac, Two per j-mount to lock them down to the rack. (8 Total) Expensive
We assembled the J-Mounts then took them to a welder/machinist to cut and weld them to fit the top of the rail on the Trac Rac. We made it so they could be removed and other implements could be used on the Rac (Possible Bike holders). Mind you, this rack is for Painters that carry ladders and long items and such. No J-Mounts or Bike racks will fit them (that we could find) without modifications. The additional 8 T bolts and nuts are needed here as well.
The Rac's come with a lip that sits on the inside of the truck bed and C-Clamps are used to attach it to the truck. The Racs also adjust on top as well at the bed. so your safe with it fitting.
Separately
To get it to mount with a LowPro Bed cover installed. We had to have the machinist shave off the lip on the Trac Rac then bolted it directly to the truck bed. I got Auto Screw Covers for when the Rac is not on the truck.
We started off with a F150 and normal installation of the Trac Rac, Since then I moved up to the F250 and LowPro cover and made the additional mods. This was the quick answer. Let me know if you have any questions.
ID:	263725   Click image for larger version
ID:	263727   Click image for larger version
Retail6 is offline   Reply With Quote
Old 06-07-2016, 05:37 PM   #7
steverino's Avatar
2010 27' FB Flying Cloud
Ivins , Utah
Still shopping for kayaks in the 14-15' range, but I figured we'd find some on our current travels in the Pacific Northwest. In anticipation of this, I put a Thule Xporter on the bed of the F250. I did the math; it will accommodate up to 17' kayaks and still be be clear while towing the 27FB.
The Xporter is pricy, but it had a key feature that I needed - once I remove the kayaks, the rack is easily lowered so I can still fit the truck into the garage.
steverino is offline   Reply With Quote
Old 06-07-2016, 06:24 PM   #8
Blackdog06's Avatar
2017 25' Flying Cloud
2015 23' Flying Cloud
Severn , Maryland
We travel with 14 and 16 foot kayaks and use a Yakima rack. They are sit-on-top and rest upside down on the rack. When the trailer is attached, we push them as far forward as possible and add foam cradles on the pickup roof.
This is the rack:
https://www.roadracks.com/product/ou...-300-fullsize/
Blackdog06 is offline   Reply With Quote
Old 06-07-2016, 06:50 PM   #9
2014 25' FB Flying Cloud
I just purchased a 2016 F150 Super Crew Lariat. I like to canoe and I went with the TracRac system. I don't know if you have a crew cab or not, but with the extra length of the roof with a crew cab you have more options. You can use a standard yakima or thule roof rack which attaches to the rain gutters. Unfortunately, my F150 does not have any track system on the roof and the roof rack would attach with a bracket that goes over the gasket on the door opening. It probably is not an issue, but over the long term it could be. However, this is probably the easiest solution to your kayak needs.
I went with the TracRack as it would also allow me to haul long lumber and ladders on occasion. However, as Retail6 noted, if you plan on installing a bed cover you may have to get creative if you want a rack over the bed. I too wanted a bed cover. My solution was to buy the TracRac with the rail system and a Retrax MX bed cover which Morrie at TonneauFactoryOutlet special ordered with cutouts for the stack pockets. As I would not need the rack 95% of the time I wanted it to be easily removed. While the kit comes with some rubber blocks which will hold the rack in place when tightened, removing the blocks and leveling the rails each time seems problematic. Therefore, I am in the process of cutting small metal foundations to be installed at each of the four stake pockets. These will stay in place and will be less than 1/4 of an inch above the bed rail. I will have a threaded hole in each one from which to hopefully easily attach and remove the rails. I would post a picture, but I am still in the process of fabricating the metal platforms.
Take Care, Lloyd
Lebthree is offline   Reply With Quote
Old 06-07-2016, 09:14 PM   #10
rbr
rbr's Avatar
2004 28' Safari
Danville , Virginia
We usually travel with a motorcycle in the bed, and then got a hobie cat which we carry on a ladder rack that I can take on and off the truck in about an hour. It is just the cheap one from HF, which I did cut down some to get it lower to the truck roof. I also drilled and pinned the longitudinal bars to increase rigidity, the stock clamp is really lame.
Bruce Robillard
Danville, Va.
rbr is offline   Reply With Quote
Experience with Rhino Rack track mounted rack? wecoyote Tow Vehicles 2 11-12-2015 03:25 PM
Kayak rack Nealrap Sprinter and B-van Forum 5 04-02-2014 05:59 AM
Sea Kayak Day Paddles on Florida's Hidden Coast nickcrowhurst Off Topic Forum 16 03-15-2008 08:26 AM
Packable Canoes / Kayak's knunut Off Topic Forum 19 02-11-2007 08:14 AM
