06-14-2012, 07:00 PM
1977 31' Sovereign
Florence
, South Carolina
Joys of Camping
Is it just me or is it that our propane tank tends to run out at night, after everyone but me has had a shower? Oh well tanks are lasting about 3 weeks can't complain
06-14-2012, 07:52 PM
Yep. That's the way it usually goes. Furnace out in the middle of the night. As for the hot water, we have the LPG/electric version so that's usually not a problem.
William C. Swinney
06-14-2012, 07:53 PM
Central
, Mississippi
Mine tend to run out when its in the 20ish degree range, between 3 am and 4 am, when the Mrs is alread cold and we have no hookups...
I just filled one tank, it lasted from January untill now. We will probably go through atleast 1, if not 2, during a 2 week outing to MT/WY...
06-14-2012, 09:35 PM
1974 Argosy 20
Kooskia
, Idaho
Just use the automatic changeover feature on your regulator, it will switch to a fresh tank all by itself, and then you can fill the empty one in the next few days without even shutting anything off. It has been a standard feature on Airstreams for 40 years, I never can figure out why so many don't know it is there or use it.
06-15-2012, 01:05 AM
2005 19' Safari
GLENDALE
, AZ
We switch ours over manually. When boondocking, it's better to know when the first one runs out, than to find out both of them are empty. It's not much fun camping with no hot water, the furnace doesn't work and everything in the refrigerator is spoiling. -- Oops, done camping!
Same thing with batteries. We use one at a time with a marine battery isolator switch. When the first one is drained, we just switch over to the second battery, which has a full charge. Not as critical, though, because generators are available for backup.
06-15-2012, 05:58 AM
1995 30' Excella
Bowie
, Maryland
If you're going to do this, it's a little silly to complain about running out of propane. It's a solved problem and many Airstreams have two ways to monitor propane capacity.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
06-15-2012, 06:12 AM
2002 19' Bambi
Northwestern Ontario
, - on the backside of the map and just above the big green spot
I guess I've never understood this problem either - it is easy to check the indicator on the change-over mechanism - and when it shows red your empty tank needs filling within the next few days - no panic - no runningn out of propane. With two tanks and a change-over mechanism this should not be a worry to anyone.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
06-15-2012, 08:51 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
not lol ... yep!
06-15-2012, 09:53 AM
Biloxi
, Mississippi
Unfortunetly not everyone has "modern" automatic switching over regulators. My Bambi II (48 years old) does not, so I have to keep an eye on the gas levels. After 6 months I am still on the same bottle using the trailer about everyother weekend and a couple of week long trips. The single stage regulator is working fine so I don't see reason to change it out just now.
MICHAEL
06-15-2012, 10:05 AM
1968 28' Ambassador
Cedaredge
I ran out of propane once about hour and 30 min from home. My friend lived 30 min away so I called him to bring me one of his, since he was coming down to visit. Turns out I didn't have mine screwed on all the way to the tank.
He never let me here the end of it....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
