Jacking Up Unhitched AS
Curious....
2019 Sport 22FB
I thought I leveled my AS after arriving at a spot I'll be for a month. Had to have neighbors move stuff to get TV in and out. Then I unhitched and started to unpack...
Ends up I'm a degree or two off side to side level and could use and inch or two on one side and even a couple inches all around to have room for Sewer Solution hose to drape smoothly.
It would be too much trouble to hitch up but I'm not sure if I need the stability to be lifting.
I suppose no problem, just make sure I chock opposite wheel..... and use jack points. Do one side and another to go up an inch at a time....
Right?
Warren
