Old 04-16-2011, 08:26 AM   #1
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Its raining inside the AS
Iím not sure of where this should be posted, as it doesnít really fit neatly into a subject area. If needed; Modís feel free to move it, and Iíll appreciate what you do.
We have a 2010, FC23FB, that we bought new last May. We donít run it a lot, but when we run the AC unit, either on cool or heat pump; we will sometimes get water dripping from the plastic housing on the inside. When we shut the unit down, about Ĺ to ľ cup of water will come down all at once. This might not seem like a big deal, except for the fact that the electric distribution panel (below the refer) is in the splash pattern.
Iíve been to the factory with the problem twice, but it still exhibits the same symptom. What say my more knowledgeable peers?
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 04-16-2011, 08:43 AM   #2
Possibly the drain hose is not attached or it could be plugged.
Certainly something the factory could easily correct.
Old 04-16-2011, 09:03 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Usually, water dripping from the air conditioner would indicate that the outside drain tube is either clogged or disconnected. What's confusing, though, is that moisture production does not usually occur during heat pump use.
I am surprised that you have had it to JC twice, and that they could not correct the problem. The techs at the Factory can usually fix anything on an Airstream.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-09-2011, 01:18 AM   #4
Snedwid's Avatar
Perry , Florida
To re-visit the problem,,, My natural inclination is to always maintain a zero bubble. However, by experimenting I have found that > 1/2 up bubble AND > 1/4 bubble starboard list, seems to facilitate the drainage. When I get home, I'll get out the big level and see if perhaps my attached levels need to be calibrated a tweek.
Old 06-09-2011, 06:13 AM   #5
fmrcaptevil's Avatar
Weldon Spring , Missouri
Snedwid, you are not alone.......mine does the same thing, despite the fact that a significant amount of condensate drains properly through the tube, at the same time. In my case, a little "nose down" adjustment diverts it to the roof (as seen during heat pump operation).
fmrcaptevil is offline   Reply With Quote
Old 06-09-2011, 07:06 AM   #6
Lothlorian's Avatar
Loganville , Georgia
where is the outside drain tube? I had the same problem this last week. When I ran the air the water dripped inside. Water was running out of the drain pan and down outside of the trailer when we ran the air . When I took off the cover and got up there to check things out I did not see the drain tube. Am I missing something?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-09-2011, 08:51 AM   #7
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Had the same problem for over a year. I finally removed the AC unit. I found that whoever installed it left a mess of caulk that re-routed the draining water. Unfortunately for me it it re-routed it such that it was dammed up to the point where at "zero bubble" it drained back into the trailer. Once I cleaned it all up and reinstalled the AC unit..problem solved.
Living life on the Road
deauxrite is offline   Reply With Quote
AC dripping water inside pappy19 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-10-2011 06:41 AM
Look inside your furnace pgr32e Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-17-2011 10:37 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
the inside lift handles removal AIR-Quarius Windows & Screens 2 03-02-2011 09:10 AM
Inside corrosion of outside skin Breadbug Ribs, Skins & Rivets 4 02-01-2011 10:37 AM
