Old 07-20-2015, 11:28 PM   #15
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
For our 34 footer I have used the silver bubble wrap that normally is used to wrap hot water heaters in all the windows and the door. They are flat and store nicely under our mattresses when not needed. They help whether it is HOT or COLD. Still wish we had two air conditioners, but....
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 07-21-2015, 12:26 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
We just spent two months in southern New Mexico, no shade where I parked at all.
I still use the original Armstrong 11,000 btu AC.
I put that above mentioned silver bubble wrap stuff between the screen and glass of every window, sacrifice the bathroom to the heat, and run the AC 24/7 set on 72 degrees. (I was also always saying "shut the door"... )
Using these techniques, I managed to keep the stream comfortable, even when it got dang hot.
Old 07-21-2015, 01:06 AM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by bobmiller1 View Post
Again 94 here in Lancaster, PA. When I bought the 325 I thought the fridge was shot, but during phase 1 of the overhaul I removed the steel wall in the cabinet over the fridge. I put my wet/dry vac hose in there just over the top of the upper fins on the back of the fridge. Used a 30" blow gun from outside and blew up, even cleaned out the roof vent and guess what...it works like new. The fridge is packed with all of our food for the week and the number 4 setting out of 5 is plenty cool for all the food and ice !
EXCELLENT reminder - a minor amount of crud can seriously interfere with air movement and cooling. I like the idea of blowing the crud out of the refrigerator's roof vent with a wet dry vac nozzle. I haven't cleaned my A/C inside filters yet this month - could be losing a few degrees of cooling right there. Not a bad idea to check them weekly.
Thank you.
Paula
Old 07-21-2015, 07:00 AM   #18
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Painted the roof on ours big difference in surface temps. We hardly ever run AC on high will cool just as good on low with out the extra fan noise. Never turned temp down more than half way before painting. Did a test this weekend full sun AC on low got down to 72 inside outside was high 90s and humid. Got a nice nap in during testing hard work.
thehandyman is offline   Reply With Quote
Old 07-21-2015, 07:22 AM   #19
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
A spray bottle filled with water (set to mist) works great. Just don't start a watergun fight with the wife.......
NavyCorpsman is offline   Reply With Quote
Old 07-21-2015, 07:45 AM   #20
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Last week the folks next to me were using similar fan to this one under their awning. They were in a beautifully restored little vintage Shasta with no AC.
http://www.amazon.com/Lasko-7050-Mis...ds=Misting+fan
MICHAEL
Old 07-21-2015, 09:13 AM   #21
Bend , Oregon
My 31' has insulated windows so I'm adding mirror film to the windows to reflect sun light and helps with privacy.
derf is offline   Reply With Quote
Old 07-21-2015, 10:03 AM   #22
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
[QUOTE=Don McKelvay;1655740]For our 34 footer I have used the silver bubble wrap that normally is used to wrap hot water heaters in all the windows and the door. They are flat and store nicely under our mattresses when not needed. They help whether it is HOT or COLD. Still wish we had two air conditioners, but....[/QUOTE
Use the silver bubble wrap on all your walls, makes a big difference in the winter and in the summer.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 07-22-2015, 07:01 AM   #23
AWCHIEF's Avatar
Images: 33
Would like to see a photo of your trailer with this treatment.🙀
MICHAEL
Old 07-22-2015, 07:08 AM   #24
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
One solution is to head for much higher terrain. Here in Angel Fire, it is a very comfortable 38 degrees this morning! Where's my jacket!?!
Lynn
WBCCI 21043
Old 07-22-2015, 07:47 AM   #25
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Dave, the difference between a crick and creek is much like the difference between nekkid and naked. If you're naked, you don't have clothes on. If you're nekkid, not only do you not have clothes on, but you're up to something. Be careful in them thar cricks.
Hijack over....
Originally Posted by mandolindave View Post
#1 Stay the heck out of the camper
#2 Find a crick ( creek ) they are shadier than lakes
#3 Put a lawn chair in the crick
#4 Get wet
#5 Stay wet
I can not count how many times, I forgot why I was in the crick, and started to walk back to the camper. Get 20 feet away, turn around , go back to the crick. I like to pass the time by playing mandolin, reading, and looking for nice rocks.
Old 07-23-2015, 03:36 PM   #26
Central , Mississippi
South Central Texas is nice and warm, the fridge isn't doing too bad. I do have this side of the trailer shaded where the thermometer and fridge are located and the wind is 12 mph.
Name:	ImageUploadedByAirstream Forums1437687378.383067.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-24-2015, 07:10 AM   #27
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Interesting! The inside of your fridge is the same temperature as our outdoor temperature this morning!
Lynn
Attachment 243694
WBCCI 21043
Old 07-24-2015, 04:59 PM   #28
2008 25' Safari FB SE
Campbell , California
How did you attach it to the walls? I'm wondering about removing the tape/glue/whatever when the silver bubble wrap eventually needs to come down.
mykabyka is offline   Reply With Quote
My Accident, dealing with State Farm Insurance David Ludwig Insurance & Claims 98 08-22-2016 09:59 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Any info on dealing with Colonial in NJ? caberneigh Buyer Guidelines 34 10-05-2010 10:13 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Dealing with the factory Silvertwinkie Commercial Listings 1 02-18-2004 10:08 AM
