12-07-2018, 09:42 AM
2019 25' International
Washington
, Washington, D.C.
Is the Clearcoat the same on Airstreams and autos/trucks?
I had a 2003 Ford Explorer for 14 years that I bought with a clear coat finish. I never waxed it, not once, and it looked beautiful until the day I sold it. It made me a believer in clear coat. So, my question is: Because my AS has a clear coat finish, will it stay beautiful and shiny without waxing or walbernizing it?
Thanks!
12-07-2018, 10:12 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
No...it's applied during manufacturing by Alcoa.
Cut & sized by AS, which does compromise the coating somewhat. 🙃
The auto industry coats after assembly & painting, very few exposed un-coated areas.
I use Griots Paint Sealer once a year...still looks pretty good. 👍 Been using Griot's on everything for a long time...The 'mop on a stick' is perfect for the AS.
The wash soap is sooper slippery and won't hold dirt & scratch.
They also have the best microfiber I've found.
12-08-2018, 05:32 AM
2018 30' Classic
Cumberland
, Maryland
Man that looks fantastic Bob! Do you do it by hand or use a buffer?
12-08-2018, 06:53 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Porter Cable,..... 6.5" foam applicator, ,..... Remove with these......
One Step... once a year.
Now...don't laugh, but this for quick touch-up's, started using on the boat after every outing and it transferred great to the AS.
I'm a confirmed believer, I use Griot's on everything.
FWIW...'Bertha' the Ford, is the DW's Gramma's first new car and is untouched original. We have been the caretakers since 1976. 👍
12-08-2018, 10:31 AM
2015 20' Flying Cloud
Lander
, Wyoming
Can you tell me exactly which Griots product you use? I checked their website and found several different sealers.
12-08-2018, 11:11 AM
2018 30' Classic
Cumberland
, Maryland
Thanks for the info Bob. I usually do all my stuff by hand but the arms don't work like they used to so maybe I'll give it a go. BTW, everything looks fantastic!
12-08-2018, 11:13 AM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I don't think the brand of wax makes much difference. I get the same results on my Airstream by spraying on Walburnize and wiping/rubbing off with micro fiber towels. The key to long PPG clear coat life is to make sure you get is on all the cut and drilled areas around all the edges and rivets. That seals out moisture and will eliminate filiform corrosion. My trailer just finished it's 14th season and the finish still looks new.
guskmg
12-08-2018, 11:29 AM
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento
Yes the clear coat is the same as the automotive clearcoat.... however, as others said Airstream does not apply it after the trailer is made... it is put on at the factory that makes the alu sheeting....
Applying a second coating to the clear after its dry'd.. doesn't work.. it won't blend in to the existing coat... so one is stuck... however,
If you rough up the existing clear coating so it has a 'tooth' so to speak... then it will stick.. but where ever its feathered into the existing... you will always see a cut line... the only way to get it fully covered is to strip the old off and then coat the whole thing with new... sorry...
It would be nice if AS waited and clear coated the whole outside.. sealing the edges etc.. but knowing how cheap the management is... it becomes a wonder after several years...
Strip and re coating is not that expensive but, if I were going to do it.. I would first strip and then do a conversion coating.. i.e alodine conversion... that then gives the alu a harder more less corrosive surface.. then I would coat it with clear coating...
This is what they do to aircraft... to prevent corrosion in years to come... as well as it can then give it color...
Again... A/S is still stuck in the dark ages as their are new ways to maintain that look... I know that avion and silver streak... both alu trailers.. went to it years before they quit making them... and they got that satin finish as well as great all weather protection.
If you polish them out you have taken away everything except the alclad... which protects the other metals like mag in the alu... it is the mag that starts to corrode first...
waxing the existing clear coat protects it from the UV... like autos... it becomes something like cancer... on cars.. and then the water color paint goes away.. and leaves the primer with is also water based... to start to rust the under metal...
So waxing does help through the years.. but, it is the sheet edges and rivets that start the corrosion process first... because of the lack of protection.
12-08-2018, 11:31 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
guskmg
PPG...over the Alcoa finish? How has it held up, was it easy to apply?
12-09-2018, 06:15 AM
Washington
, Washington, D.C.
To guskmg - thanks for the specific advice i.e. applying a good wax to cut edges and drilled areas. Given all the helpful info provided in this thread, that makes sense.
12-09-2018, 08:48 AM
2019 22' Sport
Bellingham
Thanks!
I just purchased a 2019 Sport 22 FB in Oct. It was coated and according to the dealer I would not have to wax for 7-years. I will find out as it ages.
12-10-2018, 11:26 AM
2018 30' Classic
Cumberland
, Maryland
The clearcoat on our airstream does not feel or act like the clearcoat on our vehicles (when scratched). It seems to be softer than our vehicles clearcoat.
12-10-2018, 11:38 AM
Walnut Creek
All - if the nano-coat or the clear coat is scratched it needs to be sealed. Since it is not easy to find all scratches, it is good practice to clean and wax or reseal on an annual basis. The dealer who told you not to wax, did you as bad a dis-service as the folks who think nano-seal is a waste of money. Maintain your coach and it will smile on you. Pat
12-10-2018, 01:24 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X2
Ignore surface protection at your peril.
I believe if you do the research you will find much better options than what the Walberoffers.
But, it's not really what your using, it's that your using it...when needed. 😎
12-10-2018, 05:40 PM
West Des Moines
, Iowa
Wow, that does look beautiful! Just curious, but you you store your AS indoors during winter months, or is it outdoors year-round? I'm planning to build a garage that will eventually store my future AS ... try to keep mother nature away from it during the Midwest winter months.
12-10-2018, 05:44 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
And the answer is.....
12-11-2018, 09:14 AM
ObviouslyKnot
KAILUA
, HI
Classic.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
12-12-2018, 05:22 AM
2018 30' Classic
Cumberland
, Maryland
I bought the pen applicator from Airstream and covered the scratch. Just noting that the coating seems way different.
12-12-2018, 12:08 PM
Walnut Creek
It is different. See Post #2. The clearcoat that Airstream has on the coach is applied by the aluminum manufacturer. It is a nano-coat material. It is not a sprayed on after manufacture process like the clear coat on cars and full paint motorhomes.
Note as well that the clear coat on some cars is soft, while it is much harder on other brands. A good high end detail specialist can help with developing a better background on your car. The information here may well be best with respect to your Airstream. Lots of folks have spent time in the "Wipe on - Wipe off" skill development.
Note - one thing that is likely transferable. Always lubricate (not oil - use soap, speed shine or some similar product) the surface when removing surface contamination like dirt, bugs, and tar. ALSO - G et the bugs and bird droppings OFF - digestive juices are not good for any finish. Pat
12-12-2018, 05:56 PM
2018 30' Classic
Cumberland
, Maryland
Copy that PKI, I misunderstood it to mean it is the same just applied differently. Did not know the difference between car brands since I only have Chevy's and one Honda with no difference. Thanks for the info!
