Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 04-04-2016, 06:30 PM   #1
East Bridgewater , Massachusetts
Is 2-ply toilet paper a must use?
Is 2-ply toilet paper a must and has anyone ever installed a bidet toilet seat in an airstream?
renrutdraw is offline   Reply With Quote
Old 04-04-2016, 06:49 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Single ply is a better choice because it breaks down better in the black tank.
Old 04-04-2016, 06:56 PM   #3
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Scott 1000 a good choice?
davidrrand is offline   Reply With Quote
Old 04-04-2016, 07:01 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
It is important to select the right toilet paper when using a RV septic system, or the black tank. Airstreamers have had problems with undissolved paper getting stuck in the dump valve causing leaks. Basically you want a toilet paper that will "pulverize" when soaked. Put some in a glass jar, let it sit for an hour or so, then shake the jar. The paper ought to dissolve.
Charmin Basic is one of those tissues. A Kleenex is not Baby Wipes are not either. RV places sell special toilet paper that dissolves, but it is more expensive.
Search Air Forums via Google and find several threads on the right toilet paper and the problems the wrong stuff can cause.
David
Old 04-04-2016, 07:01 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Personally I am not too particular. There is a special tp for septic tanks that is fast dissolving. You can probably get it at a rv store.
Old 04-04-2016, 07:02 PM   #6
Sag Harbor , New York
You should ONLY use TP which is designated for RV or Marine toilets. It is usually single ply, and the wood pulp used is designed to break down easily. Even Scott single ply does not fit the bill IMO (unless they make an RV version of which I am unaware). [edit see MacPDX correction]
"Can" [ intended ] you get away with using something close, just to save some money? Sure, but when you are cleaning out a sewer clog someday because the TP did not dissolve right, please remember the day you decided to save a few pennies per wipe !!!
Old 04-04-2016, 07:20 PM   #7
Portland , Oregon
Scott's rapid dissolve is made for RV's.
http://smile.amazon.com/Scott-Rapid-...oilet+paper+rv
2015 Nash 24M
2014 Tundra DC Limited TRD (Sold)
2016 Ram 3500 CTD SRW CC
Blue Ox SwayPro
Still looking at Airstreams....
MacPDX is offline   Reply With Quote
Old 04-04-2016, 07:24 PM   #8
r carl's Avatar
Lin , Ne
x2.
Old 04-04-2016, 07:35 PM   #9
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
PS on board our boat there was a steadfast rule...if you don't eat it first ... don't put it down the toilet.
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 04-04-2016, 07:48 PM   #10
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
An Airstream deserves nothing but the best:
https://youtu.be/vRlBtabKRFM
Thalweg is offline   Reply With Quote
Old 04-04-2016, 07:53 PM   #11
Roadhoop's Avatar
2022 30' Classic
Granville , Ohio
@prairieschooner
I have never used TP that way.... Inside out...
Roadhoop is offline   Reply With Quote
Old 04-04-2016, 07:53 PM   #12
Bummer!
Obviously not a real product, butt a put-on?
Old 04-04-2016, 08:00 PM   #13
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
So far (2 years) we have managed to avoid going #2 in our AS. This was advised to me by an old RV hand when I first got the AS. I think it has made the atmosphere much more pleasant inside, the dumping of the black waste less "black", and much reduced the use of TP. Either there is a campground toilet, or a convenient tree and a GI shovel/hoe to bury the evidence.
McDave is offline   Reply With Quote
Old 04-04-2016, 08:13 PM   #14
2022 Atlas
Homosassa , Florida
Charmin 2 ply Ultra Soft is our choice. We use plenty of water in the black water tank and the drop in deals that dissolve solids. We only use septic system safe toilet paper.
Tater is offline   Reply With Quote
Old 04-04-2016, 08:18 PM   #15
[ Speechless . . . ]
Old 04-04-2016, 08:20 PM   #16
Originally Posted by Tater View Post
. . . We only use septic system safe toilet paper.
"septic system safe" is not the same as "designed for RV and Marine toilets" IMO.
As said earlier:
Old 04-04-2016, 08:36 PM   #17
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I've never ever bought a roll of special toilet paper, never will. Just regular TP.
I've not had a stopped up sewer tank, pipe, etc. Been more than more than 20 years Airstreaming.
If toilet paper is causing a problem, it is because not enough water is being put into the tank.
add edit:
If I was using a macerator pump and small discharge hose, I might change my mind.
Old 04-04-2016, 08:52 PM   #18
dznf0g's Avatar
Oswego , Illinois
add edit:
Me either. In over 30 years of camping, never had a clog.
-Rich-
Old 04-04-2016, 09:09 PM   #19
2013 28' International
Bozeman , Montana
I'm not towing around a 4 ton trailer and using public bathrooms because I'm afraid to use the head. And no, my trailer does not smell like @#$%.
Sorry, but that is about as nuts as using sleeping bags instead of high end sheets and a decent wool blanket.
I just don't get it.:roll eyes:
Oh, yes, another vote for Scotts one ply RV TP. Does the job pretty well for a one ply and so far no clogs.
HeadWest is offline   Reply With Quote
Old 04-04-2016, 09:45 PM   #20
CRH
1995 25' Excella
xxxxx , xxxxxx
Septic safe paper user here simply because it is what I use at home. I always add water before a trip and top it off before dumping. Never had a issue.
I can't imagine having a toilet and trying to not use it in favor of squatting over a hole.
CRH is offline   Reply With Quote
8-ply or 10-ply tires?? Doug C Tires 2 07-13-2012 02:37 AM
Any reason to NOT use bias ply tires? tvanwave Tires 50 03-26-2012 04:30 AM
MUST SELL, MUST SELL--BUY NOW 1994 Airstream Land Yacht eBay Watch Airstreams on eBay 0 07-31-2009 08:00 AM
8 ply vs 10 ply jcanavera Tires 6 08-16-2007 04:12 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
