Old 03-27-2012, 08:27 PM   #1
Kittypuke's Avatar
Columbus , Georgia
I want to die in my sleep like grandpa, not screaming like everyone else in the car
Which brings up my question At what length and weight should sway bars and electric brakes be used? Mine is 12ft and around 1000lbs.
Kittypuke is offline   Reply With Quote
Old 03-27-2012, 09:02 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Many state laws are on the books for trailer brakes at 2,500-lbs (some at 1,500-lbs).
WD hitches probably for a 2,500-lb trailer as TW of 350-lbs and up is sufficient per vehicle manufacturer.
2,500-lbs at 15% TW = 375-lbs
What sort of trailer is this? And what is the TV?
Old 03-27-2012, 09:42 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Any four wheel vehicle rated to pull a 1000 lb trailer can handle that weight w/o trailer brakes. In California the legal limit w/o brakes is 3000 lbs, but clearly the safety of this depends heavily on the TV. When to use a weight distributing hitch depends on the TV and the tongue weight; again, 150 lbs (15% of trailer weight) is going to be fine.
-= Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-28-2012, 07:07 AM   #4
Kittypuke's Avatar
Columbus , Georgia
Great, I think I will pass on adding sway and brakes since its so small.
Old 03-28-2012, 07:36 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
"I want to die in my sleep like grandpa, not screaming like everyone else in the car" The easiest way to accomplish your goal is to fall asleep at the wheel.
You probably won't need sway bars for a 1000-pound trailer unless your weight distribution is WAY off. Whether you need trailer brakes will vary by state. Some states require trailer brakes regardless of trailer weight, with a stipulation that the tow vehicle plus trailer be able to stop in 40 feet at 20 mph.
A good summary of trailer towing requirements by state can be found at Towing World's website:
http://www.towingworld.com/PDFS/TowingLaws.pdf
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Getting on the roof perryg114 Roof 34 04-05-2012 06:07 PM
Stolen in Seattle Area - Brand New 31 foot Airstream! Airstreamnw Our Community 47 03-28-2012 05:35 PM
Who says dogs don't go to Heaven? :) Kittypuke On The Road... 49 03-28-2012 05:08 PM
Vintage aluminum camper like Airstream eBay Watch Airstreams on eBay 0 03-27-2012 04:20 PM
