Old 07-03-2002, 10:31 AM   #15
Chuck,
Look at that 12V recepticle box closely. To the right of the socket are three pin holes from an old style antenna plug. It is in a flat triangular shape. If you take a flashlight and shine it on the plastic box, you will notice there are raise letters identifying each receptacle. There is also a small switch on the right hand side of the box. I did not read what it said though!
I believe the two switches are as you state. Above the door and for the round outside light. I am working on a problem with a torn gasket on the top small fixed window forward of the door. I noticed the gray rubber gasket flops around when I sprayed it while washing the trailer. I have not detected a leak yet but I want to correct the problem. Can I get replasement gaskets? If so, do I have to drill out the rivets and remove the window to install it? Thanks!
Larry
Stougard is offline   Reply With Quote
Old 07-03-2002, 11:11 AM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I'll check it tonight when I get home...
what's the 3rd switch for, then? the one that is forward of the window is right underneath the outside "taillight-looking" one, so I'm assuming its for that, but maybe its for something else; then there are 2 right next to the door.
You can probably get replacement gaskets from inland rv...if nothing else, I'm sure there's at least "gasket material" available. don't know, haven't got that far, yet. (I'm new at all this I don't know how to get the window out, but from my reading here, it seems that just about everything requires rivets to be drilled out....
Motor Home Gun Laws winner On The Road... 26 08-17-2009 02:45 PM
Guess what followed me home?... docbluedevil 2004 Safari 9 11-05-2003 10:58 AM
She is home - 2003 Classic! Pahaska 2001 - 2005 Classic 9 10-23-2003 11:50 AM
new member/new motor home malski Airstream Motorhome Forums 12 08-09-2003 05:02 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
