Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 01-27-2017, 08:52 PM   #1
SailorSam205's Avatar
South East , Michigan
I-75 Southbound closed near Detroit
Just saw a report. Southbound I-75 will be closed for approximately 2 years starting in early February. Northbound will remain open. Here is a map of the construction area.
I suspect this will be a major issue for folks coming into the US thru Windsor and trying to head south. I-94 is another option to get to I-275 but is heavily traveled. During non-rush hours, I would consider taking I-94 to Telegraph US-24 then south to pickup I-75 south of the construction. Expect LOTS of semi traffic whichever way you go.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 01-28-2017, 01:10 AM   #2
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
Thanks for the heads up we drive that all the time.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 01-28-2017, 08:47 AM   #3
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
I -94 is as heavily traveled as I -75. The problem is, I -94 is a 70 year old highway (built in the 1940s) in the close in areas. So the I -96 routing will be as fast or faster, even with the added distance. One can also consider I -94 to US -24, then back to I -75. Traffic flows fairly well as signals are coordinated and those 'Michigan Left' turns....
Tom
AIR 71620
WBCCI 5809 Reg 9 Unit 155
2008 Classic 30'
2019 F250 4x4
tvketchum is offline   Reply With Quote
Old 01-28-2017, 08:54 AM   #4
2018 27' International
Southeastern MI , Michigan
I96 to I275 is not for the faint of heart. If you can't do 80, you might want to take another route.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline   Reply With Quote
Old 01-29-2017, 10:20 AM   #5
An update, southbound closure starts Feb 4, 2017. Based on a report I heard this morning, when construction on the southbound side completes, they will route northbound traffic to the southbound lanes (still no southbound travel).
FWIW, one of the things they are working on, a section of the roadway on the big bridge over the Rouge river fell out! There was a large hole and a number of vehicles hit it. I they are going to completely replace the roadbed on the bridge. While they are redoing the Rouge bridge, they are going to replace two other bridges farther south. The two long bridges are to be replace by four shorter bridges (lower cost to build and maintain).
Ouch!
Al
Old 02-01-2017, 07:12 AM   #6
gator.bigfoot's Avatar
KW , Ontario
Thanks for the heads up. Here is the count down timer to the closure.
http://www.freep.com/story/news/loca...iver/97289238/
I think I'll be taking Sarnia to Flint and then Ann Arbor to Cincinnati. Hopefully that route will flow ok.
gator.bigfoot is offline   Reply With Quote
Old 02-01-2017, 10:33 PM   #7
There may still be some extra traffic once you get to AA.
FWIW, I would seriously lean toward taking 94 from Port Huron down to 696 to 275 to M-14 to AA. Then south on 23. You would mostly be on 3 or 4 lanes. 23 from Flint to AA is 2 lanes and there is a bunch of construction once you hit Brighton. They are modifying 23 to put in a center lane in the stretch between Brighton and AA.
Depending on time of day and how traffic looks, you might get to Toledo faster staying on 275 and not going further west to AA.
Al
Old 02-02-2017, 04:02 AM   #8
Andrew T's Avatar
London , Ontario
That's the route we used last time 75 was being rebuilt. It works well.
Andrew Thomson
London, Ontario
Campgrounds near Detroit Sal44 On The Road... 3 08-06-2012 01:58 PM
Metro-Detroit Rally vote! Anon Forum Rallies & Meet Ups 56 07-17-2005 11:04 AM
AIR Midwest : How about a Metro-Detroit get-together Anon Forum Rallies & Meet Ups 44 04-28-2005 11:04 PM
(Detroit) Looking for Workspace-Warm? 3237 Off Topic Forum 2 01-17-2005 12:47 PM
