Old 05-17-2003, 04:20 PM   #15
Chas & Craig,
Thanks for the updated info. If it ever stops raining here in Tennessee, I'll be back at it. Still haven't figured how to remove the broken tap. If I can do that, I will not have to remove the lock, just re-tap and replace with a new screw-button.
Dan
Dbraw is offline   Reply With Quote
Old 05-17-2003, 05:24 PM   #16
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
Lightbulb Broken tap ?
Dan,
Are you sure it is a broken tap. If so , being taps are hardened , you are in for a bit of work . I hahe had luck with breaking them into small pieces to get out. Then over size the hole a little and retap. Sometimes to a metric thread.
If it is part of a screw, there are left hand drill bits available thru tool dealers like Snap On. I used to have good luck with them and some penetrate lube. Useing a bit small enough to not cut the threads , as you drill , the combination of vibration and heat as well as the penetrant usually spins the screw out as you drill.
Just some thoughts from a once upon a time auto tech.
Good luck
Loren
69 Silverback is offline   Reply With Quote
Old 05-17-2003, 05:46 PM   #17
Check for a tool called an "Easy Out", same principle. But easier to find than a Snap On man.
You can find some machinist ones, all sizes, very good. Or some of acceptable quality at auto part stores, or dirt cheap ones at WalMart.
femuse is offline   Reply With Quote
Old 05-18-2003, 07:05 AM   #18
Loren & Chantal,
Thanks for the info. I'll go slow and try to fix the lock. May have to get out the dynamite. If I have any left after the last fishing trip.
Dan
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
What type of door lock after '77? tiniree Doors & Locks 26 09-21-2009 09:49 AM
lock of screen door on 16 foot-Bambi gloriajoan 1997 - 2004 Bambi 10 10-16-2006 03:30 PM
MH door lock wb13798 Mechanics Corner - Engines, Transmission & More... 9 01-14-2004 11:05 PM
1978 Excella door lock startrekker2001 Doors & Locks 0 08-28-2003 12:59 PM
