Old 05-06-2014, 08:02 PM   #1
how to get all hot water in Sport 16???
wife and i are on our first trip in new sport 16. everything going great except we can only get about a quart or so of hot water.
i contacted service folks at airstream today during a long drive to florida campsite (fantastic) and what they told me was a bit confusing as this is so new to me, but i think they said to turn the valve in the closet to allow waterflow from white to red side. i understood the fine fella at airstream to say that the middle valve comes closed from the factory so that if the airstream is winterized immediately, the antifreeze does not go into hot water heater??? (i predict i have this really screwed up in my mind)..... Tonight i opened the hot water hatch inside the closet and all three valves are inline (open).
what am i doing wrong???
thanks so much,
bob
boxerteam is offline   Reply With Quote
Old 05-06-2014, 08:16 PM   #2
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Attachment 211383Well, a quart is the limit of hot water in the 16'. (just kidding)
You should have valve a and c open and b closed. In the drawing B, the closed one, is the one in the middle. The other two should be open. I will check to see if your model is different online but that is the way mine is.
Also make sure that your water heater is on and did not run out of LP gas.
If you are hooked up to the campsite water spigot then you have water?
OR, if dry camping, is your water pump on? Just checking.
Here is a pic (double-click to make larger) of a Sport manual diagram. Hope it helps. I did not see a diagram in the new model book. OH loo
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-06-2014, 08:23 PM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
There should be a valve on the cold water line (white), a valve on the hot water line (red) and a valve on the crossover that connects the two. That valve on the connector should normally be closed. It is opened only when winterizing. Did your trailer come with an instruction book? There should be instructions there for winterizing and it should include a diagram on how to set those valves.
robert claus is offline   Reply With Quote
Old 05-06-2014, 08:49 PM   #4
2006 25' Safari
Images: 8
Let me know if it works for you. Normal operation is to have the middle valve closed and the other two open. Winterizing is the opposite for storing - both sides closed and middle one open.
So, for use, close the middle valve. Sorry for the abc stuff, I changed the photo reference from a 2010 using abc to a 2014 using 123.
Old 05-06-2014, 09:03 PM   #5
thanks to all...
i am properly hooked up to city water at campsite.
bypass valve was open. i just closed bypass valve thanks to your guidance...
lp bottles are full and turned on.
pump is off as my understanding is that the pump is only necessary when not using city water or when city water pressure is low...
do i now need to do anything to cause cold water to enter hot water heater?
again, thanks kindly!
bob
Old 05-06-2014, 09:06 PM   #6
by the way, Rod...impressive ability with photo sir!
is not part of my owners manual.
i think you may b n florida, and we are now hooked up at topsail in santa rosa island in panhandle...awesome spot.
sport 22 next to us, amazingly...
i bet they get a half gallon of hot water! <grin>
Old 05-06-2014, 09:08 PM   #7
2006 25' Safari
Images: 8
No, sounds right. Is the water heater turned on now? reset it just in case it thermally shut down. Listen for the sounds of draining water and a burner. If you are in Santa Rosa, look for a 30 foot Airstream bunkhouse and a young family. That is Pharmgeek on the forum. He is supposedly there or coming there. You may have to crack a faucet on the hot side in case of air.
Old 05-06-2014, 09:16 PM   #8
IT WORKS!
Yea and thanks a ton...
bob/boxerteam
Old 05-06-2014, 09:19 PM   #9
it took cracking the hot water faucet to gain flow....
all is well.
will look for pharmgeek as i read his entries regularly.
thank you
Old 05-06-2014, 09:20 PM   #10
2006 25' Safari
Images: 8
Good now remember to share!
Old 05-07-2014, 05:51 AM   #11
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
I just love happy endings!
I hope the rest of your stay is uneventful and full of good times.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
How to get rid of crystals in hot water heater? H. Huester Water Heaters, Filters & Pumps 5 06-11-2010 08:29 AM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
