Old 06-13-2013, 09:19 PM   #1
AL’ UM- MONEY's Avatar
1976 31' Sovereign
Ball Ground , Georgia
How hot is too hot
I was hopeing to take off in Sept and visit Arizona and Utah.Due to schedule problems It looks like we may go most of July. In Georgia if it's 95 degrees we really feel it because of humidity. How difficult will it be out west with reports well in the hundreds. I have heard it is a different type of heat. Should we go?
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
AL’ UM- MONEY is offline   Reply With Quote
Old 06-13-2013, 09:33 PM   #2
1986 31' Sovereign
Miami , Florida
It is a dry heat but so is my oven and you won't see me sticking my head in there...
Your AC is, at best, good for about 20 degrees from ambient so 110 in Vegas is 90 in the trailer...
Come up to Yellowstone. 80 is a hot day.
mike
Old 06-13-2013, 09:49 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Sedona isn't terrible, Flagstaff is actually ok. The low-altitude places will be roasting, though.
— David
Old 06-13-2013, 09:52 PM   #4
7GenTex's Avatar
Briarcliff , Texas
Your A/C should be good for a 20 degree differential from the temp of the intake air going into the A/C inside the trailer. Outside temp, direct sun or shade, and insulation qualities are all a contributor to the heat gain you may experience, but the outside temp, on its own, does not limit how cool you can get the inside of the trailer unless your A/C is marginal in capacity as compared to the heat gain.
As the trailer cools down inside, that 20 degree differential continues. I see 100 degrees outside often, but inside my trailer can get to the 70's easy. It's a 27' Avion with a single 15k unit.
Just because it is 100 outside does not mean you can only get the inside to 80. If so, you have other issues that need to be looked at.
See this thread:
http://www.airforums.com/forums/f427...ml#post1303829
Dry heat - it's not near as bad as humid and hot..........and I grew up in Houston!
And the dewpoint is the key, not relative humidity.
1966 T-27 Avion (Sold & missed already!)
7GenTex is offline   Reply With Quote
Old 06-13-2013, 10:19 PM   #5
1989 34' Excella
Ottawa , Kansas
Being from Arizona there is no way I would stay in Phoenix in July let alone in September! We see 115+ even in September. That is way to hot!!!!
1989 excella is offline   Reply With Quote
Old 06-13-2013, 11:56 PM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Northern New Mexico and Northern Arizona can be warm in July but cool nights. Also plenty to see in the Colorado mountains. Stay out of the desert.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-14-2013, 07:35 AM   #7
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
The ability of your Airstream to cope with temperatures aside, from those who have lived in those conditions year round, there are common sense opinions on how you may cope which may be given. I took college in Tucson, seeing 124 in the shade my final summer before moving to Minnesota (where I saw -41 that first winter..)
Your major concern is going to be water - "dry heat" feels great because your sweat evaporates as soon as it is produced; or very shortly thereafter. Feeling dry helps you feel cool. However, you have little to no warning over heat stroke until it's upon you. In Tucson, come July and August, the streets go deserted between the high heat hours of 11-2 or so. You want to be inside or in steady shade during those hours - and during all hours you want to have a water bottle with you. You want good hydration; constantly drinking to satisfy the three C's of urination: you want it clear, you want it copious and you want to have a constant need to go. you want to ensure your nutrients are up to scratch. I've seen friends take too much water out of caution. Finally, exposed skin is burned skin in minutes - my sophomore year at Arizona, a girl in my apartment complex perished from sun tanning in under 30 minutes of direct full body exposure at the noon hour.
Having said, southern Arizona is amazing during July and August. Early monsoon season is amazing in the desert - from flower and wildlife viewing to the sheer intensity of storms forming up and rolling off of Mt Lemmon into the valley mid to late afternoon. The camps and boondocking in the mountains are always a nice respite from the heat and the trail systems throughout the various ranges are all amazing.
Good luck and if you make the trip at that time year, take some cautions and enjoy yourself!
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 06-14-2013, 09:23 AM   #8
mandolindave's Avatar
What kind of activities will you want to do?
Hiking? Sight seeing from your tow vehicle?
Hiking is the way to get to see the very cool places. It seems that " they " leave and or create obstacles to prevent motorhomes, trailers, or luxury sedans from getting even close to any pristine wilderness areas. So drop off your trailer when car sight seeing ( also that might prevent you from engine overheating ) I go desert trekking at the end of May when daytime temps are about 95, dropping to 50 about 15 minutes after sundown.
IMPORTANT SURVIVAL TIPS. Sipping water only helps your mouth be comfortable. You need to gulp water for it to get to your brain. Don't leave plastic water bottles on the ground. ( critters will get at them ) Carry at least one gallon of water per day per person.
I try to limit hiking to 5 to 9 am and pm. Caves, Slot Canyons, air conditioned bars and diners is how I avoid the mid day heat. ( Siesta ) Altitude is another way avoid harsh temps.
mandolindave is offline   Reply With Quote
Old 06-14-2013, 12:50 PM   #9
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Ha, this thread is getting me psyched up to drive drive the the Mojave desert next month with only a 13.5K AC unit. May just park the stream and get a hotel room.
I have driven that same desert from Needles CA to Palm Springs in a VW Bus with NO ac, but was smart enough to do it at NIGHT and it was still 108 degrees at two in the morning.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 06-14-2013, 01:05 PM   #10
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Don't know if you travel with pets...but it would go without saying that they shouldn't be left in a car or trailer in those kind of temperatures - even for a short time.
Personally, I would opt for a cool hotel room that time of year...my folks live in Scotsdale and I never visit between Memorial Day & Oct 1st - I don't like the heat, even if it is a "dry heat".
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-14-2013, 03:18 PM   #11
2005 19' Safari
GLENDALE , AZ
Note to non-Arizonans: It is illegal to leave children or pets (animal cruelty law for pets) in unattended vehicles in this state. Possible fines and jail time await offenders, due to almost inevitable death. We have child and pet deaths and heat-related injuries here every year. If you are lucky, a passerby will break into your vehicle and remove them; but expect police to be waiting for you when you return.
Old 06-14-2013, 03:33 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
Is this true without exception, in all seasons? One of the things I like about my Ford is that when traveling alone I can leave the engine (and air conditioning) running, lock the doors with the keypad and go into a truck stop to the bathroom or to purchase something so the dog stays comfortable.
— David
Old 06-14-2013, 03:54 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Stay to the higher elevations. The North rim is a nice area. I do not like heat. But by being flexible you should be able to find spots. If you are at decent elevation it cools off at night. July might be better than August or early Sept.
Old 06-14-2013, 04:12 PM   #14
DKB_SATX's Avatar
1976 Argosy 28
I think I found the exact answer.
Arizona 13-2910 A. 7. seems to say: A person commits cruelty to animals if the person intentionally, knowingly or recklessly leaves an animal unattended and confined in a motor vehicle and physical injury to or death of the animal is likely to result.
It would then seem that leaving the dog for a brief period in a reliable truck with the engine and AC running (and locked to avoid running afoul of laws like one in Texas that makes it a violation to leave your keys in the car with the door unlocked) would be permissible.
— David
Old 06-14-2013, 04:27 PM   #15
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
There is no seasonal adjustment for these laws in Arizona, Texas, or any other state I know of. Even in midwinter the interior of a car in the sun in Phoenix or Fort Worth can quickly reach deadly levels. If for any reason the engine of your car quits or the a/c fails, you could easily come back to find a dead or seriously heat injured pet. But any punishment the law might deal out would be next to nothing alongside living with the heat related death of the dog you left in the car while you ran into the store for "just a minute."
joemikeb is offline   Reply With Quote
Old 06-14-2013, 04:36 PM   #16
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hope he doesn't drive it off.
Dog puts car into drive, injures central Pa. man | 6abc.com
Vaughan
Old 06-14-2013, 05:42 PM   #17
DKB_SATX's Avatar
1976 Argosy 28
Yes well... if I could afford to hire a Jeeves to travel with me, or if all business allowed me to take the dog in, I could live without THAT risk. Then again there's the chance I'll have a wreck with her in the truck with me and perhaps she would have been safer at home... then again the house could burn down while I'm away and perhaps she would've been safer with me.
You can't eliminate risk, but you can minimize it without being sanctimonious.
— David
Old 06-14-2013, 06:35 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is not an issue of how cool the a/c can get the trailer. We have 2 roof airs. The thing is if it is too hot to hang around outside we might as well stay home. If all we're gonna do is lay around in the trailer and watch movies because it is miserably hot outside we can do that at home. We usually park it from after Memorial Day until just before Labor Day. Maybe one day when we are retired we will go where it is cool in the summer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-14-2013, 06:49 PM   #19
2005 19' Safari
GLENDALE , AZ
Sorry for taking this thread further off topic. Moderators, feel free to move or delete this entry, if necessary:
I suspect that the actual conditions may determine what is done by bystanders and the police. I'm guessing that a vehicle parked with the motor and air conditioning running in front of a Circle-K, 7-11, Quick Stop or gas station would be less likely to have a window broken out than one that was in a shopping center or employer parking lot with the engine turned off.
The local news media usually reports on dead children left in baby carriers in the back seat, when someone forgot to drop them off at daycare or a babysitter, on the way to work; and a passerby found the body after 4-8 hours. Similar reports with pets.
Per a local TV station, when the daytime temperature is 110, the inside of a car parked in full sunlight will rise to 140 degrees in 10 minutes. I'm unsure how hot a car parked in 118 degree weather would be after 4-8 hours. However, several local people have proven it is hot enough to kill their children.
If it helps any, most were not prosecuted; because authorities felt that the families had suffered enough by losing a child. However, one person was arrested for leaving children in a vehicle; because it was parked in front of a bar where they were inside drinking. Fortunately, this was at night and the children were not injured.
For reference, beef cooking temperatures appear below:
120° - 125° = Rare
130° - 135° = Medium-rare
140° - 145° = Medium
150° - 155° = Medium-well
160° and above = Well done
Old 06-14-2013, 07:35 PM   #20
Central , Mississippi
We have gone out west in July, the key is Go Up! It was 105 near Denver and even with dual AC units, it stunk. A few hours NW between Cheyenne and Laramie at altitude we were able to dry camp very comfortably the very next day.
Our Southern humidity is a different experience, a squirt bottle in dry heat does wonders. Down here it simply spreads around the stinky sweat.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
