10-23-2011, 08:03 PM
one of those
2011 27 FB International
'03 F250 PSD
, Airstream summers, Catalac winters
How do you know you've got a flat?
We are now near the end of our first "real" trip in the new 27FB. Dallas to Wichita Falls to Palo Duro to Taos to Colorado Springs to Ft. Collins.
It's been 'interesting' and a real education in a number of ways. Have a couple questions I hope you experienced main streamers can help me with.
We stayed with friends in Colorado Springs last night and the AS ( now named "Silver Sage") was unplugged and on LP all night. It ran out.
We just switched to our second propane cylinder. Is that about typical for an LP cylinder? All in all we have two nights back in May, low lp use, then five days and nights and 1400 miles fridge using LP, with three of the nights on the furnace with temps around 28-32 deg. The fridge was on LP last night as we were unplugged.
not sure what to expect out of the second cylinder.
And as we came down from Veta Pass, I had to wonder:
How do you know if you have a flat on the trailer while driving? Can you feel it in the tow vehicle handling?
A trucker came over to me at a gas pump near Pueblo and asked about the laser thermometer I was using to quickly check the temps of the tires and bearings. He thought it was a great idea and had never seen it before. An old trucker, been around. Do you guys use them?
Fort Collins KOA is pretty neat, by the way. And Taos....
well.
I want to go back to the WalMart and film a documentary.
10-23-2011, 08:14 PM
Oswego
I do use an infra red thermometer, not laser.
-Rich-
10-23-2011, 08:34 PM
Common Sense
The heater and the water heater are the big users of propane, however that does sound like a short time on a cylinder. We have a heatpump type AC/heater, and an electric water heater, so I may be all wrong on the propane consumption thing.
For tire monitoring, I use a TPMS (tire pressure monitoring system), it's like the new cars have only the sending units screw onto the valve stems, and it will alarm if the tires loose air pressure. It's not a perfect deal, but better than nothing.
Regards,
Steve
2007 27' Safari FB SE
LONDON
, ON
Get yourself a tire pressure monitoring system and you will know just before you get a blowout and have time to stop before damage is done.
Your propane regulator should have automatically switched over to the 2nd full tank. That seems like a lot of propane to go through IMHO.
10-23-2011, 08:37 PM
1999 23' Safari
Perrysburg
, Ann Arbor
That sounds like a lot of propane to use in a pretty short time. I go through one bottle plus a little more in a whole season ... but I try not to use the furnace much, and when I do, I keep the thermostat set pretty low ... in sub freezing weather, maybe 50 or so, then turning it up a bit for showering, breakfast, etc. before heading out somewhere. And I don't run the water heater except for twenty minutes or so before showeirng or dish washing. Are you sure you started with a full tank? Sounds to me as if either you had a partial bottle full, or that you run the furnace all the time and at a pretty high interior temp. ... I'm just back from two consecutive trips: the first three days, 1,000 miles, cooking, showering, etc., three nights light furnace use (temps in 40s-50s), and the second a 3,000 mile ten day trip with nights in the mid thirties to low fifties, ten days of fridge use, cooking, showering eight mornings (2 days in places that had showers), and I'm sure (no gauge, but plenty of experience) that I haven't used half of a 30# bottle ...
As to the IR thermometer yes, I have used one for years, (with a laser to show me the center of the "read" zone), to check tire temps and at least hub temps ... that usually means I more or less coast into rest stops, so that I don't heat up the hubs with brake use. Never had a trucker question it, though I do get some funny looks. By the way, I've discovered this way that my right rear truck tire always runs about ten degrees hotter than the others ... no good reason that I have found. And it's not the tire ... after rotation, the right rear is still a bit warmer. It's also not load or pressure; have checked carefully. It doesn't run hot - just a bit warmer than the others. Of course, if there's much sun, sunside tires run a bit hotter also. That too doesn't explain this particular phenomenon. I'm not worried, but I AM puzzled.
10-23-2011, 08:49 PM
1999 23' Safari
Perrysburg
, Ann Arbor
TPMS does work. I've hear - but never personally witnessed - horror stories of a type that replaces the valve stem, leaking air out of the tires, but at least they tend to report it!
As to the auto-switch-over regulator; many of us keep only one tank valve open at a time. That way, we KNOW when one tank is empty without having to check the regulator. Whenever one runs out, I manually switch over to the other one and get the empty one refilled. It's simple minded, I know, but that way I always have at least one full tank. And when I refill, it's refilling a totally empty tank, so that the guy who only sells by the tankfull rather than by weight or gallonage doesn't get to overcharge me. (I always figured that the manual changeover would just have to occur on the darkest, coldest, rainy or snowy night ever ... but so far this has never happened to me. Good karma, I suppose. )
10-23-2011, 08:56 PM
1974 Argosy 20
Kooskia
, Idaho
Leave both your propane bottles on and the automatic regulator will switch to the new one when the current one is empty (point the switch or arrow to the one in use). When you go to get the empty one refilled, you can just point the switch to the "new" one and disconnect the old one without turning anything off. That way you don't run out, and get cold, and have to re light anything.
Propane useage: Highly variable depending on how you use your water heater, furnace etc. When out full time boondocking, using the refrig on propane only, and hot water on all the time, I figure a 30# tank will run me about 2 1/2 weeks with not much heat on, with heat, maybe 2 or a lot less if it is farily cold out. I am not conservative in my heat or hot water heater use, but am conservative of water itself. My refrigerator is somewhat smaller than your, I am sure, but I keep it very cold.
So, just some more grist for the mill.
10-23-2011, 09:09 PM
Alamo Heights
Hmmm....
Do you have an open diff in the rear? I wonder if your truck somehow routes more torque to the right wheel.
— David
10-23-2011, 09:22 PM
Alamo Heights
I use an IR thermometer with a laser targeting pointer to monitor hub and tire temps as well. I was pleased to find that the Carlisles that came on my Argosy run slightly cooler at 65mph than my truck tires, even in the sweltering Texas summer.
Re: the (good) advice to open both propane tanks and use the auto changeover: Also be sure you check the regulator every day or so to see when it changes over from the empty tank, so you'll know it's time to refill one before you run out altogether.
— David
10-23-2011, 09:35 PM
Salem
, Oregon
Hi, propane usage is too variable. I have had one tank last more than one year and I have used up two tanks in about eight days; Weather conditions were the deciding factor.
I have an infra-red thermometer, but very seldom use it. My hubs are covered so no reading there. [center caps]
I torque all of my lug nuts and set tire pressures just before each trip and never check them again until I'm ready for the next trip. I visually check my set-up at all rest stops, all camp grounds, and all gas stops. I have never had a flat, but I have noticed sidewall bubbles and the start of tread separation and immediately changed those tires. My longest trip so far was to Alaska; It was more than 10,000 miles and for 50 days.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
10-23-2011, 10:51 PM
2009 27' FB International
Los Angeles
Our last trip was ~2.5 weeks and 3,300 miles with rain, cold days & nights (Washington State & Oregon), snow on the ground (at Yosemite) then >100* at Lake Cachuma (Santa Barbara County) for a couple of days. We consumed more than 2 full tanks of propane (1st tank lasted ~5+ days). We were not waistfull in our use, but we were warm when it was cold. When we purchased our AS and asked the PO how long a tank would last, he said he could go a whole season on a single tank. He later told us he had only taken the AS on 4-5 trips during his 2.5 years of ownership (and proudly told us they never once used the shower). I kind of take this as an indicator of "your mileage will vary" when it comes to the use of consumables, be it water, propane, or whatever.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
10-23-2011, 11:22 PM
Grand Prairie
The Do-Whop Whop Whop-The Do Whop Whop...
If you read you're owner's manual, tire pressures may vary. Pay special attention during shakedown and preparation cruises so as to pick up any unusual vibrations... Should yo have a space age tire monitoring devise, by all means also monitor you're rear view mirrors from time to time to allow you to notice smoke and or wheel well parts leaving the scene!
AirsDream, you bring up an interesting point! Most highways deteriorate from the Crown and or left side, over to the brake down side to the right. So as to require an right side drive tire to work harder to keep up! NO??
10-24-2011, 05:00 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Regarding your LP use: You said it was your first real trip. Perhaps the tank wasn't full at the start. Maybe you thought the dealer was giving you full tanks, but they weren't?
10-24-2011, 05:41 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I use a TPMS on all of the trailer tires (the truck came with a factory installation). I find all six trailer tires usually stay within 2 psi of each other. The Pressure Pro system alarms both for high pressure (an indicator of high temp) and of course low pressure. My father-in-law had a flat on a previous Airstream and beat a wheel well and interior cabinets to pieces with the steel cords!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
10-24-2011, 05:56 AM
St. Cloud
Compared to the furnace, the fridge, HW heater & stove use a relatively insignificant amount of LP. A tank will indeed last much of a season if you're not using the furnace. I've had a tank run out in as little as 5 nights of heating. We were running maybe an hour in the evening and in the morning + the overnight.
But I don't like the furnace noise overnight and turn the thermostat down until it's not on a lot -- like, say... 50-55° or so. Target sells some nice extra-heavy fleece blankets. That and a small down comforter go a long way toward comfort. First one up in the morning ticks up the thermostat.
Unlike a house set at 70°, I find our Safari gets too warm if we even approach a 65° setting when we're up and about. There are more cold currents with the bare aluminum interior models; so we keep a throw handy for reading. Your results may vary is the only true fact here.
10-24-2011, 06:27 AM
2023 16' Basecamp
Chgo. N.W. Burb's
I find keeping the tank valve "Closed" works for me. Use to keep both open and it would switch over automatically .Cool idea but "Both Tanks " go empty. Usually at the Least convient time.
10-24-2011, 07:25 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Bob's TPMS works for me also. Cept' I do a cold pressure check whenever possible.
Iv'e only had one on the road tire failure years ago, my own fault....lesson learned, trailer tires require much more attention than most drivers are used too.
10-24-2011, 07:53 AM
one of those
'03 F250 PSD
Thanks for the replies. I'll look into the monitoring systems for the tires. This is an RV rich environment up here, with several big stores over on I-25 south of FTC.
What's the best monitoring system for the propane tanks? Pressure guage? Those stick-on strips?
I suspect we didn't have a full tank to start with from the dealer. We haven't been taking daily showers, but have been leaving the water heater on while parked. I was wondering if anyone had worked out whether it is better to turn it off after use, and then warm it up from ambient all the way to 140 degrees at the next use, or to leave it on and let it run short bursts to maintain 140 degrees. I guess that would depend on how often one needs hot water. I was also considering the fact that the tank full of hot water is inside the trailer, and is in fact somewhat of a thermal bank. I know it's insulated, but it's still radiating warmth into the trailer.
We are digging this SO much we've decided to hang around another day or so here before winterizing and putting her away for the Rocky mountain winter. Having a problem finding inside storage, so we are actually considering buying a fabric cover and storing her outside. Not real happy about that option, but it's a lot cheaper.
10-24-2011, 08:02 AM
2002 25' Safari
Dewey
Pressure gauges only show you when the tank is almost empty and the pressure starts to drop. The strips on the tank only work by pouring hot water on the tank and then looking at the strip. We keep an eye on the regulator and fill the empty tank. We can go several weeks on the road on one tank (30#) if we do not use the furnace.
We leave the water heater on (gas only) when we are setup. The only time it runs is when we use hot water for showers or dishes.
Richard
10-24-2011, 08:08 AM
St. Cloud
Like others, I always leave a full tank unopened in reserve. The stick-on strips are worthless. It doesn't warm up much inside if the fridge runs out of gas on a day's drive if I'm not opening the fridge until later -- when hopefully I look and see the 'check' light.
We turn off our HW heater when we go to bed and turn it off again when done with breakfast (of course, never on when we travel). Your AM/PM usage can dictate when you turn yours on. I find that it stays warm enough that it comes back up to temp in a small fraction of the time it takes when cold. I think overlander63 has commented during times of fulltiming, staying in one spot, that he's had his on continuously for as much as a year -- and he lives in the lower lower 48. [Terry, sorry if I'm off by as much as 11.9 months. My forgetter is getting better all the time! ]
