Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 10-24-2011, 08:19 AM   #21
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
Gringo,
To answer your question...you probably won't know you've got a flat on a tandem a/s trailer if you've got a sufficiently capable TV. I had a blowout a couple of years ago that was preceded by a dull pop that we both heard but dismissed because nothing seemed amiss towing. It wasn't until we went under an overpass and heard a faint slapping of the remaining carcass...some 25 or so miles after hearing the pop. Fortunately, there was minimal damage (broke the wire for the brake) but now I have a TPMS.
Marc
B25guy is offline   Reply With Quote
Old 10-24-2011, 09:53 AM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Yep. We heard the pop, and I looked in the mirror and was able to see the tire. Otherwise, though, I would have had no idea it was ours.
Do research on the TPMS options before buying one. A fellow Airstreamer told me this weekend he'd spent big bucks on a set for his truck and triple axle trailer, and found that the false alarms were too common, meaning it'd be easy to start ignoring it, defeating the purpose. Then they actually DID get a flat and it didn't warn him. (He didn't remember what brand it was.) That was the final straw for them...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-24-2011, 09:55 AM   #23
1975 29' Ambassador
Reno , Nevada
re: "I've discovered this way that my right rear truck tire always runs about ten degrees hotter than the others ... no good reason that I have found." -- check the weight on the tire. Keep the pressure at max sidewall rating. Also keep an eye on the brakes as weight on the tire can influence braking.
Propane has 93,000 BTU per gallon. A typical tank has 5 to 7 gallons. The furnace burns about 30,000 per hour and the water heater maybe 15,000 per hour. The refrigerator is a few hundreds. The stove around 5,000 to 10,000 per hour.
The automatic switchover regulator should be checked regularly, along with propane connections and a sniff test (if you see flies or spiders near your propane connections, it usually means a leak as their nose is better than yours). It is usually most convenient to keep both tanks open and let it do it's thing - but you shouldn't ignore anything on your rig as far as routine inspection and maintenance.
Tire and hub temperature monitoring is easy to do and it is a good idea to do a walkaround and check these and other things at every stop to look for potential problems.
TPMS type systems are probably the best way to get immediate notice of rapid tire deflation, though.
Old 10-24-2011, 10:12 AM   #24
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by Gringo View Post
Having a problem finding inside storage, so we are actually considering buying a fabric cover and storing her outside. Not real happy about that option, but it's a lot cheaper.
I'm pretty certain you will be even less happy about what a fabric cover will do to the clearcoat finsih in your Airstream after a season or two. You'd be better off to store it outside without a cover touching the skin than with one.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-24-2011, 10:17 AM   #25
SteveH's Avatar
Common Sense , Texas
Shari
I'll agree with that.
Regards,
Steve
Old 10-24-2011, 10:59 AM   #26
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I would think that on a dual axle trailer it is quite possible to have a flat and not know it until the tire starts to fly apart and then you will most likely feel vibration through into the tow vehicle - and quite possibly have costly trailer damage.
I use a TPMS system - it isn't a 100% guarantee, I suppose you could still have an instantaneous blow out. Under that condition, the TPMS would of course warn you, but by the time you got the trailer stopped damage could already have occurred.
What it will do is warn you of a slow leak and allow you to address the problem before the tire heats so much that it starts to come apart.
I do like to have the TPMS for increased peace of mind. But I also do a walk around at each and every stop and examine the tires for any visible problems and either feel the hubs or dig out my IR thermometer.
I also change tires every five years, and recently moved to a higher range tire because the weight of my trailer was such that as pretty much at the top end of the range tire that was fitted - I felt that moving to a higher range might give a little extra margin of safety. I'm not really sure of that though!
Finally, I have reduced the speed that I travel at - Before I realized that trailer tires are supposedly only rated for 65mph, I regularly ran at 75mph or more - now I rarely exceed 65.
I seem to be getting more safety conscious in my old age! Maybe I'm just not in a hurry any more!
Brian
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-24-2011, 02:10 PM   #27
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Real Life Story. Like many others we run a TPMS with varying results. Most annoying are the "lost sensor" alarms (always false so far). That said, we got a 57 lbs. low pressure alarm in Russellville, Arkansas, about .8 mile from camp. We rolled in and stopped to take a look. One of the four was slowly loosing air, and was somewhat worn looking. Popped it off the next morning and located the local Goodyear dealer. Had it replaced before 9 AM. Saved our bacon.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 10-24-2011, 02:19 PM   #28
"Cloudsplitter"
Forget the T...
that's the alarm that would save your bacon more than once.
Old 10-24-2011, 02:28 PM   #29
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
..... I suspect we didn't have a full tank to start with from the dealer......
Gringo,
There is a new(?) type of propane tank on the market. They are transparent so you can see exactly how much fuel is actually in the tank. However they are expensive ($$$$$$) and I don't think they are rated to last as long as a steel tank. One of the brands I have seen is Clearview but I have only seen 7 lb and 20 lb tanks in the stores. I 'think' they also come in a 30lb size (and larger). Because they are made out of fiberglass they weigh much less than steel. I would love to upgrade to these, but haven't been able to justify the cost.... yet...
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 10-24-2011, 08:09 PM   #30
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Thanks for the advice. We drove from Ft. Collins down to Boulder and back today. This place has literally thousands of RVs stored in yards outside all over the place. We are feeling better about leaving Silver Sage for the winter. I am studying up on the winterizing.
What do you guys do with your batteries if storing for the winter in sub freezing conditions, and no electricity. Do you remove them? Does a trickle charger like one of those solar doo dads make any sense? Does a charged battery not freeze?
I am a little puzzled about the advice to remove them from the trailer that I read in some of the AS lit. I used to travel the world extensively in my job, and I remember leaving my vehicles parked in outside long term airport parking for a month or two at a time without any battery damage.
A Blog from the Devil's Triangle
https://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 10-24-2011, 08:46 PM   #31
CanoeStream's Avatar
St. Cloud , Minnesota
Charged batteries won't freeze. Loss of charge that might concern us could take several weeks to a month. Left wired in place, some parasitic drain from the coach will accelerate that slightly (taking 2-3 weeks instead -- I don't know enough to say for sure). This sounds like a prime situation for a small solar recharger. I recall hearing about one that sits inside the front window. Don't know much about it otherwise. You'll want to scrounge for more info on that.
I normally wouldn't say this, but removing the batteries doesn't sound like a good idea unless somebody responsible could put them on a battery minder every few weeks to a month.
The roof can take any amount of natural snow & ice with minimal to no chance of damage.
5 meter Langford Nahanni
Old 10-24-2011, 11:05 PM   #32
one of those
Gringo's Avatar
yeah, I was thinking a solar charger inside a south facing window wiring routed under the bed and out the hatch. There must be a smart one somewhere that monitors the batts. I appreciate the comments on the cover. It makes sense that it would scuff the surface with coase fabric chafing, and dust accumulation. This is all great information. Do you think covering the tires is worth it? Or is it a good idea to euthanize these Marathons and buy my first good set in a year or two?
I kept the speed control pretty much on a max of 65-66 mph almost all the way. I might have hit 68 to squeeze past something a time or two. The rented ford would have pulled that trailer up the side of Pikes Peak at 65, or at least it felt like it. Could smoke the rear tires, despite the fact that I never got the Reese installed and all the tongue wt. was on the rear of the truck.
If the opportunity presents itself, I now have some tales of fighting for control while spinning tires and sliding backwards down a steep gravel driveway in the mountains. It never occured to me that the new trucks have manual hubs again....
and then there were some backing up tales.
Old 10-25-2011, 03:52 AM   #33
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
They are right in the matter of a (or any kind of cover) that makes contact with the skin of the Airstream...It will leave all kinds of marks and blemishes that you could only begin to imagine. Just park it. But do not park under a tree (tree sap and falling limbs)...and especially if there is a hawk thats made its home up there (the other falling stuff... ...)
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 10-25-2011, 04:50 AM   #34
"Cloudsplitter"
Gringo,
WNY Winters....the AS batteries come out. With the IOTA converter I can isolate the cables and still plug in with no damage if I need power in the coach.
I use a Battery Minder on the 6v Ford battery stored in unheated garage, no freezing problem.
The AS & boat batt's get charged and stored indoors, with no draw they will stay fully charged for several months, re-charged with a Vector 1093 when needed.
Not much Winter Sun for solar around here.
BTW...I would not cover if stored outdoors.
Old 10-25-2011, 06:04 AM   #35
1977 Argosy 24
Milltown , Wisconsin
Originally Posted by AirsDream View Post
By the way, I've discovered this way that my right rear truck tire always runs about ten degrees hotter than the others ... no good reason that I have found. And it's not the tire ... after rotation, the right rear is still a bit warmer. It's also not load or pressure; have checked carefully. It doesn't run hot - just a bit warmer than the others. Of course, if there's much sun, sunside tires run a bit hotter also. That too doesn't explain this particular phenomenon. I'm not worried, but I AM puzzled.
I bet you have a right rear brake that is dragging.
ventport is offline   Reply With Quote
Old 10-25-2011, 06:52 AM   #36
one of those
Gringo's Avatar
The problem for me in taking the batteries out is that I have no place at all to secure them. I guess we could rent a small heated storage facility, and keep batteries in there over the winter, if I can find one. I am going to look into solar chargers today. They really wouldn't need much charge to keep up from totally dead, I don't think. We have two sunroof type windows in the top of this AS, I am thinking that I might be able to suspend a solar panel in the top one, and maybe a second one wired in parallel....if I don't get enough output from the first one. But a couple hours a day of sun, average, should be enough, maybe?
Old 10-25-2011, 07:47 AM   #37
1975 29' Ambassador
Reno , Nevada
Batteries need proper maintenance during storage for best performance. That means keeping a full charge and also applying a sulfation inhibiting technique.
A float charge alone is 'old school' and insufficient as far as sulfation inhibiting goes.
A good converter such as the one with the Charge Wizard or some others will provide good battery maintenance. They make trailer batteries a simple matter of keeping the trailer plugged in when not in use.
I have only recently started to see solar charge controllers that provide storage maintenance features.
Old 10-25-2011, 07:56 AM   #38
one of those
Gringo's Avatar
Its not like I have a lot of choice. I can't think of any other way to keep the batteries from going dead. And I am not really worrying so much about 'best performance'. I just want to keep them from freezing over the winter with no other souce of charging current.
I am thinking of something simple like the 5 watt solar panel Harbor Freight carries. I wonder if I still need a controller, since it will be charging two batteries. That's not much charge per battery, and the winter days are short this far north. I am looking at the two sky lights in the AS, and thinking I could suspend this thing in the forward one somehow. There are two layers of plexi between the inside and outside, but it's thin and clear plexi. Not anything like the heavily shaded glass windows. It weighs 4 lbs and I can run alligator clips directly to the batteries instead of trying to plug it into an internal 12 volt connector. I guess I could also wire up a connector for that round 7 conductor that connects to the tow vehicle, but alligator clips seem simple and cheap.
Old 10-25-2011, 08:45 AM   #39
SteveH's Avatar
A 5 watt solar panel will only put out about 400 milliamps, and if you have two batteries, that's only 200 milliamps per battery.
Not enough, even if the panel is in direct sun light and angled at the sun, but you would not need a controller.
Regards,
Steve
Old 10-25-2011, 12:41 PM   #40
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The problem is that lead acid batteries discharge on their own over time. Even with the battery switch set to store, most trailers keep the LPG detector energized, a small but incessant drain on the batteries. In an ideal situation you would have a way to either maintain them with something like a Charge Wizard or set a timer to charge them for a day once a month.
In your case you are pretty much limited. Remove the batteries and take them home, or rig up a solar charger.
The smaller panels like you mentioned don't need a charge controller and they don't have the capacity to truly charge a battery like their bigger siblings. But they can compensate for parasitic loss and self discharge. Temporarily mounting one under a skylight seems to be a possibility. You could put a cigarette lighter plug (observe polarity) on the end of the cable and plug it into the 12v power point in one of the TV connection wall plates. Or you could permanently mount it or a slightly larger panel on the top of the A/C shroud and run the cable down the fridge vent and tie it into a hot 12v line in there.
A few concerns here... These panels are more efficient if they are angled to face the sun. A horizontal panel works but not as well. Snow! It might take several days for the snow to clear off a panel or skylight, further reducing its effectiveness. Several storms in succession could defeat the small daily gains you would otherwise want. For both reasons a panel facing south angled to catch the winter sun would be desirable. Another concern besides the efficiency of different designs and compositions of solar panels, some incorporate a diode in their design and some (lower cost ones) do not. The diode prevents the parasitic drain the panel would otherwise impose on the battery when it was in the dark.
A proper solar panel is a solution if you don't want to take the batteries home. I don't know haw effective a 5 watt panel will be in your situation. Remember how the battery storage switch works and understand that depending on how you make your connections, you have to think about that switch... Example, using the cigarette lighter plug may require the switch to be on rather than in storage.
Being an experiment, I would like to visit the trailer in storage monthly to: a) put a meter on the batteries to see how the system is doing. b) make sure the solar panel didn't grow legs if mounted externally.
Some might suggest that if you take the batteries home, take the wheels also.
AIR 47751
Silver Goose is offline   Reply With Quote
Pilot on but burner flame is flat Rob1966 Refrigerators 3 09-26-2011 07:07 AM
OEM Flat Detector on 81 Excella II perryg114 Tires 0 09-12-2011 04:59 PM
Flat Pack Cabinets for RV's ExcellaNewby Cabinets, Counter Tops & Furnishings 1 09-03-2011 01:55 PM
Zipdee flat fold chairs Farmer Dan Off Topic Forum 11 05-03-2011 07:50 AM
Custom Flat Beds MrBeast Tow Vehicles 7 03-09-2011 01:08 PM
