Old 10-19-2015, 03:40 PM   #15
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Originally Posted by '55 Airlight View Post
Also, when dealing with difficult to locate utility pole services while boon docking, I have found it handy to carry one of these. Especially at music festivals or rallies on big grassy fields, this'll make your neighbors go absolutely apoplectic. (Wish I could say I built it m'self, but that'd be far from true.). Michael
Or out in the middle of nowhere... That's hillarious, Michael! 👍
Jaxon is offline   Reply With Quote
Old 10-19-2015, 04:05 PM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Over the years, we have found several little tricks that help with making and breaking camp.
When it come to water hook-ups, we have found that garden hose brass quick-connects really speed up the process. If you decide to use these, get the solid brass ones that they sell at Tractor Supply Company (best price). Don't get the aluminum ones. They are junk.
We use a short stringer hose to a "Y". Then we use curly spring hoses from the "Y" to the trailers connections (city water and Sewer Solution). All of our hoses are rated for drinking water. All of our water hose connections are via quick-connects.
We also use the "push on" coax cable connectors.
Brian
SuEllyn & Brian McCabe
Old 10-19-2015, 04:13 PM   #17
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Nice photo, saved it to my someday trailer file.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 10-19-2015, 04:46 PM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by rodsterinfl View Post
Greetings
I did not see a specific thread on such a topic but I thought it pertinent as I want to know and others may also have an interest. So many have learned short cuts and products that may help. Usually as a solo camper, I am interested in not taking an hour setting camp. One of the caveats to RV trailer ownership besides backing that I have heard is the extra work of de-hitching and extra connections.I do not find the de-hitching that difficult but let's discuss connections and/or de-hitching time savers. My contributions and questions below.
Looking at it more broadly, I don't find that the connection of hookups contributes much to the time required to set or break camp. Takes more time to get out and put away hoses, cables, etc., set stabilizers and pads, fuss with hitch, awning, windows, camp chairs, grill.
We typically don't use any hookups except electricity if we're only staying one night.
LP generator line:
One solution, I recently got a quick connect for my LP generator line which saves me about 5 minutes in a boon docking situation. Ironically all but one evening when I hooked up the generator this summer it was pouring rain. I could have been so much faster with a quick connect line. Now, is there a type of connector that better holds the weight of the trailer AC cord to the side of a generator if using a standard 2 prong/30AMP adapter?
You could retrofit both the generator and the cord with a twist-lock connector with a suitable rating. If you do that and have a dedicated generator cord you may be able to use smaller and lighter cable that is sized to match the output of the generator.
Water line:
This one is IMO the messiest. Often the spigot threadings are thin and for some reason difficult to get the hose connected. Any fast options here?
It's the last thing we hook up. We just use the water from the tank until a more opportune time, if we're in a hurry.
Leveling:
I got a two-way level for the trailer tongue and the legos for use under the jack and on a side if needed but it takes more time than I would like as it is a small level and also requires guessing how many legos and more moving before done. Ideas? Any place to mount a large balance viewable from the truck? Is it worth it?
I have a large level mounted near the top of the propane compartment. I have 40# tanks so it's up fairly high. If I raise the liftgate on my Suburban, I can see it from the driver's seat.
Stabilizers:
I use a cordless drill for these and the PP3 hitch weight jacks and add legos to shorten distance.
I used a cordless drill for a while and went back to the crank. The drill doesn't save as much time as you might think, and it's one more thing that has to be carried along, charged, and accounted for. I don't worry about people stealing the crank so I just set it behind the propane box when I'm at the campsite.
You might be interested in the "elephant feet" product. They are oversized feet for the standard stabilizer jacks, that are supposed to eliminate the need for placing a block of wood under the jack to distribute the weight. They stay on the jack in place of the factory foot, so it's one less thing to have to handle.
Old 10-19-2015, 07:33 PM   #19
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I second Jammer's comment about the electric connection. My wife built a second power cord for our trailer, with standard household-type plug on one end and a 30 amp trailer fitting on the other. The pieces came from Lowe's. They had normal and waterproof versions of the fittings. The cord itself is smaller and lighter than the normal cord because it doesn't have to handle as much current.
The other thing would be a "dogbone" type adapter to go from the generator to the regular trailer power cord. This type of adapter is less likely to pull out of the socket. For example: Amazon.com: Camco 55165 15M/30F 12" PowerGrip Dogbone Electrical Adapter with Handle: Automotive
SSquared is offline   Reply With Quote
Old 10-19-2015, 07:48 PM   #20
olympia , Washington
(Just making sure you're not actually suggesting "the normal garden hose type" for a potable drinking water hose.)
Michael
This is awesome!
Xicaque is offline   Reply With Quote
Old 10-19-2015, 08:07 PM   #21
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Campgrounds sound complicated.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-19-2015, 10:32 PM   #22
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Originally Posted by FollySteve View Post
Love it !! Ask them, "What, you didn't get full hook ups?!"
"There're a bunch of utility full hook up poles around; just gotta look for 'em..."
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 10-20-2015, 01:42 AM   #23
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Brian
I guess my question is that if your sewer solution backflow preventer fails, and you discover it only later, how do you tell which hose went into that system? This is the unlikely and "unforeseen" circumstance I envisioned when I went with green hoses for flush and sewer solution and kept the white only for fresh water and mister.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is online now   Reply With Quote
Old 10-20-2015, 09:29 AM   #24
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
WestieHouse - I use two as AStreamNerds suggests. With the Anderson's it's simple and there's no stress on the frame which leads to "door slam" problems.
The Ice Man is offline   Reply With Quote
Old 10-20-2015, 11:29 AM   #25
2015 23' FB Flying Cloud
Redmond , Washington
Thanks, Ice Man. Makes good sense to use two Andersons.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 10-20-2015, 01:17 PM   #26
IanPoulin's Avatar
Aldie , Virginia
I know I am tangential slightly, but the jury is out on my Anderson levelers so far. I've had a few situations already where on soft ground, the "set" block re-adjusts during the week allowing a 1-2" drop and loss of adjustment. still playing with it though.
Old 10-20-2015, 07:34 PM   #27
moosetags's Avatar
I've got about 1,700 nights on the Sewer Solution. The back flow preventer has never failed. I'm just not going to worry about that.
Brian
Old 10-24-2015, 03:15 PM   #28
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Some fantastic ideas. I am getting the hose. My Never Kink always kinks and is a mess.
Re: WiFi/HDTV AIR:
Those that still have the crank Winegard have some options to add WiFi and even a new frequency HDTV antenna to the batwing mount. Crank it up and you have your antenna array ready to go. Turning it is nearly a mute point with the new antenna so I rarely have to mess with it once lifted. Saves time.
Please tell me more, link, etc., on how to update the crank winegard with WiFI and the new HDTV antenna.
Yes, the antenna update "kit" I got from Winegard. It basically uses the crank up system already in place for the batwing but you remove one rod. The kit for those that have a batwing is:
Winegard Rayzar Air - RV HDTV Antenna, RV Antenna
they also have the fully automatic disc model but I do not know how well it performs.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Full hook-ups close to Port Orchard, WA? DianePhx On The Road... 2 07-23-2014 12:07 PM
hook ups for water tank , pump and tie ins batt Fresh Water Systems 3 10-03-2010 07:10 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Hook ups? watt1968 Plumbing - Systems & Fixtures 12 05-01-2008 05:53 PM
West Cheap or Free Hook-ups - MT CTHilmo Boondocking 3 04-09-2006 08:45 AM
