Old 08-22-2015, 11:05 AM   #43
2015 28' Flying Cloud
Newtown , Pennsylvania
With loads around 1500 watts, like a microwave, 2 Honda 2000's loafing along are definitely quieter than one screaming Honda 2000.
Bruce
AstroBruce is offline   Reply With Quote
Old 08-22-2015, 12:06 PM   #44
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Originally Posted by Moflash View Post
Never any problems with carbs but as with everything that I own that burns gas and sits I always add Seafoam fuel additive.It keeps the fuel fresh and the algae growth at bay.
You cant go wrong with Yamaha or Honda.These little Gens sip very little fuel.
This is a smart thing to do, and I also use ethanol free fuel. Seafoam fuel additive and ethanol free fuel combination, can't go wrong using this combo in all your small engines and boats, etc.
Hiho Silver is offline   Reply With Quote
Old 08-22-2015, 12:56 PM   #45
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
Don't think I have ever seen ethanol free fuel for sale. Where would you buy it?
firstwave is offline   Reply With Quote
Old 08-22-2015, 01:04 PM   #46
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Originally Posted by firstwave View Post
Anybody know about how long one of these would run (if converted) on 20# of propane?
Not yet. I purchased one of the little 2000 Honda's a month or so back and immediately converted it to propane.
I've been putting off posting a review (including the horrible buying experience with a well known dealer of Honda generators) until I get a chance to include some performance numbers. (things like, how long will a 20# propane bottle last)
We're headed to the Alburquerque Balloon Fest. in early Oct. that will be my first chance to really give it a workout.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 08-22-2015, 01:18 PM   #47
Here is a link for ethanol free gas locations.
Ethanol-free gas stations in the U.S. and Canada
Old 08-22-2015, 01:20 PM   #48
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is widely available in our area.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-22-2015, 01:28 PM   #49
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Ok, gang. Firstwave's question got into my head like a bad BeeGees tune. I decided not to wait until I was loaded for our upcoming trip (or forced to flee approaching hurricane Danny... whichever comes first).
I pulled the Hondas out of the garage, grabbed two 20 lb LP bottles and the digtal bathroom scale and started my test.
I weighed each tank using the scale (also weighed a case of water as a "control" to assure reasonable consistency of the scale from start to finish of the test), plugged a hair dryer into each generator to simulate a load, turned the EcoThrottles "off", and fired them up (since they've never seen gasoline, they started on the third pull even after sitting in a hot garage for over a month) and started the stop watch.
After 30 minutes I switched hair dryers between the generators just in case they were not the same wattage (I was trained as a scientist... I couldn't help myself... one variable neutralized). After an hour I turned off the gas to each, unhooked and reweighed both the water (which was precisely the same as before to the 1/10 th of a pound) and the two bottles.
The answer I got was that each bottle was 2.0 pounds lighter than at the start.
Since a 20 lb LP bottle doesn't actually hold 20 lbs of LP (typically a full cylinder delivers 17 to 19 lbs before its exhausted... and blue rhino and Amerigas reportedly only put 15 in theirs) that says a generator running flat out will empty a full 20 lb cylinder in about 9 hours of operation.
Since a propane refill costs about $15-20, propane costs about $2/hour per generator at full load. Since the same load reportedly runs an EU2000 for 3.4 hours on one gallon of gas which at $2.50 per gallon is about 75 cents per hour, propane is way more expensive. Like others have reported, I chose propane because it seems safer to transport under my black tonneau, I can use the 30 lb bottles on the AS or carry 20s on the generator platform and I believe LP saves me from the reliability issues of gas left in carbs (or the need to manage that problem with additives, carb draining, etc). Other folks make the choice for gas for equally compelling and valid reasons that suit their needs. However, if fuel cost is driving your choice, GO GAS!
Now, on to the question of "what can I run with one, or two Honda EU2000s?". I mentioned yesterday that I cannot run my factory installed AC (a Dometic Penguin II 15,000 BTU AC/heat pump which Dometic says draws 13.4 amps for the compressor plus 2.6 for the fan or 16.0 amps total) and microwave (Sharp carousel micro/convection at 12.5 amps as a microwave, more in convection mode) at the same time with the two EU2000s in parallel. I did not mention that there are other loads on the system. The other biggie is my aftermarket Progressive Dynamics 4655v converter/charger. The 55amp (DC) model draws up to 950 watts or 7.9 amps of AC.
When I fire up the generators and connect them to the trailer and want AC I assume that the converter usually wants all the power it can draw to charge batteries and handle the 12v load. Let's do the math...
16.0 amps of AC plus 7.9 amps of converter (23.9 amps total) at 120 volts is 2,868 watts. The Hondas are rated at 1,600 each continuous.... 3,200 for the pair. 2,868 is under their capacity. All is good. Now, GammaDog wants a frozen burrito to become a mouth burner and kicks in 12.5 amps of microwave and the total is 36.4 amps or at 120 volts 4,368 watts. That exceeds both the sustained 3,200 watt and max 4,000 watt output of the pair of Hondas and nasty things happen since the resulting voltage drop is bad for the burrito and any device on the system. (Has your "30 Amp" Airstream ever tripped a 30 amp breaker on a campsite pedestal? Mine has. Now you see how that happens. The breaker was likely working as designed. Thank you Square-D!). If the converter happened to be asleep at the time I hit the microwave "go" button the AC and micro would have worked. I know that it's a "smart charger". It might be smart enough to take a break now and again. If you had a similar experience and said "gee... that wasn't a problem last time I ran the micro and AC at the same time" it could be that "last time" your converter was not drawing full power to charge low batteries when you asked the microwave to cook your dinner.
The solution is to turn off any one of those loads so the other two don't overload the generator pair.
One final thought... To answer the "can I pleeeeeease run my AC on just one Honda 2000?" question. If your one AC is a Dometic Penguin II 13,500 BTU model (for which my Dometic manual lists power needs) it uses 12.7 amps at 120 volts for the compressor and 2.6 for the fan. That's 15.3 total. At 120 volts that's 1,836 total. That's over the sustained rated power of the Honda EU2000 but under the max. I'm not sure how the Honda responds to that. Maybe someone with actual EE training (I said I was trained as a scientist... and I chucked that for a business career anyway... I never would have made it as an actual engineer) can tell us. If it responds with a voltage drop, 15.3 amps at 1,600 watts would have to deliver 104 volts. Hard on the compressor? I don't know. I wouldn't do it. In any case, adding any other load - even "just the converter" - would easily exceed the Honda's capability. The even smaller 11,000 BTU penguin II is 1,572 watts for compressor plus fan and would fit as the only load on a single Honda 2000 rated for 1,600 watts continuous.
There... I'm glad I got that off my chest. Now let's hear from people with actual knowledge in how this stuff works. I'm either going camping (heading to western New York then Maryland then the outer banks including two times with the truck and trailer on the NC ferry system!) or running like a scalded dog from Danny.
My next test will answer an earlier question... Since I sometimes run my generators using a tee fitting from the LP port on the AS, is there sufficient gas flow in the trailer to deliver 3,200 watts of electricity and run the fridge, stove and hot water heater? Stay tuned....
GammaDog is online now   Reply With Quote
Old 08-22-2015, 01:51 PM   #50
Rockingham , North Carolina
'People with actual knowledge' I am not.
Almost didn't bother replying after reading the requirements. Hope you don't mind me chiming in. But I did confirm what I thought in my earlier reply in that with a certain quality solar system, utilizing a hybrid converter, you can run the air conditioner with a single Honda 2000 generator.
If this is of interest to anyone I suggest you contact Lew Farber here. His contact info is also listed on AM Solar's website as one of their few approved installers. He is an 'EE', over winters in Florida (near OP), and is sharp as a tack.
At this point I've merely exchanged a few long winded emails with Lew, but we will have him design and install a solar power system in our 30' Serenity when we buy it.
Dan
"The wilderness holds answers to questions man has not yet learned to ask."
- Nancy Newhall
Danattherock is offline   Reply With Quote
Old 08-22-2015, 04:46 PM   #51
dznf0g's Avatar
Oswego , Illinois
I'm a bit jealous of my Bro-in law. He can run his A/C on one EU2000i. He bought a little 16' SOB with a 10 - 11000btu (I forget exactly) A/C. Specs say 16A on startup and 11.4A running.
-Rich-
Old 08-23-2015, 06:36 AM   #52
1990 34' Limited
grosse pointe , Michigan
Just yesterday I tried to use my Honda 2000 generator and it is not enough to run the ac on my 34' limited. I'll have to by a companion to it. They are so quite and lightweight its worth it to me.
shantycreek is offline   Reply With Quote
Old 08-25-2015, 11:41 PM   #53
lewster's Avatar
Naples, FL , Hood River, OR
You called ????
The system Dan has mentioned involves a minimum 400 amp/hour lithium battery, adequate solar and a Magnum MSH3012M 'hybrid' inverter/charger.
I have started a Dometic 15K A/C from the inverter/battery alone with a calculated run time of 2.6 hours before the lithium is depleted.
I have also used a Honda 2000 coupled with the Magnum to start and run the same size A/C. The hybrid/lithium combination seamlessly supplements the 2000 watt generator output to cover the transient amperage surge required to start the compressor.
After the compressor settles down, the Honda (or Yamaha) takes over the full operating load of the A/C unit.
All amperages were verified thru a Blue Sky iPN - PRO solar remote with a 500 mV shunt. Once the compressor stabilized, the amp draw from the batteries approached zero.
Can it be done........absolutely! But it sure ain't cheap!!!!!!!!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-09-2017, 11:28 AM   #54
lynnsoltys's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
BambiTex, ever get an answer about the WEN?
lynnsoltys is offline   Reply With Quote
Old 06-09-2017, 01:29 PM   #55
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Originally Posted by KJRitchie View Post
Are two EU2000s running together in companion mode noisier than a Honda Handi 3000w generator?
Kelvin
I have two Yamha 2000i's running together and there isn't much of a noise increase if any.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 06-10-2017, 09:19 AM   #56
lewster's Avatar
Two words to enable you to operate your Dometic roof A/C from a single Honda 2000.............EASY START!
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda EU2000i Generator Mount for Bambi Teton Stream Boondocking 53 09-28-2014 11:43 AM
Honda Generator EU2000i Theft Deterrent Bracket z8 hm Generators & Solar Power 1 02-17-2012 04:47 PM
Honda EU2000i Generator Pricing Jan.2005 markparker22 Generators & Solar Power 12 11-23-2005 06:49 AM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
