Old 03-17-2014, 10:27 PM   #43
mefly2's Avatar
2015 25' FB Eddie Bauer
We have used twin EU2000is / companion with excellent results BUT avoided running the AC and microwave at the same time on both our FC20 and Eddie Bauer 25. We traded in one of the EU2000iS on a EU3000iS ... and have never looked back... the 3000 wide open is nearly the same loudness as ONE of the 2000s at idle! The EU3000 is VERY quiet! We also like the electric start and suggest the 3000 IF you have a place to leave it in one place in your TV as it is truly a job to move it around - even with the wheel kit- due to the weight. However, the two EU2000s were not all that much easier - don't confuse the weight of the 2000 with the weight of the 1000 (check the Honda website for specs on weight and loudness when running as well as fuel consumption).
Our EU3000iS lives in the bed of our TV covered with a topper. We like the 3000 so well that we will likely be trading in our remaining EU2000iS Companion on another EU3000 !!!
Our Honda EU 3000iS powers the AC or the Convection Microwave without incident on our 25 Eddie ... recommend it hands down as the best choice ...YMMV, however.
Old 03-18-2014, 07:21 AM   #44
nilesrob's Avatar
Marietta , Georgia
Images: 12
I have both a Honda 3000 and a 2000, both great. The benefits to the 2000 are cost, weight and space. If you bring two 2000's, then the benefits of cost, weight and space are probably a wash.
Clearly the 3000 is quieter, and like others have posted I load the 3000 in the truck bed and never move it again on a trip; love it. The 3000 is always my preferred generator to bring unless really crammed for space or if I am bringing a generator just in case but with no intention of using the air conditioner in the trailer.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 03-21-2014, 11:53 AM   #45
robert@honda's Avatar
Alpharetta , Georgia
Honda guy here...
EU2000i (all models) has a 100cc GX-series commercial grade engine, with a diagonal split-block design, aluminum block, cast-iron cylinder sleeve, overhead valve and overhead composite ("plastic") camshaft. It has an internal timing belt and a 3-year warranty. FYI, there is no replacement interval on the timing belt; timing belt failures are extremely rare on this model.
http://powerequipment.honda.com/gene...models/eu2000i
EU3000is has 200cc GX-series commercial grade engine, with a traditional block and cylinder head, cast-iron cylinder sleeve, overhead valve (pushrod design) and metal timing gear and camshaft. It has a 3-year warranty.
Honda EU3000iS Super Quiet Generator – 3000 Watt Inverter Generator
EU3000i (a.k.a. "Handi") is the same as EU3000is but has a smaller 160cc engine and is pull-start only. FYI, the Handi is only 76 lbs and has a magnesium center spar to keep the weight low (but the cost high ).
Honda EU3000i Handi Super Quiet Generator– 3000 Watt Inverter Generator
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 03-21-2014, 10:23 PM   #46
Airstream Voyeur
hwyranger's Avatar
Northern California , California
When I ran the 3000 with the Moho, I only ran the A/C, and it was at 1800' altitude. After 10-15 minutes (I was inside when it stopped) it quit powering the 14.8 BTU A/C and shut down. If I remember correctly, a circuit breaker was tripped somewhere too. The onboard Onan 4000 powers it fine.
hwyranger is offline   Reply With Quote
Old 03-22-2014, 06:40 AM   #47
Gainesville , Florida
And the Handi 3000 is much louder. Jim
Old 03-23-2014, 06:56 PM   #48
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
I ended up buying 2 x 2000i Hondas I like the versatility of 2 and they are light. I figured it was worth the cost as can I run everything and have confidence in the Hondas lasting a long time.
LoveSally
ILOVESALLY is offline   Reply With Quote
Old 03-24-2014, 12:52 PM   #49
The 3000 handi is much louder than the normal 3000. Jim
Old 03-24-2014, 01:26 PM   #50
The 14.8 is too much for a 3000. Jim
Old 03-24-2014, 03:28 PM   #51
HowieE's Avatar
Princeton , New Jersey
Images: 12
What else was on during this period. The frig on electric? The convertor on? Anything else on 110 volts ac?
2004 Excursion 4x4
Old 03-24-2014, 04:34 PM   #52
Bainbridge Island , Washington
Lurking
I've been a prospective buyer, enjoying the education lurking and finally signed up. This may be a bit off topic, but I'm going to require a generator and what do those of you without trucks do about fuel for them? A single cab pickup doesn't come with the creature comforts we want, a super cab won't fit in the garage and I don't want to drive around in something like a Tahoe or Denali smelling gasoline on a 3 month trip to Alaska. I don't even like coming home with gas for the mower. We're more of the dry camper types and figuring out what to do other things like a shovel is challenging with the very limited outside storage in the trailer.
Al
donaal is offline   Reply With Quote
Old 03-24-2014, 04:51 PM   #53
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Al
Many people convert their generators to run on propane (or buy them already converted by one of the vendors that supply them that way.)
— David
Old 05-10-2014, 09:17 AM   #54
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Recently found that 2 X EU2000i isn't an option with Canadian Hondas. They never received the necessary safety approvals here, so the EU2000i comes without the necessary connectors. And the EU3000is is a little too tall to fit under most truck tonnes.
Arghh!!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 05-10-2014, 10:51 AM   #55
TinTin's Avatar
Canmore , Alberta
Whoops, tonnes = tonneaus
Bob and Nancy
Old 05-10-2014, 11:35 AM   #56
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Correction on my posts. Honda generators 2000 and below have a PULLEY system. I shared with my generator selling father about this thread. Here is the info from him.
"the Hondas are using a pulley system to get more out of a smaller engine. That is not a timing belt per se, it would put more of a strain on the engine when a load was on it but make it more efficient when idle. Still, a direct drive is always a better solution. It looks like the two companies have gone about it differently."
Those that posted that Honda does not have a belt are incorrect. Also, you cannot compare a car timing belt to this application. The lifespan rating by the EPA on the generator tells a story too. I made my purchase decision as many of you have; however, that does not mean bias should enter into fact manipulation for any of us. The Honda 3000 does not use a belt but the boost technology relating to motor use is a bog boon for those wanting to run engines. The reason the belt is not mentioned in the manual is because it is not considered a user serviceable item. I believe with the current models and pricing that the Yamahas, purchased new, are a better choice so I share that information. That's all. whoever can make their decision.
Also, any single AC application available can be handled by this 3000 watt model:
EF3000iSEB
3000 watts (+500 watts boost)
Rated AC Output 2800 watts
Rated / Maximum AC Current 23.3 / 25 amps @ 120V
Engine OHV, Air-Cooled, Four-Stroke, Single Cylinder
Displacement 171cc
DC Output 12 amps @ 12V
Ignition System Electric w/Recoil & Auto Decompressor
Overall Length 26.8 in
Overall Width 17.5 in
Overall Height 21.9 in
Dry Weight 154.3 lb
Fuel Tank Capacity 3.4 gal
Continuous Operation at 1/4 Rated Load 19 hr
Noise Level 53 -60 dBA
Warranty 3 Years Limited Warranty
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
Honda 3000i Handi for late 70s Sovereign? Airstream Dad Electrical - Systems, Generators, Batteries & Solar 6 10-13-2011 01:42 PM
Paralleling Honda 2000i, and Eco system Headhog Generators & Solar Power 18 09-17-2011 04:04 PM
Honda 2000i and AC ShawnG17 Electrical - Systems, Generators, Batteries & Solar 22 07-22-2011 10:39 AM
Honda EU 3000i generator for sale rando Generators & Solar Power 2 05-12-2011 10:30 AM
