Old 03-06-2014, 11:38 PM   #15
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Originally Posted by Grand Master View Post
I chose the Yamaha 2400 for our Trade Wind with a Dometic 13,500 AC and have been very satisfied. Trouble free, quiet, and light enough that I can carry it.
I couldn't agree more, it is a beauty.
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 03-07-2014, 01:20 AM   #16
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
By comparison, will the Honda 3000 run longer, fuel capacity wise, compared to the two EU 2000 Honda's? I believe the weight on the 3000 is 170lbs?
Luigi123 is offline   Reply With Quote
Old 03-07-2014, 04:35 AM   #17
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
What adapter should I use if I go for the Yamaha 2400 It only has regular electrical outlets and not the 30 amp?
I going to look at one today used for only $700.00. Must supposed to have a 100 hrs on it, seems a lot. Is there something I should look for when checking it over? Thanks for everyone's input.
LoveSally
ILOVESALLY is offline   Reply With Quote
Old 03-07-2014, 05:00 AM   #18
2011 30' Flying Cloud
Arvada , Colorado
It may have been mentioned by someone in their reply, but regarding the flexibility issue, we have found that a single 2000i will run everything in our AS (including the coffee maker) other than air conditioning. We only carrier the "companion" when a/c is going to be needed.
Jack46 is offline   Reply With Quote
Old 03-07-2014, 05:06 AM   #19
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
There are some good options here. The new Dometic shared might be a great choice. Check to see if it is Chinese- then PROBABLY no parts and a toss out later down the road- dunno. The price of the Honda 3000 you found will make a difference. How many hours on it? If you choose a new one I would still consider Yamaha for the direct drive and tri-fuel option. You can make most any of them tri-fuel but if you order from that dealer in West Virginia, the dealer does the conversion and it is "a dealer" that is responsible for any error drilling into the carb, etc. Be aware that if you DO consider Yamaha the HC in the name of various models is "high current" which basically means that they are designed to operate with motors drawing initial high current to start (like air conditioner compressors/fans) with capacitors that give higher capabilities for so many seconds. There is an older 2400 without the HC designation so take note. I too run my generator on LP since it does not gum up the carb- considered the #1 service call on generators. The tri-fuel option is about $300 or so to the cost.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-07-2014, 05:29 AM   #20
Gainesville , Florida
One version of the Honda 3000 is lighter and noisier than the second older version offered. The second version is quieter than a 2000 but heavier. Go to the Honda site. Jim
Old 03-07-2014, 05:40 AM   #21
2006 25' Safari
Images: 8
Here is a clip regarding the only issue I found with Yamahas known as surging and, it is related to using gasoline on an non HC 2400. They have an automated RPM circuit. The clip shows the issue and the easy fix. Yamaha has an iron sleeve and metal cam.
Old 03-07-2014, 06:25 AM   #22
Arvada , Colorado
I'd check the ability of the Yamaha to handle a 15K a/c unit along with other needs. I've heard different opinions about that. It could be workable by managing the use of various "drains" in the AS.
Old 03-07-2014, 08:02 AM   #23
1974 Argosy 20
Kooskia , Idaho
100 hours on a Honda or Yamaha is nothing. I have a friend who uses his Honda 2000 for back up on his off grid solar powered home. The Honda has probably 4000 + hours on it now. It burns a little oil, but otherwise still is doing just fine.
Old 03-07-2014, 10:04 AM   #24
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We have two Honda 2000, one is a companion with the 30AMP plug. Running the air and all other appliances is fine, except the Fridge, I keep that on gas. Running the A/C and both generators the fuel will last about 4 hours. I have a auxiliary tank that provides fuel to both generators when they run out. It's a pain, but when I use it they will staying running for over eight ours. They are loud as are all campground stand alone gens. I don't like using them for that reason, but do when no one else is around.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-07-2014, 02:39 PM   #25
2006 25' Safari
Images: 8
I know that the 2400 is certified to carry a 13,500 AC load. I can run the AC and my microwave in my test; however, I have an 11,000 BTU unit.
Old 03-07-2014, 02:47 PM   #26
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
If it hasn't been stated, you can add remote start to the 3000. I had a 3000 and a pair of 2000's. I sold the 3000 with my power boat, I installed the remote start kit which made it a pleasure to use. With the 2 2000's you have a backup. Really a toss up.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-07-2014, 02:50 PM   #27
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
another factor you may want to consider is the weight of the larger one. especially if you have to lift it in out of your vehicle. The older one gets the heavy it becomes.
urnmor is offline   Reply With Quote
Old 03-07-2014, 03:24 PM   #28
2006 25' Safari
Images: 8
ILOVESALLY, I would certainly look at the used Honda unit. Seven hundred seems like a good price. You need to hear it run (smoothly) and take a heat gun or some small high wattage device(s) to plug into it to make a load. Let it warm up too and test again. It needs to run about 10 minutes then put as much load as you can on it. If you have a couple hair dryers 15-1600 watt. You can run one on high and work the other one at various settings. Just an idea.
As others have stated, larger units weigh more. A 3000 is 134lbs, a Yam 2400 74lbs, two 2000s 47lbs each. I use a dolly for mine with a ramp on the truck to the bed.
The last thing to consider, are you comfortable to buy it and do the maintenance on it right away for the 100 hours already used? If so you may have found a bargain. How old is it? Why are they selling it? --are good questions to ask.
If you buy new, I have already shared the Yamaha brand. Honda is good too but I point out that Honda has a plastic cam and several plastic components in the engine including the belt. The belts are $20 but servicing is not cheap. I have a Honda mower and really like it. Another point is it depends on what ELSE you may want to run while the AC is being used with the generator. If not much, then you can get by on a 2400isHC. The Honda 2000 is not an option unless you buy two with the connection kit as it will not run your AC. There is a 250 watt difference between a Dometic 11K and 13.5K AC so if I can run my microwave and the AC, it should run your AC with no trouble. If it were me I would go for the used 3000 first then consider a tri-fuel Yammy 2400 as a new option. Ironically the new one would be about double the cost of the used one. Oh, ask the owner to open the left side cover and look around at the engine while running for leaks, wet oil, etc. There may be some buildup but should not be wet oil.
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
Honda 3000i Handi for late 70s Sovereign? Airstream Dad Electrical - Systems, Generators, Batteries & Solar 6 10-13-2011 01:42 PM
Paralleling Honda 2000i, and Eco system Headhog Generators & Solar Power 18 09-17-2011 04:04 PM
Honda 2000i and AC ShawnG17 Electrical - Systems, Generators, Batteries & Solar 22 07-22-2011 10:39 AM
Honda EU 3000i generator for sale rando Generators & Solar Power 2 05-12-2011 10:30 AM
