Old 11-14-2007, 09:14 AM   #29
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
With an old non-AS trialer I used to have I used one of those clear plastic RV Hyrdo-flush fittings that allowed me to backflush the waste tank. I can't get it to fit on my '94 LY as the waste valve is set back and is set to drain via a hole in the floor of the storage compartment which houses it all. I had purchased a portable FloJet mascerator pump, but it looks like I'm going to have to modify the waste fillings to get it to fit.
For chemicals, I have been using Pinesol (the original liquid cleaner) since the mid-1980's. While in motion, it washes the tank, there is a bit of oil in it which lubricates the valves and it has a pine smell to it which is not unpleasant. It's also easy to find and much less expensive than some of the packet cleaners.
I've got to admit that I squirmed in my seat when I watched the antics of Robin Williams in "RV", especially when he was connecting up the waste hoses.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
