Old 11-09-2015, 02:37 PM   #15
2012 30' Classic
Homosassa , Florida
We have drug our 30' once when exiting a gas station. Entrance was fine but opposite side exit looked ok but just steep enough to scrape. We fuel at Flying J RV pumps whenever possible just to avoid problems.
Tater is offline   Reply With Quote
Old 11-09-2015, 02:52 PM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
If you have a steep driveway or some other obstacle you'll have to deal with on a fairly regular basis you CAN bring the back end of the trailer up high deliberately. Dump 10 lbs of pressure from your rear tires of your tow vehicle (have a pump to refill them promptly to prevent damage). If you have a weight distribution hitch removing the weight bars should let the front sag down a couple of inches - it may be all you need to cross over the transition.
Carry a couple of 5 to 6 ft long planks (2 x 10's are best) to bridge OVER a big dip in a driveway entrance/exit.
Recently I had to do a back in parking job with a deep pothole I couldn't help but run over. Orange "lego" blocks to the rescue, but I think I left one in the bottom of the hole never to be seen again. The campground has since filled it in after a fellow camper pulled an old car antenna and stuck it in the pothole than claimed that a sinkhole had gotten his Jetta. (Almost had the camp host going for a minute or two!)
Paula
Foiled Again is online now   Reply With Quote
Old 11-09-2015, 03:00 PM   #17
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
It does happen. I am always careful when entering or leaving a driveway with any sort of transition curb. Most are ok but look for the telltale signs of other trailers that have already bottomed out and left gouges in the pavement. Worst outcome would be ripping out your holding tank drain valves. Would not be fun to have an unplanned dump of your holding tanks right there in the street for all to enjoy. If it looks like a troublesome transition, go slow and watch closely. Position a spotter outside to watch and report if you can. Avoid if it really looks like trouble, and look for a better spot.
Nomad518 is offline   Reply With Quote
Old 11-09-2015, 08:30 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't want to add casters because that will limit your clearance and push up on the stern. Too much can "bend" the shell of your Airstream.. Pop rivets.. Or crease!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-09-2015, 08:36 PM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh, here are the boards laminated to span 6 feet of our 9500# BABY!!!
Channing
WBCCI# 30676
Old 11-09-2015, 08:47 PM   #20
2016 25' Flying Cloud
Holly Springs , Mississippi
The newer trailers I've gotten under have vertical 1/4" steel plates/strips welded to the aft frame that will contact the pavement first, so main part of the frame and the bumper won't drag.
I don't understand why this factory set-up would be better than casters, but what do I know? (Answer: nothing.)
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 11-09-2015, 09:42 PM   #21
2007 22' International CCD
Trust me, even with the drag bars it's still possible to wrinkle the shell if you miss a narrow driveway edge and drop the rear corner hard. Don't ask me how I found this out.
Bent two segments in one corner (sigh). At least it's not leaking.
KE4GNK/AE
Old 11-14-2015, 02:08 PM   #22
gpt
2014 25' FB Flying Cloud
sequim , Washington
Originally Posted by Rocinante View Post
Here in the PNW we worry about ferries.
watch the tides, enter at an angle, no problem doing that, and you will be fine.
gpt is offline   Reply With Quote
Old 12-30-2015, 06:23 AM   #23
2016 30' Classic
The Berkshires , MA
Thank you all for your comments. All valuable to a newbie!
mrg1960 is offline   Reply With Quote
Old 12-30-2015, 06:41 AM   #24
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bridges
Here is how we negotiate our driveway...
Channing
WBCCI# 30676
Old 12-30-2015, 07:02 AM   #25
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh.. Our little baby snaps 2x12's like small branches. Your "span" should be less than less than 4" before ther is another support at least the width of the top board.
Our "bridge consists of multiple 2x4's which are thru drilled, glued together with the strongest construction adhesive I could buy, then then clamped With "all thread" and fender washers and cured 3 days before use
They are 3 years old and need replacement now.
They also weigh over 80# each... And are 8' long. So a challenge with my injured back,,, just move one end at a time using my arms..
I considered steel, but the weight would be more... Also, wood will usually make noise before it reaches its break point... Sometimes. Steel just bends and is permanently deformed. I am considering a set of casters near the center to help position...
One other thing.. Boards can "kick up" on the light ent and hit your underside... Take care.
Channing
WBCCI# 30676
Old 12-30-2015, 03:59 PM   #26
gpt
sequim , Washington
Here in the PNW we worry about ferries. We haven't taken Rocinante (27FB) on one yet because we fear the potential to drag her butt when entering or leaving the ferry, on the assumption that the potentially sharp angle between deck and ramp might be problematic, and by the time we realize there's a problem it would be too late to back out.
To be fair, we've no actual experience with this to date - just a concern that makes us avoid them though we'd love to go for it one day. So, this is officially a mostly fact-free opinion that led us to make an uniformed decision.
watch the tides, simple enough to avoid the sharp entry/exit angles. no issues for us on the WA ferries, at least to this point.
Old 12-31-2015, 08:27 AM   #27
2015 27' Flying Cloud
Irrigon , Oregon
Originally Posted by ROBERT CROSS View Post
Once in a BluMoon we will scrape our rear end....
Do NOT add casters....the frame has provisions for the occasional butt drag.
Bob what are you showing me here?
Alluminati: not all conspires are theory,Alluminati is a 2015 27fb Flying cloud😎
Tv: 2015 Gmc sierra 3500 duramax allison 😇
"We like it"
FunyFarm is offline   Reply With Quote
Old 12-31-2015, 08:48 AM   #28
This is my first post and I don't own an airstream yet with any luck I'll find the perfect air stream this fall. This has been one of my main concerns hitting bottom or worse the hitch assembly hitting bottom when backing into a tight spot. I have been researching and looking at different setups mostly online and a few at RV parks and I like the Pro Pride and Hensley setups. I'm just really concerned that they hang too low and will contact the ground when pulling into or backing into on level areas. Anybody have any experience with this or am I just over thinking the situation too much.
I've been reading this form for the last year and a half learning as much as I can thank you again for being a great resource.
Rich
n9hox is offline   Reply With Quote
Hitting the road check list smallfry On The Road... 8 12-12-2016 12:52 PM
Twink hitting 8000 posts? CanoeStream Off Topic Forum 66 05-06-2007 07:25 PM
Hitting the Road! lewster On The Road... 27 06-22-2006 08:30 PM
Start on interior & hitting the road PodPeople All Argosy Trailers 7 01-04-2005 09:32 PM
THUD! Sound of head hitting monitor... Janet H Our Community 9 10-23-2004 11:18 AM
