Old 05-05-2015, 02:52 PM   #1
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Hitch extender?
When hitched up the tailgate of my F150 cannot be opened because it interferes with the electric Jack power head. I see that there are hitch extenders available, but would they cause another kind of grief? Stability issues? Anybody BTDT? How did it go? I only need about 6 extra inches.( I know. The story of my life)
Gearheart is offline   Reply With Quote
Old 05-05-2015, 03:00 PM   #2
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I don't see you mentioned the type hitch you have. If an equalizer, they do make a longer shank that can be used. I purchased one and pulled my 25FC about 3,000 miles. You need to be careful of proper WD set up and personally I did not like it too much. Equalizer will walk you through this. As noted, there are some factors to consider with tongue weights and hitch capacity. As an easier option, you can rotate the top portion of the electric jack and it gives you the proper clearance. Loosening the lower bolts and rotating will not work. Must rotate just the head of the jack. I would go that route first as tried the extended shank and was not pleased with how it pulled. So much so that when I changed to a 28FC I gave the shank away. Ultimately went to a ProPride and no issues with it.
silverlabs is offline   Reply With Quote
Old 05-05-2015, 03:06 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Interesting product,
Jack-E-Up
MICHAEL
Old 05-05-2015, 03:07 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
CanAm shortened our hitch length for better towing performance and when they did that we ran into the same issue. The solution was to turn the hitch head 90 degrees as shown in this photo:
Bob Martel
WBCCI# 5766
Old 05-05-2015, 03:07 PM   #5
Chelsea , Michigan
Images: 12
Dang, I meant the hitch head was turned 90 degrees, not the entire trailer!
Bob Martel
WBCCI# 5766
Old 05-05-2015, 03:22 PM   #6
1972 27' Overlander
Saline , Michigan
we actually had a local welder weld our adjustable hitch to a longer bar, ours is now about 2 1/2 ft long.
It did not effect towing we have done multiple cross country trips since the modification in the late 1990's
loechli is offline   Reply With Quote
Old 05-05-2015, 09:58 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"Length is leverage"... and that will affect handling.. and WD... take care when extending that...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-05-2015, 10:13 PM   #8
gpt
2014 25' FB Flying Cloud
sequim , Washington
if the AS and the F350 are square to one another, i have about 2" of clearance when i put the tailgate down. if they are not straight on, i can't open the tailgate either. turning the jack head 90 degrees is a clever solution and one i bet would solve my issue.
gpt is offline   Reply With Quote
Old 05-06-2015, 06:19 AM   #9
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
The Hensley lengthens the hitch by its design, and my F150 tailgate opens without a problem, with a couple of inches to spare. The Hensley improved handling by eliminating sway, and has excellent WD properties.
Tom
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 05-06-2015, 07:59 AM   #10
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
I will turn the jack head and see. If it's not enough it will surely reduce the amount of extension req'd.
Old 05-06-2015, 09:31 AM   #11
2010 28' Flying Cloud
Slidell , Louisiana
Turned my jack head 90 degrees also, problem solved in about 15 minutes.
dayner is offline   Reply With Quote
Old 05-12-2015, 06:17 PM   #12
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
In order to rotate the jack head, do you just loosen the two Allen head screws behind the thing that looks like a canister?
McDave is offline   Reply With Quote
Old 05-12-2015, 06:35 PM   #13
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
We use an Air Safe hitch (air bag) to damp shocks to our Airstream, and a side benefit is about 10 inches more space between the F350 and our 2012 25' Flying Cloud. Clearance solved.
Old 05-12-2015, 06:36 PM   #14
AWCHIEF's Avatar
Images: 33
Yes, that is the motor and gears. Do not remove or lift the motor. Loosen the screws and give the head a turn, tighten the screws back and you should be good to go.
MICHAEL
Dually Air Valve Extender Glamper1 Sprinter and B-van Forum 28 05-09-2015 10:42 AM
Extender Mirrors for my Rav 4 Big Air On The Road... 1 05-01-2015 11:17 AM
Anyone using a hitch extender? adwriter73 Hitches, Couplers & Balls 25 11-26-2012 01:42 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
