Old 10-04-2009, 08:39 PM   #15
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
This situation has to be one of the greatest fears in a trailer owner, another would be the hitch pulling out of the receiver.
Has that ever happened???
I have always wondered about the strength of the hitch pin.
Be Safe.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 10-04-2009, 10:17 PM   #16
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I handle my hitch head/DrawBar and lube the ball (couple little spots )with every hookup. So I know if there are any cracks or if the ball is loose.
This little story reminded me of how important safety chains are. I just replace mine yesterday. With 1 size larger (3/8 high tensile) and new hooks. I did find two open (broken ) links.
Everyone please cross your safety chains to form a cradle so if this happens the tongue does not hit the ground. Always use a drawbar pin lock and also a coupler lock when on the road to make sure that couple stays closed. Safety is the key word here.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-05-2009, 05:31 AM   #17
Kevin245's Avatar
I have not heard of this happening, but I'm sure it probably has. I can imagine several scenarios.
Some prankster yanks your pin while you're stopped.
Forget to slip in the keeper pin.
Keeper pin break, or slips out.
Hitch pin cracks
Pins are cheap enough that if there is any doubt I replace them. I keep a spare in the TV along with several of the keeper clips. If I observe any scarring of the pin I toss it in the scrap recycle bin at work.
I seem to remember HowieE had a hitch head to draw bar failure.
Regards,
Kevin
Eleanor Roosevelt
Old 10-05-2009, 06:33 AM   #18
1998 28' Excella
Dolores , Colorado
Some interesting comments about keeping the hitch ball lubricated, etc. I had a very substantial disagreement with the owner of the local RV dealership about lubricating the hitch ball. Their opinion was that the ball is used for grounding and should NOT be lubricated. I swore a couple of years ago when they screwed me on a service deal that I wouln't deal with them and now I know I won't ever deal with them.
4CU/CAC
dogpound is offline   Reply With Quote
Hitch ball rating n2916s Hitches, Couplers & Balls 21 12-19-2008 11:07 PM
Hitch ball atvmcg Hitches, Couplers & Balls 4 10-26-2007 06:01 PM
Hitch Ball question racoco 2005 and newer - Bambi all models 10 05-04-2007 08:04 AM
Hitch Ball ? aviontt Hitches, Couplers & Balls 1 06-09-2004 05:24 PM
Hitch Ball Source uwe Commercial Listings 1 10-18-2003 11:47 AM
