Old 04-15-2006, 11:16 AM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
High clearance Airstreams
If you look closely at the movies of Wally's caravan in Africa and some in Asia, you will notice that the trailers and trucks have extra clearance. I think they modified the trailers by putting some blocks under the frame and then mounted the axles to the blocks. That put the damageable parts up a few inches. Looks like some of the trucks were special also as they forded some fairly deep streams. I would not think it would take much to install a few steel box sections under the frame to give you some extra clearance. New axles with higher spring rate and more offset is also a possibility if you are going to replace the axles on a short older unit and you love the back country. I do not know whether I would go with one axle units or two but I would keep the length at 25 foot or less. I saw an ad for a special off road Trailer that was towed by a Hummer 1 that looked pretty neat.
Others' Reactions to your Airstreams? Pick On The Road... 84 05-16-2007 12:49 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
sky high prices overlander Our Community 17 10-09-2002 03:52 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
