Old 10-12-2014, 01:32 PM   #1
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Help! Transporting gasoline for generator,where, Suburban and AS, no open truck.
I have a 2005 Chev Suburban and I would like to transport a 2000 Honda generator and 1-2 gallons of gas, thoughts? Thanks beforehand. I am awaiting some creative thinkers out there! What to do? What to do?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is online now   Reply With Quote
Old 10-12-2014, 02:12 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I sense that you do not want to carry the gasoline inside the car, which makes sense to me. Three possible solutions come to mind:
1. Ditch the gasoline entirely and convert the generator to run on propane and use the TT's propane tanks.
2. Carry the gasoline in the trailer, at least you won't have any fumes in the car!
3. Carry the gasoline on a roof rack on top of the car or perhaps you could rig something on top of the TT's battery box area.
BTW, we winter in Venice from January until April this year. Perhaps we can stop by and say hello.
Good luck!
Bob Martel
WBCCI# 5766
Old 10-12-2014, 02:50 PM   #3
2000 30' Excella
Toledo , Ohio
rig something up on the storage box behind the propane tanks no fumes in trailer or tow vehicle .
woodfox45 is offline   Reply With Quote
Old 10-12-2014, 03:01 PM   #4
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Buy an army surplus Jerry can. Make sure the rubber gasket is in good shape.
They will seal airtight, when in good shape. I have carried gas in two of them for years.
terryV is offline   Reply With Quote
Old 10-12-2014, 03:34 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
TerryV is right.. do NOT use the 'household' style...you must have one that SEALS.. it's the can Man...
Yes, it is more $$$$. Yes, it will outlast the 'home' versions...yes, you will have to have a very serious accident to have to worry about it.. then store it upright...
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-12-2014, 05:29 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That's actually doable— if certain precautions are followed. It's not ideal, but it is doable. I've considered this option for my Airstream Interstate motorhome, in the event of a hurricane evacuation, where I'd have to carry fuel cans either inside my Interstate or inside my Honda Fit toad. So here's what I came up with as a plan:
1 - Carry the fuel can in the shower. The shower pan provides secondary containment in case of a spill so spilled fuel doesn't end up everywhere, only in the gray tank (not the best place for it, but far from the worst place for spilled fuel to go since I could dilute the heck out of it before dumping).
2 - Keep the bathroom vent open for vapors to escape.
3 - LPG detectors will detect other types of fuel vapors as well, such as gasoline, so listen for the LPG detector.
4 - Make sure the fuel can can't tip over; a can that is wider than it is tall, like the six-gallon cans used with outboard motors, would be ideal.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-12-2014, 06:29 PM   #7
1987 25' Sovereign
Oregon , Ohio
I like the idea of converting it over to propane and running it off the trailer tanks.
msmcv51 is offline   Reply With Quote
Old 10-12-2014, 07:35 PM   #8
Don't be surprised when you find out how much LPG that generator consumes.
Makes some owners carry extra LPG bottles.
Old 10-12-2014, 07:52 PM   #9
My Interstate has an on-board 2.5kW Onan propane-fueled generator. When running at 50% load, it burns about 0.6 gallons per hour— that's about 2.6 pounds per hour.
WBCCI #1105
TAC LA-4
Old 10-12-2014, 08:28 PM   #10
Yes, that's pretty close.
But, as an example, if you run an AC in a trasiler, your useage gets up to about 3 to 3.2 pounds per hour, which also includes the Univolt.
Assuming 2 40 pound tanks, then your looking at about 25 hours.
LPG has less BTU per gallon than gasolene, therefore it takes a little more to run the same engine.
Old 10-13-2014, 06:45 AM   #11
Chelsea , Michigan
Images: 12
According to the comparative information posted on the web site of one of the companies that does the propane conversion, the rate of propane use is very similar to that of gasoline in terms of gallons per hour. So yes, if you are using propane you will need to factor that into how often you fill up your propane tanks, but it's not like a 2kw generator will suck your 30 pound tank dry in a matter of a couple of hours.
All in all, I'd rather deal with propane than gasoline any day.
Bob Martel
WBCCI# 5766
Old 10-13-2014, 12:36 PM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Siphon gas for your generator out of the tow vehicle then siphon any unused gas in the generator back to the two vehicle. I haven't done it so is it possible?
Kelvin
Old 10-13-2014, 12:50 PM   #13
Doubt it. Most vehicles these days have a check valve in the filler tube that prevents siphoning.
WBCCI #1105
TAC LA-4
Old 10-13-2014, 01:15 PM   #14
Venice , Florida
Images: 14
Thanks to all that have contributed solutions to my dilemma. All of which are notable. I want to take the gen with us, so we will!
Airdreamers
WBCCI #8880
AIR #41310
Recharging Batteries/ transporting portbale generator boblomquist Generators & Solar Power 5 05-24-2013 03:56 PM
Transporting Gasoline? TowAir Generators & Solar Power 13 05-18-2011 12:24 PM
Gasoline Can For Generator Fuel PARKS1963 Generators & Solar Power 9 08-12-2006 08:14 PM
