Old 10-13-2014, 01:58 PM   #15
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
When my 2009 Suburban was still brand new, I carried generator gasoline in the cargo area. It spilled. Soaked the carpet, the pad, the full catastrophe.
You are wise to look for alternatives.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-14-2014, 03:21 AM   #16
2004 16' International CCD
Chicagoland , Illinois
I put my generator into a HD plastic storage box w/ a removable lid. As long as it is packed properly, any trickle of fuel that leaks out from the generator stays in the box.
As far as fuel storage goes I've had good luck with the Rotopax fuel containers:
Fuel Cans : Gas Pack : Gasoline Containers : RotopaX.com
If you need to lug lots of fuel try the Scepter MFC. It is the final evolution of the Jerry Can. You may need to look for a while to find someone selling them as their civilian availability can be frustratingly limited. Hence they aren't usually cheap. If you only need a few "cans" they are a justifiable and worthwhile investment that will easily outlast your AS.
http://civ.sceptermilitary.com/sites..._catalogue.pdf
Airrogant is offline   Reply With Quote
Old 10-14-2014, 06:48 AM   #17
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I carry my generator and 1 gallon gas can in a Rubbermaid container with the lid. Both the generator and gas can fit in the container and sit in the original plastic bag the generator came in. Im able to twist tie the bag closed then put the lid on the container. It rides in my Suburban. No issues.
LilNomad
LiLNomad is offline   Reply With Quote
Old 10-14-2014, 08:33 AM   #18
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I use a Rubbermaid Action Packer to haul my 2k Honda generator in my pickup bed. It is not airtight, though over time it does seem to concentrate the smell of spilled gas, oil, and combustion within the container. I tie it down with a ratchet strap when hauling. I would not carry it inside the tow vehicle cab with passengers.
I use a Scepter plastic fuel can from Tractor Supply. I also bought their EZ Pour spout replacement and use that when I haul fuel. The EZ Pour has a plastic disc/plug with neoprene ring washers that prevent fuel/fumes from escaping. It's also tied down with a ratchet or bungee.
If I were towing with a SUV I would not haul the generator or fuel can inside the passenger compartment. There would be to much chance of fire inside during a collision. I would put it in the trailer, strapped down so it would not move.
Alan
Old 10-14-2014, 08:40 AM   #19
Zil
egg harbor city , South Jersey
Look at Eagle brand metal gasoline cans. OSHA approved.
Zil is offline   Reply With Quote
Old 10-14-2014, 11:00 AM   #20
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I would carry the generator in the bathtub or shower.
To minimize the danger of carrying gasoline, I might consider carrying the gas can empty. Just carry gas in it when needed to refill the generator. I carry a 1K genny with me but rarely use it, so no need to carry a gas can.
If you are going to carry a gas can, I would recommend something like a Justrite metal can that meets OSHA and many other requirements. Just order it from Amazon.
Dan
Old 10-14-2014, 11:38 AM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bureau of Land Management gobbledegook
http://www.blm.gov/pgdata/etc/medial...a2003025a5.pdf
Jerry Can...
http://www.jerrycan.com/product-cate...erry-cans-new/
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-14-2014, 11:51 AM   #22
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I'm not sure it's gobbledegook. In fact, it's pretty much in line with Department of Transportation guidelines for carrying individual fuel cans without secondary containment.
It's the same principle that only lets you carry up to 11 one-pound propane canisters in your truck for use with your Coleman grill, even though you can have a built-in tank or a larger DOT cylinder that holds a lot more than 11 pounds of propane.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-14-2014, 07:34 PM   #23
Mixter's Avatar
1976 27' Overlander
Havent seen anyone one speak up to say that fuel storage in the trailer is a no-no because of vapors and pilot lights on the appliances is a recipe for disaster.
Thought I read this somewhere and always been under the impression that its a bad idea.
Is this not the case? This is new to me as I have never actually used my 2 year old, shell off, restoration project that I was just going to "clean up and go camping".
Mixter is offline   Reply With Quote
Old 10-14-2014, 08:16 PM   #24
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Roto Pax
And the appropriate base bolted to the propane cover
1.75 Gallon Fuel Packs : Gasoline Containers : RotopaX.com
RotopaX Mounting Bracket Solutions | Standard Pack Mount
LAWBC is offline   Reply With Quote
Old 10-15-2014, 02:03 AM   #25
Gasoline vapors have a "lower explosive limit" just like propane; and being a hydrocarbon vapor are detectable by an LPG detector.
Gasoline's lower explosive limit is 1.2% by volume (propane's is 2.1% by volume).
A five-gallon gas can would have to off-gas a lot of vapor to add up to 1.2% of your trailer's air volume. It would have to off-gas a lot less to add up to 1.2% of your tow vehicle's air volume. So if you have to carry it inside, it's safer in the trailer than in the tow vehicle. If you keep the vents open to allow air exchange, it will also take a lot longer for vapors to build up to 1.2% of the trailer's air volume.
Also, your pilot lights are all on the outside of the vehicle for your furnace, water heater, and refrigerator; air for combustion is drawn from outside, not from inside. The only spark source inside the trailer is the stove, which you shouldn't be using while you're driving anyway.
WBCCI #1105
TAC LA-4
Old 10-15-2014, 04:24 AM   #26
r carl's Avatar
Lin , Ne
I used to have a 1967 Ford F350 and you could see the gas tank when you pulled the back of the seat forward. I always could smell a faint gasoline odor and I always smoked cigarettes in that cab.
Old 10-15-2014, 04:56 AM   #27
I used to have a 1959 Ford pickup with the fuel tank behind the seat like that.
WBCCI #1105
TAC LA-4
Old 10-15-2014, 07:42 AM   #28
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
Great idea. Does the can sit on the frame? Does the mounting bracket support the weight or just stabilize the can and the weight is on the frame.
Ponyfvr is offline   Reply With Quote
Recharging Batteries/ transporting portbale generator boblomquist Generators & Solar Power 5 05-24-2013 03:56 PM
Transporting Gasoline? TowAir Generators & Solar Power 13 05-18-2011 12:24 PM
Gasoline Can For Generator Fuel PARKS1963 Generators & Solar Power 9 08-12-2006 08:14 PM
