Old 03-08-2012, 01:27 PM   #1
la crescenta , California
Talking Help towing an Airstream Safari from AZ to CA
Hello All,
I'm currently looking into purchasing a 1977 22ft Safari that is near Prescott, AZ. Problem is I dont have a sufficient tow vehicle at the moment in order to get it home (97' V6 3.4L Tacoma, I live in La Crescenta, CA 91214).
I am looking for someone who might be willing to tow the AS for me.
Obviously willing to pay for gas and time.
Any help would be greatly appreciated!
Christian
drmittens is offline   Reply With Quote
Old 03-08-2012, 03:34 PM   #2
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Christian
If the Tacoma is in good shape and you are a little bit patient it will easily tow a 77 22' Airstream. You will climb the large hills in second gear at 45-50 MPH but other than that it will run along nicely at 60 MPh and give you pretty good mileage. If you have the original radiator you may need a new one. It will need a transmission cooler if it is an automatic, brake control and wiring and a class 3 receiver. No matter what vehicle you ultimately tow with you need a weight distribution hitch and sway control.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 03-08-2012, 05:15 PM   #3
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
I may be able to, depending on timing. I'm your neighbor in Glendale. I'll PM you!
Mike91208 is offline   Reply With Quote
Old 03-08-2012, 11:44 PM   #4
I read a lot of forums on tow vehicles and it seemed most people thought it not a good idea to tow with the Tacoma. That said the Tacoma is in excellent shape, manual transmission and I have looked into weight distributing hitches but I really dont know what I am looking for? Reese was mentioned as a solid hitch and I found that online but unsure what model to look for. Seeing how I have no experience towing I dont want to put myself in a tough situation. A friend of mine said he pulled a 63' 22ft Safari from NM with a v6 Explorer without the brakes hooked and claims to have had no problems!?
Again thanks for all input!
Old 03-08-2012, 11:45 PM   #5
Thanks Mike! I'll give you a call tomorrow.
Lady - A 1969 23' Safari; Update and fixes BoCox 1969 - 1973 Safari 28 08-25-2013 09:00 PM
How to reseal windows 92landyacht Land Yacht/Legacy Motorhomes 8 04-03-2012 06:16 AM
Airstream Goose Neck perryg114 Towing, Tow Vehicles & Hitches 23 03-10-2012 11:09 AM
How to buy a used AS??? sophiefox Buyer Guidelines 4 03-08-2012 12:49 PM
The RETROMOBILE in this month's Airstream Life Eaglemate Airstream Lifestyle 7 03-08-2012 12:40 PM
