04-14-2014, 11:15 AM
2013 28' Flying Cloud
Central
, Canada
Heating Trailer while travelling....
Greetings All:
This might be a stupid question, but one I'm going to ask anyway......
I need to head out in about a week to collect a (new to us) Unit in Seattle. I'm assuming the weather on the coast will be good enough to test all the systems etc. The issue is as soon as I leave the coast, I will be heading across the Rockies and into Central Canada. As of this AM my local weather is (-18) but should warm up to single digests by weeks end.
The plan is to overnight in the unit on our way home but I'm concerned about keeping heat in the trailer as I go down the road. Can I leave the furnace on and allow it to heart the trailer. I'm not as concerned about water an the like, just heat.
Hope someone can fill me in on the best way to handle this little trip
TKS
Doug
Trying to use my camera to create memories - not photographs!
04-14-2014, 11:19 AM
1981 31' Excella II
New Market
, Alabama
I would talk to the furnace manufacture and see what they say about it. If they say it is safe then go for it. You might run out of propane pretty quick.
I would drain everything at the very least. Also drain the water heater. Unless you leave it going, it will freeze as well. If you can blow the system out with air, I would do that.
Perry
04-14-2014, 11:22 AM
Central
, Canada
TKS Perry - I did not consider the propane issue... I was just thinking about how cold it will be when I want to get a little rest from driving...
04-14-2014, 11:32 AM
Princeton
, New Jersey
There should not be a problem. The heater gas will shut off if the flame happened to blow out, highly unlikely.
I would set the thermostat as low as possible while traveling. That will keep the chill of the unit and not just waste propane. If the trailer is at 55 when you stop it won't take it long to come up.
Now that said I never sleep with the heater on even when it is below freezing outside.
2004 Excursion 4x4
04-14-2014, 11:34 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
This is one of those yes and no questions....
I have done it and still do it on occasion, especially if I am going to be driving into or during cold weather.
Some people are dead set against driving with the LP tanks turned on, in some cases it may be illegal (tunnels and bridges come to mind). You will have to determine your own risk level. IMHO it is a low risk in most cases, except when refueling, in which case I want the LP tanks closed off.
The furnace is pretty good at knocking the chill off pretty quickly, especially if the trailer was warm at the start of the trip. I know where you are coming from in wanting to be able to get from a warm truck into a warm trailer, great feeling and one of the reasons I like traveling with my trailer.
Aaron
WBCCI #XXXX AIR #2495
04-14-2014, 11:40 AM
2005 30' Classic
Burlington
, Ontario
Just a thought - when you leave the warmer area, why not just pump plumbing antifreeze thru the system - I am guessing you might still need it when you get back home anyway.
As for warming the trailer up if you want to take a rest on the drive back, I would just fire up the furnace when you stop, it is surprising how quickly it will warm things up in there, that is what we do if we want to have lunch in the trailer or sleep in it overnight at a truck stop.
We normally head to our home near Toronto from Florida or Arizona targeting to be home in the first week of April.
My experience has been that very often we can still get nights a few degrees below freezing during April in our area, and so not to take any chances, and not to have to worry about it, I always put antifreeze back in the system at the last campground we stop at on the return journey. It stays there until we use the trailer again at home later in the summer.
After we put the plumbing antifreeze in and dump the tanks at an RV park , we generally need to stop one more night someplace and it is usually a Flying J truck stop. We sleep in the trailer without water and try not to use the toilet! But if we need a "pee" in the middle of the night I don;t worry about it and just flush the toilet wilh a little antifreeze! It has never been a problem.
An alternative would be to put the antifreeze in and dump the tanks at a Flying J, they generally have RV dump facilities.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
04-14-2014, 11:42 AM
Corona
Originally Posted by Arcticfox
Greetings All:
TKS
Doug
Having the furnace function while the trailer is in motion, is a ZERO problem, as long as the furnace is operating properly.
Set the thermostat to about 50 to 55 degrees.
Then when you will be in the trailer change the thermostat to what ever temperature you wish.
When leaving the trailer to hit the highway again, turn the thermostat back down.
That works even in freezing temperatures.
It also keeps the holding tanks from freezing.
04-14-2014, 11:57 AM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
When I am in this predicament, I stop about an hour before I really stop (?) and put the furnace at 74f so it is nice and warm at bedtime. I have never had any issues doing this other than a happier wife. I also leave the HWH on, full water and empty holding tanks. Let's face it. If we are not camping, it's just a mobile Tims with a comfy bed. Jim
04-14-2014, 12:00 PM
Central
, Canada
Thanks for this Aaron:
Your comments make total sense. The one question I do have is your comment about having the LP tanks turned off while refuelling? Are you referencing the refuelling of your truck or of the LP tanks themselves?
TKS
Doug
Aaron
Thanks Brain:
I did not think the furnace would warm the trailer so fast. At this point I'm looking at about 2000 miles for my trip home so my guess is 2 nights 3-days. In all cases I'm just looking at Walmart's or flying J's just to get some sleep and then head out again.
So heating the trailer when one stops might be the best plan at this point in time. How is the best way to get some antifreeze into the system to protect things until I get home?
TKS
Doug
Brian.
04-14-2014, 12:06 PM
Central
, Canada
Thanks for This Jim:
Having a happy wife is always a good idea! When you say you stop before you stop. Are you talking about pulling over cranking the furnace and then driving another hour or so?
Finally what is HWH - sorry new kid on the block....lol
Cheers
Doug
04-14-2014, 12:13 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
TKS
Doug
Refueling the truck. Tanks I take off and haul to the refueling station. When we are traveling with LP on (typically in the winter) if I have to refuel the truck I will pull up well away from the pumps and turn the furnace off, then close the LP tank valves. I don't want any open flame near the pumps. I typically drive a diesel vehicle so the open flame is not as much of an issue, but many diesel pumps are adjacent to gasoline pumps... those are the issue.
Aaron
04-14-2014, 12:24 PM
1997 25' Safari
Burlington
, Ontario
Cheers
Doug
Exactly on the pull over. HWH hot water heater. Sorry about that. Acronyms should be eliminated from any form of communication. Just checked my log for the period that I had an Airstream while residing in Alberta and it indicates a crap shot on freezing. Following are my start dates for camping not involving antifreeze:
1998 April 23
1999 March 24
2000 April 1
2001 May 4
My guess is Saskatchewan is the same.
04-14-2014, 12:36 PM
Princeton
, New Jersey
Just pumping in antifreeze is not a good idea. You should blow down the system from the city connection first. Drain the hot water heater and switch to bypass mode, if equipped. Then remove the input line to the pump and use the pump to fill the system. Failure to do this will leave water in the line from the city connection to the rest of the system. If there is not a bypass valve on the trailer you should consider putting one on before you travel. Failure to do this will require 6 gallons of antifreeze and no guarantee you had done more than just dilute things.
Another consideration.
If the day time temperatures are above freezing while traveling and the nighttime temperature are above 25F you can safely do nothing. It takes more than an overnight to freeze things up at those temperatures.
There is nothing colder than an Airstream trailer if you come out of your truck and step into an unheated trailer. Radiating to cold aluminum is like sitting on dry ice. Use the heater.
2004 Excursion 4x4
04-14-2014, 12:56 PM
Central
, Canada
Thanks very much to this Andy.....
It's great to see such GREAT input!
Cheers
Doug
04-14-2014, 01:00 PM
Central
, Canada
Thanks Howie:
I'm assuming this unit will have a bypass mode as It's a 2013. That said, I will check for sure. I think in the end, I will just leave the furnace on low and hope for the best. Hell this cold weather cannot last much longer.....lol
Thanks again
Doug
04-14-2014, 01:15 PM
2011 23' FB International
2007 20' Safari
Irvine
Turning off LP tank prior to refueling the diesel or gasoline is not necessary period. I have mentioned it in a previous thread that is: any flammable vapor mixed with air (oxidant) are dangerous within Lower Explosion Limit (LEL) and Higher Explosion Limit (HEL). Any mixture above or below these limits e.g. too lean or too rich does not explode or catch fire. Having the right mixture near the Airstream open flame e.g. refrigerator/water heater near the gas pump is very remote to none. I have been RV'ing for last 6 years and never turned off the propane ever when driving or re-fueling. When it comes to safety I never compromise. This is an opinion of a Chemical Engineer, who has been wrong many times.
Happy camping
04-14-2014, 01:40 PM
2005 30' Classic
Burlington
, Ontario
Hi Howie,
I have done it both ways over the years - i.e. blowing first with compressed air, then pumping in the antifreeze or just pumping in the antifreeze to pump out the water. Never had a problem with either method, and it does get pretty cold up this way!
As for the incoming city water line, you make a good point and no doubt your method is the surest.
In our case, ours has an external tap right near the city water inlet - I do always crack that open until it runs pink. I guess that is why I have never had a problem with it when I have not first blown the lines with air. I also crack the two low point drains open momentarily.
To the original poster
To make the job of filling the plumbing lines with antifreeze as easy as possible, you need bypass valves on your HW tank allowing you to take the HW tank out of the system and just drain the water out of it leaving it empty.
To get the antifreeze into the system, the easiest way is to have a short suction hose on your 12v pump inlet. You disconnect the pump suction from the fresh water tank, then use the short suction hose to suck antifreeze directly from the one gallon jugs into the plumbing system.
Once ready to start the process, you then go around opening ALL hot and cold taps one at a time letting them run until they run pink showing that the antifreeze is escaping. Don't forget the galley sink rinse hose, shower, and toilet rinse hose if there is one.
Normally takes about a gallon on a half when I do this with our Classic 30.
I dump the remainder into the sink traps, shower drain and toilet bowl to ensure they are protected and to keep the seal in the toilet soft and working.
The whole process takes me probably twenty minutes.
It is possible that your trailer might need to have an HW tank bypass installed, and also a means to allow your 12v pump to draw from the jugs of antifreeze.
Any RV shop should be able to attend to these items for you if needed.
Brian.
2005 Classic 30'
04-14-2014, 01:53 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Happy camping
I agree... however open flame around gasoline is not a wonderful idea. Every now and again someone screws up and dumps a bunch on the ground. I am a Safety Professional and am willing to take an extra step or two to make sure I and others are safe. I came out of a production background and used to take my fair share of less than stellar short cuts to get the job done. Perfect Storms occur just a bit too often to make me totally comfortable with cutting corners much any more.
Aaron
04-14-2014, 03:51 PM
Wise Elder
2010 30' Classic
South of the river
TKS
Doug
Hi Doug
Andy (InlandRV)'s advice is correct. You can run the furnace while traveling if you wish. Most Airstreamers and most RVers in general, about 90% as near as I can tell, travel with the propane on if there is a reason to use it while underway. There is extensive data that this is safe and doesn't contribute in any material way to fires. Most trailer fires are electrical in origin. I've posted at length about this elsewhere and won't repeat the details here.
I have traveled with the furnace on myself.
There are a couple of things to keep in mind. The furnace uses a good deal of 12v power and also a good deal of propane while it runs. It will run much of the time if on while traveling due to the cooling effect of the airflow from movement.
Since you do not plan to have shore power at your overnight stops, it will be of vital importance to be sure that the charge line circuit from your tow vehicle is connected properly and is working. For a trip like that I would recommend wiring an ammeter into the charge line so that you can confirm at all times from the cab that the trailer is charging.
You will want to be sure that the batteries are in like new condition. I would replace them if there is any doubt or at least bring fully charged spares.
At the temperatures you're expecting it will take around an hour for the trailer to warm up to the point where you will be comfortable.
You will use as much as 5 gallons of propane a day so plan to stop and refill as necessary.
04-14-2014, 08:11 PM
Central
, Canada
Thanks everyone for the Great input!
Cheers
Doug
