Old 03-25-2016, 12:18 PM   #1
Bryan , Texas
Heater cycling
We recently took our Sovereign out and used the heater over night. The heater would cycle on and off every 1.5 to 2 minutes. Is this normal? It was not that cold out side (low 50's). Thank you, David
wdc1369 is offline   Reply With Quote
Old 03-25-2016, 12:39 PM   #2
richw46's Avatar
Lexington , Kentucky
We used an electric heater on the floor that never cycled off, always read 71 even when the furnace or heat pump got the top of the AS to above 78.
The heat pump cycled about every few minutes after it reached a temp where we had set it, same with the furnace, but less frequently. The air at the bottom, middle and top of the AS varied by 6-9 degrees. Night time temps were upper 30s to the 50s.
With poor air circulation in the AS the air will layer. The thermostat has a 2-4 degree difference from cycle on to cycle off. Because of the poor insulation and drafts inside I figure it just cools off pretty quickly at the floor and all the heat rises. The middle layer keeps changing and making the heaters cycle frequently.
When it starts doing that, try lowering the thermostat another 2-4 degrees and I'll bet the furnace doesn't kick in right away, but when it does, it will behave as before.
The good news is, you're warm, right?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water pump cycling every 1-2 sec?? BOBHASTINGS Water Heaters, Filters & Pumps 19 09-06-2006 04:22 PM
Water heater rapid cycling on/off BillTex Water Heaters, Filters & Pumps 8 07-13-2006 11:50 AM
furnace fast cycling - thermostat adjustment emanon25 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-28-2004 09:06 PM
Water Heater Cycling? BigAl Water Heaters, Filters & Pumps 0 07-06-2004 08:48 PM
