Old 08-22-2016, 08:44 PM   #1
Hans627's Avatar
2009 25' FB International
Hanover , Pennsylvania
Heat Pump Question
Just curious, what is the lowest outside temperature that the heat pump will provide enough heat?
Thanks!
Old 08-22-2016, 08:52 PM   #2
dznf0g's Avatar
Oswego , Illinois
Mid 30s for my unit. But I supplement it with a Dyson Hot/Cold.
-Rich-
Old 08-22-2016, 08:56 PM   #3
Hans627's Avatar
Thanks. I'm not familiar with a Dyson Hot/Cold. What is it?
Old 08-22-2016, 08:59 PM   #4
dznf0g's Avatar
Oswego , Illinois
A space heater
-Rich-
Old 08-23-2016, 12:04 AM   #5
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
I recall about 42 degrees is the cut off. Probably depends on humidity as well.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 08-23-2016, 06:26 AM   #6
dznf0g's Avatar
Oswego , Illinois
Seems like the cutoff varies from unit to unit???? Mine switches over to furnace at about 37*
-Rich-
Old 08-23-2016, 07:24 AM   #7
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
It is in the low forties. We run the furnace at night if we think it is going into the low forties because we find the HP noisy.
urnmor is offline   Reply With Quote
Old 08-23-2016, 07:41 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have had similar heat pump results to around 40 degrees.
Brian
SuEllyn & Brian McCabe
2005 Suburban 2500 Quadrasteer (Olivia) & 2011 Silverado 3500 (Fred) with Outfitter Truck Camper (Ethel)
Old 08-23-2016, 07:45 AM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine starts to drop off around 40. Nice to have the gas furnace and a small ceramic heater as alternate heat sources.
MICHAEL
Old 08-23-2016, 09:22 AM   #10
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Same-O
About 40*..but only during the day, too noisy.
Early AM or evening with genset..... Pelonis Disc, (old style, metal)
"What you do speaks so loudly, no one can hear what you say"
M. Levy
So when is this..."old enough to know better" supposed to kick in?
Old 08-23-2016, 09:30 AM   #11
Nowhere , Somewhere
The good old days when if its hot you use the air cond, when it's cold you use the furnace, so much simpler.
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is offline   Reply With Quote
Old 08-23-2016, 10:38 AM   #12
2005 31' Classic
Pleasant Plains , Illinois
We normally use the heat pump if the ambient temp. isn't expected to be below the mid 30s. It seems to work fine. We sometimes use a space heater too. If it's forecast to be below the mid 30s, we use the gas furnace. Also depends on other factors like wind.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
WGreg is offline   Reply With Quote
Old 08-23-2016, 10:50 AM   #13
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
Upper 30's.
We found that last fall the heat pumps In our new 2016 Classic worked quite well into the upper 30's which occurred at night during our Thanksgiving trip to TN.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 08-24-2016, 06:47 AM   #14
Hans627's Avatar
Am I to understand that the switch from heat pump to furnace occurs automatically when the temparure drops roo low for the heat pump?
Also it seems like having a small space heater might make sense. Currently we do not have one.
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-30-2011 02:14 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
