08-22-2016, 07:44 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Heat Pump Question
Just curious, what is the lowest outside temperature that the heat pump will provide enough heat?
Thanks!
08-22-2016, 07:52 PM
Oswego
Mid 30s for my unit. But I supplement it with a Dyson Hot/Cold.
-Rich-
08-22-2016, 07:56 PM
Tavares
Thanks. I'm not familiar with a Dyson Hot/Cold. What is it?
08-22-2016, 07:59 PM
Oswego
A space heater
-Rich-
08-22-2016, 11:04 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
I recall about 42 degrees is the cut off. Probably depends on humidity as well.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
08-23-2016, 05:26 AM
Oswego
Seems like the cutoff varies from unit to unit???? Mine switches over to furnace at about 37*
-Rich-
08-23-2016, 06:24 AM
2012 25' Flying Cloud
Berlin
, Maryland
It is in the low forties. We run the furnace at night if we think it is going into the low forties because we find the HP noisy.
08-23-2016, 06:41 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have had similar heat pump results to around 40 degrees.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
08-23-2016, 06:45 AM
Biloxi
, Mississippi
Mine starts to drop off around 40. Nice to have the gas furnace and a small ceramic heater as alternate heat sources.
MICHAEL
08-23-2016, 08:22 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Same-O
About 40*..but only during the day, too noisy.
Early AM or evening with genset..... Pelonis Disc, (old style, metal)
08-23-2016, 08:30 AM
Mantua
, Ohio
The good old days when if its hot you use the air cond, when it's cold you use the furnace, so much simpler.
08-23-2016, 09:38 AM
2005 31' Classic
Pleasant Plains
We normally use the heat pump if the ambient temp. isn't expected to be below the mid 30s. It seems to work fine. We sometimes use a space heater too. If it's forecast to be below the mid 30s, we use the gas furnace. Also depends on other factors like wind.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
08-23-2016, 09:50 AM
2016 30' Classic
The Beautiful Mountains Of Southwest
, Virginia
Upper 30's.
We found that last fall the heat pumps In our new 2016 Classic worked quite well into the upper 30's which occurred at night during our Thanksgiving trip to TN.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
08-24-2016, 05:47 AM
Tavares
Am I to understand that the switch from heat pump to furnace occurs automatically when the temparure drops roo low for the heat pump?
Also it seems like having a small space heater might make sense. Currently we do not have one.
08-24-2016, 07:20 AM
2016 30' Classic
, Virginia
Yes!
Yes you are correct. At least that's the way they operate in our 2016 Classic. That is so you wont freeze to death during the night!
