Old 01-12-2008, 08:02 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Heading West, Plan B
All of you that I talked to at the Can Opener know my story.
I left my sisters Wednesday morning before the Can Opener with full holding tanks and headed to JD Sanders to have my Converter replaced. When I opened my door I was knocked over by the smell. Never had that happen before. I asked Sander where I could dump my tanks and they told me they did not have a place for "the public" to dump tanks. I did not get this since I owned an Airstream and theyt are an Airstream dealer. I had just walked by the place on the property where tanks were dumped. Go figure. They told me where I could go which was down towards Gainsville. This was not the direction I was travelling. I looked at my watch and decided I could make Topsail a day early. I went north and west.
When I stopped for fuel I noticed a fluid running out from underneath the trailer. It was not water or grey tank material. It was from the black tank. Ah Hah! the smell. I have a black tank leak.
I called the factory and asked where I could have it repaired along I-10. Not much until California. I was not going that far on this run.
Here is plan B. After spending four days in Mississippi and Louisiana I have detoured North. I am now in the Dallas area for a stop at North Dallas RV on Monday for the tank repair.
I beleive it is the toilet coupling. Since I was flushing the tank with a little too much vigor, some water started running out on the bathroom floor. A major clue.
I will be wandering around parts of west Texas for a few day and then headed into New Mexico and Arizona. Back to Boise by the end of the month.
Michelle TAC MT-0
Sarah, Snowball
Old 01-12-2008, 08:12 PM   #2
janetb's Avatar
2007 25' Safari FB SE
Santa Cruz , California
Hey Michelle, what do you mean too much vigor? I like the vigor! Isn't it part of what the Flush King's all about? (Hush DG--the SS is still on our list...)
How does it cause a leak at the coupling? Eek. Don't want that to happen so please post precautions.
And best of luck. See you in March!
Janet
janetb is offline   Reply With Quote
Old 01-12-2008, 08:19 PM   #3
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Question
Was your running gear properly balanced?
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 01-12-2008, 10:27 PM   #4
_
Originally Posted by janetb
... what do you mean too much vigor?...
the black tank can b very quickly filled with the f.k....
when back flushing with 'the king' the only escape for air/pressure is the tank vent tube...
this can get plugged on occasion and bad things will happen....
so one option is to prop open the toilet bowl valve...
NO pressure can accumulate this way...
also the vent tubes can come LOOSE right at the tank attachment point
i had this happen on the wash water tank and whenever the tank as full or NOT LEVEL it would leak into the trailer....
don't ever let anyone tell ya wash water doesn't stink!
cheers
2air'
cats did you consider stopping in searcy arkansas for service? they do great work there!
and gladly let customers use the hookups as needed.
Old 01-12-2008, 11:05 PM   #5
2005 22' Interstate
Afton , Virginia
Here is a site that I use when traveling, and it is pretty handy: rvdumps.com | RV Dump Stations in the United States and Canada
( I know it is a little late for it, now and that you probably already knew it, but just in case...)
regards
herrgirdner is offline   Reply With Quote
Old 01-13-2008, 06:31 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Michelle, if you are out this way again, and need your trailer's tanks dumped, Flying J at exit 192 on I-10 in Florida has a dump station. Most of them do, no matter where you are, and you can fill up your truck while you're there.
Old 01-13-2008, 07:06 AM   #7
Keymar , Maryland
No I removed the weights that the factory put on when they install the new tires. My axles are shot as well. Too many miles.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 07:07 AM   #8
Keymar , Maryland
Terry,
I thnk I missed that one on this trip. I wasn ot running the Interstates for some of my trip across Florida. I do like the US roads since hte speeds are close to the interstates and the scenery is much nicer.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 07:09 AM   #9
Keymar , Maryland
Janet
I let the tank fill up. Theroticly the water should have been running out the vent stack.
I got a complate flush on this one as well as the belly pan.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 07:12 AM   #10
Keymar , Maryland
I was not going that far north. I wanted to stay as far south as possible. IF North Dallas does not do a good job. There is always Rodger Williams.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 11:16 AM   #11
janetb's Avatar
That sounds like a good precaution. Thanks 2Air.
Old 01-13-2008, 03:15 PM   #12
2005 22' Interstate
Afton , Virginia
Michelle, if you're going as far as Tucson, Oasis (right off I10) does top notch work. -- I know that's a long, long way to drive with an odor, but if you don't get satisfaction at any other dealer, it would be worth it.
Here's hoping your next report is: Problem Cleared!
regards
Old 01-13-2008, 03:25 PM   #13
Keymar , Maryland
No pressure should accumlate if the vent is working properly.
Proping the toilet valve open can lead to nicks in the valve and eventually leaks. This could also lead to water backing up into the toilet and then the trailer.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 03:31 PM   #14
Keymar , Maryland
regards
I am not sure if am going to get that far or when. I will keep them in mind if North Dallas Rv or if necessary Roger Willams cannot solve the problem.
I tried the dealer in Phoenix and they were un-sympathetic.
Michelle TAC MT-0
Sarah, Snowball
Heading east, Plan C thecatsandi On The Road... 75 12-16-2007 06:03 AM
Where are you heading? candycane Our Community 1 11-08-2006 07:12 PM
Any Snowbirds heading west? fabofabo Airstream Motorhome Forums 0 11-03-2004 07:59 PM
I 40 Heading West- Need help, just in case! Hidalgo On The Road... 9 04-11-2004 07:13 AM
