01-12-2020, 02:59 PM
2019 30' Classic
Byhalia
, Mississippi
Get me around Cincinnati!!!
Hope to pick up our trailer from the Mothership next week. Will be coming down I75 heading toward Louisville and would like to avoid all of the construction in and around Cincinnati. Any alternate routes will be greatly appreciated, no matter how out of the way they are!
Greg
01-12-2020, 07:05 PM
1969 18' Caravel
Greenville
, whereEverIroam
Depends if you want to avoid the interstates or not.
If you want to maximize the time on interstate highways, take I 75 south to I 70 toward Indianapolis, then take 465 south around Indianapolis and hit I 65 which will take you straight into Louisville.
A shorter all-interstate route is to take I 75 down to I 274 which is the ring around Cincinnati. You may run into some slower traffic right before you hit I 274, But it won’t be as bad as going directly through downtown Cincinnati
A more scenic route would be to head west out of Jackson Center on 274 until you get to 127. Turn south. Both of these are very good state highways, but are two lane most of the way. 127 will intersect I 70. Or you can pick up 121 around Greenville and head to Richmond Indiana on a very scenic curvy road, but it may be a bit risky if there’s snow or ice.
Ohio’s major roads are basically set up in a grid pattern. Once you get to Indiana, all of the major roads are in a hub and spoke pattern, with Indianapolis at the center.
01-13-2020, 04:36 AM
2019 27' Tommy Bahama
London
, Ontario
I drove both ways through Cincinnati on I 75 in November/December and it was fine.
The other way is to take I-70 to Indy and go south to Louisville from there.
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
01-13-2020, 06:31 AM
2018 28' Flying Cloud
Clayton
, Georgia
The first time we visited JC we made the mistake of taking the bypass around Cincinnati at rush hour - bad move. Next time we just went through town on a weekend or the middle of the day, don't recall which it was, and things went fine.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
01-13-2020, 07:45 AM
2019 30' Classic
Byhalia
, Mississippi
Thanks for the suggestions and comments, they are most appreciated. Now if the factory will just finish the work, we can go get our toy!
Greg
01-14-2020, 09:41 AM
GTL48
2018 33' Classic
Greeneville
, Tennessee
Problems on I75 generally overrated. We have towed our 33 Classic and older 34 Classic numerous times (at least 10) between northeast TN and family just north of Columbus OH about 25 miles from the Mothership. We have primarily stayed on 75 through downtown and have used the beltway a couple of times. I recommend staying on 75. Try to avoid rush hour, take it slow and easy, leave some room between you and the car ahead but not too much or someone will surely dive in and cut you off. A good strategy is to follow a Semi. They are generally better drivers, travel ata steady speed in heavy traffic and are less likely to do a panic stop..good luck.
01-14-2020, 09:48 AM
2018 27' Globetrotter
Apollo Beach
This is what I always do in big cities. I find it stops people from cutting in front of you because they don't want to go into a lane behind a semi. Therefore, you can leave a little more room in front of you without others constantly filling your braking zone.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
01-14-2020, 10:06 AM
2017 16' Sport
Mount Orab
, Ohio
The beltway around Cincinnati is I275 (not I274). Just do not want anyone to get lost!
Ruby Rose
RV: 2017 16 foot Sport
TV: 2017 Jeep Grand Cherokee
Member WBCCI
Member NOVA
