Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Closed Thread
Old 05-17-2015, 11:27 PM   #21
2018 33' Classic
Montgomery , Florida
I use 2 Harley cable appox 1 inch in dia. Leave in back of truck during use and pull cover when not in use
Grateful2 is offline
Old 05-18-2015, 04:36 PM   #22
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by adamwright View Post
Anyone have any recommendations for how to keep a generator that is stored in the back of a truck secure? I have a lockable tonneau cover. for when it is not in use. I am more concerned about when the truck bed is down and the generator is in use. Is a simple chain adequate? How thick should it be to avoid theft?
No easy answers. No such thing as "adequate."
I use security chain from Tulsa Chain. They have two sizes, either will win a fight with a bolt cutter but not a grinder or torch. Heavier chain makes for a longer and louder fight with the grinder.
For some generators there are locking bases available. That may be the right answer in your situation.
Jammer is offline
Old 05-18-2015, 04:52 PM   #23
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
While camping in the desert this past winter, I enjoyed a cup of coffee with a neighbor..... While some local thugs made off with his generator, secured by a 1 inch stainless cable, his portable satellite dish, and a neighbors air compressor, also secured by a big honking tempered chain. Lesson is that if a thief want your goods, they'll get it any way possible, right under your nose!
The BLM ranger noted that a mans genset is nothing more than a very handy power source for a felons cutting wheel!
I personally use an Onan generator which looks like a science experiment, weighs 250 pounds, and requires a crane to heft around!
Those little red and blue generators are nothing but easy targets! If you want to retain them, put them inside out of site or take them with you!
I was at a lake mead camp ground a few weeks ago. A fellow had 2 Hondas sitting beside his 5th wheel. I mentioned his lack of security.... His response was "won't get stolen, I'm in a campground"!
Personally, I think security is all an illusion.
AtomicNo13 is offline
Old 05-18-2015, 05:17 PM   #24
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would bolt to truck Bed
Peace and Blessings..
Channing
WBCCI# 30676
cwf is offline
Old 10-26-2016, 10:43 AM   #25
Wadestearns's Avatar
2013 25' International
Sedona , Arizona
Generator Security
I have read many of the options for generator security and fully realize that we are for the most part devising theft deterrent solutions. Obviously the best solution is to keep the gen locked and out of sight in the TV when not in use.
Are the AS hitch chains, with a good lock a viable option for security while the gen is in use?
Thank you
Wadestearns is offline
Old 10-26-2016, 12:15 PM   #26
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
I made it as difficult as possible for the thief, but as stated, if they want it bad enough...I'll probably lose the box too, although it should take them some time.
Roy
ID:	274260   Click image for larger version
64airstream is offline
Old 10-27-2016, 07:23 AM   #27
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
When we're not using our generator (in which case I'm usually standing right next to it) it's covered and locked in the back seat area of our TV (2016 Tundra).
StreaminGeo is offline
Old 10-27-2016, 07:59 AM   #28
2010 25' FB Flying Cloud
Davenport , Iowa
THE RED, BLUE,GREEN, ORANGE AND YELLOW ARE PRETTY and easily spotted. I bought one in Airstream Camo ;lol; (silver and black) by Ryobi. Same as 64airstream. I still chain it down in the truck bed.
mike
Airtandem is offline
Old 10-27-2016, 09:47 AM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
This system gets bolted to a truck bed and then the gen set gets locked to the base with a protected lock. And they are heavy!
http://www.perfectcasita.com/ho20semosy.html
switz is offline
Closed Thread
Trailer Security (Preventing unauthorized towing) Craig Our Community 45 02-02-2016 04:43 AM
Generator Security solution widgetwizard Commercial Listings 18 07-24-2014 08:59 AM
Generator security urnmor Generators & Solar Power 6 10-21-2011 11:22 AM
