05-25-2015, 11:41 AM
2010 19' Flying Cloud
2020 25' Globetrotter
Fayettville
, Georgia
Generator Rack
Hi
I have struggled through several years and Airstreams trying to figure out the best way to haul a generator. I have always put them in the bed of my truck and once I tried to leave it in the bed while in use but I actually melted a gas container doing that. I have also tried to lift them in and out every time I use them that doesn't work very good with a larger unit.
I do see some Airstreams out there with a generator on a rear mounted rack. I have never had the opportunity to speak to anyone that uses a rear rack on their Airstream TT.
Can I get some thoughts and ideas on this?
05-25-2015, 11:48 AM
Biloxi
, Mississippi
There is company making generator racks that fit on top of the battery box. You can find it using Google.
MICHAEL
05-25-2015, 12:06 PM
houston
I've certainly seen some mounted to front hitches on a truck, hanging off the front end.
I read something somewhere about mounting on the tongue could alter the tongue weight?? I haven't looked into deep enough to know, and I also don't own any generators. But, I saw this while researching it and thought it was pretty nifty
Lock Down security mount system for Honda EU2000i generators
'15 27fb Signature
'12 Chevy 2500HD Gasser
05-25-2015, 12:09 PM
houston
front mounted
'15 27fb Signature
05-25-2015, 12:10 PM
houston
Here's a page about gensets on the tongue
RV Generator Installation | ModMyRV
'15 27fb Signature
05-25-2015, 12:11 PM
Biloxi
, Mississippi
I think over battery mount certainly would add the weight of the rack and the generator. Cost of easy storage and access I suppose. Personally I think it would be a bit of a bother to have to remove the generator and mount every time I wanted to check the batteries.
MICHAEL
05-25-2015, 12:33 PM
Fayettville
, Georgia
I really hope I can find someone that has experience carrying a generator on a rear mounted rack. Similar to a bike rack.
05-26-2015, 09:00 AM
houston
From what I understand, it's a bad idea to mount too much weight to the rear of a trailer. But some gensets are very light....
'15 27fb Signature
05-28-2015, 11:12 AM
2010 27' FB Classic
2003 36' Land Yacht XC Diesel 330 hp w/2slides
Shelby
, North Carolina
If you mount a generator on a slide out rack, does it need a ground strap to prevent static during fueling?
05-29-2015, 12:46 PM
houston
Great question. Would you be fueling directly from the pump, or from a plastic gas can? I would think a ground would be a good idea, but aren't the plastic cans static free?
'15 27fb Signature
05-29-2015, 12:51 PM
houston
Originally Posted by TarheelTrvlr
Attachment 239460
That setup looks AMAZING!
'15 27fb Signature
06-03-2015, 02:53 PM
2016 28' Flying Cloud
Brandenburg
, Kentucky
Love my Bed Slide. Had it installed immediately after purchasing my 2006 diesel pickup. It has been a great help in NOT having to crawl into the front of the bed when I can just slide the platform out and reach into a storage box.
