Old 06-27-2003, 03:03 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Gear oil: 75W-140. what does that mean??
and is it important? I'm putting synthetic oil in the gearboxes tomorrow. Dodge manual recommends synthetic if there's going to be any significant towing...they recommend 75w-140. The dodge dealer wants 20 bucks per quart for Chyrsler synthetic gear lube; mobil 1 is 7 bucks....but I think the sae grade is 70w-90. is that a problem? what do those numbers mean?
Old 06-27-2003, 03:12 PM   #2
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Re: Gear oil: 75W-140. what does that mean??
For lack of a better way to explain it the lower number is the viscosity of the oil at a certain low temperature (like 32 degrees) and the higher number is the viscosity number of the oil at a certain higher temperature (like 180 degrees).
If Dodge recommends 75W140 then use 75W140, NOT 70W90. I had problems with the rearend of a Ford Ranger running 75W140 instead of the recommended 70W90.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 06-27-2003, 03:23 PM   #3
stp2136's Avatar
I found the Texaco synthetic (85W140) a lot less expensive, about $100 for five gal. Use the Dodge sealant for the cover--it is made to withstand hot gear oil. Too bad they couldn't afford to put in a drain plug--messy job!
stp2136 is offline   Reply With Quote
Old 06-27-2003, 03:28 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Ok, I'm poking around the 'net now looking for info...do you think that 85-140 would be ok? I think that the mobil-1 is readily available in that grade. where did you get the texaco lube? haven't seen that around.
Old 06-27-2003, 05:25 PM   #5
Check farm supply stores. Should be me cheaper.
TBKP's Overlander is offline   Reply With Quote
Old 06-28-2003, 12:00 PM   #6
stp2136's Avatar
Can't speak for Dodge but 85W140 is what I used. It will have slightly higher viscosity when cold but I didn't want to pay the $20/qt at the dealer for the 75W 140. I found the Texaco at the local bulk oil dealer. I think Shell has a similar product.
Oil Filter Study ViewRVs Mechanics Corner - Engines, Transmission & More... 32 03-11-2010 06:26 PM
Running gear balance? Cedars Axles 79 06-10-2004 02:57 PM
Synthetic oil viscosities for heavy-duty towing ipso_facto Tow Vehicles 1 01-16-2004 07:04 PM
No oil pressure! Stefrobrts Mechanics Corner - Engines, Transmission & More... 3 11-06-2003 08:47 PM
GM/Dodge advice needed uwe On The Road... 16 08-17-2003 09:10 AM
